Just a question about ps fluid
Hi guys, and happy new year to you all
Just a question about PS fluid. Last summer replaced ps sterring fluid on my vette '95, was filled with a brown dye fluid, don't know what it was, and replaced with redline D4 atf. Yes i know that is not the right one though david from redline absolutely confirmed me that D4 was the right PS fluid for corvette and instead redline power steering fluid wasn't So i bought D4. Yesterday i've replaced my light truck dodge nitro PS fluid where an ATF +4 from owner manual is required. Well i've replaced all old fluid with new Atf +4.experienced whining noise from pump before, and now no more whining, and very smooth operation :thumbs: Corvette instead has some problem. Whining noise and no so smooth operation, we have already discussed about this in an old thread, someone said me pump bearing could be the noise culprit, but at this point i'm wondering if even a wrong oil in could it be?? |
Originally Posted by Christi@n
(Post 1591251719)
Hi guy, and happy new year to you all
Originally Posted by 93Rubie
(Post 1591252099)
Their application guide does indeed list the D4 as the recommended fluid. I've ran their regular PS fluid in my 93 for a couple years and it has not had any issues at all. In fact it works better than the old stuff that was in the system before. So IDK, interesting experiences I guess.
I'd like to know even other opinions, about which fluid USUALLY to use in corvette PS since that From owner manual the only option is the GM fluid.
About redline and their application guide, i've recently discovered that their fluid (as example c+) are not officially approved from car manufacturer. In fact there's an atf +4 in place of a c+ for chrysler. And the same i think for other fluids. |
Interesting I've been using Redline PS fluid in my '89 C4 for years and it works great, no issues.
It's what redline recommends for my '89 P/S pump; D4 ATF is recommended for the auto tranny. http://www.redlineoil.com/application.aspx Not sure why they recommend D4 ATF for the P/S pump and the auto tranny in a '95. Something must have changed. |
I believe you have someone in the US that forwards you parts BUT I don't believe forwarding of any fluids via USPS is allowed. If it were I believe the GM Cold Climate (GM # 12345867) might be a wise buy. It's been used in problem systems with success.
Land Rover has a spec that is likely the same/similar by Texaco. Here's a .pdf of the fluid and spec. If this were available to you it might be a go to. http://www.southernlubricants.co.uk/...ng%20Fluid.pdf This product for a problem system is maybe a go to: I don't know that I could agree to any use of any ATF derivative EXCEPT in an emergency situation. I'd think any ATF derivative could maybe aggravate your situation. You might check availabilities of the latter 2 if you've issues. The GM CC product is a proven product for ornery systems. |
Originally Posted by mako41
(Post 1591253976)
Originally Posted by WVZR-1
(Post 1591253983)
Land Rover has a spec that is likely the same/similar by Texaco. Here's a .pdf of the fluid and spec. If this were available to you it might be a go to. http://www.southernlubricants.co.uk/...ng%20Fluid.pdf This product for a problem system is maybe a go to: Amazon.com: Pentosin CHF202 Power Steering Fluid (1.06 qt): Automotive I don't know that I could agree to any use of any ATF derivative EXCEPT in an emergency situation. I'd think any ATF derivative could maybe aggravate your situation. You might check availabilities of the latter 2 if you've issues. The GM CC product is a proven product for ornery systems. Let me know please which are the right one for my car if you know, over GM, solded in US |
Back in 2006, I started doing open track days with my 1987 coupe. At the time, the fluid that was in the power steering system was the GM power steering fluid that came from a local Chevy dealer. Everything seemed to work fine; no shudder when turning, no noise from the original PS pump.
After a year or so of doing track days where the engine ran at higher RPM's (4000+ RPM) I noticed that the pump would start to whine loudly when the fluid got hot. So I flushed out all of the old PS fluid and re-filled the system with RedLine Synthetic power steering fluid. All of the noise from the pump went away. At the same time I added a small PS fluid cooler. This also made a big difference. I still track the car and it still has the original PS pump in place. No noise, no difficulty with steering effort, no problems. I find that very significant considering the pump is 28 years old. I would suggest that you purchase some RedLine Synthetic PS fluid (not the D4 stuff), flush the system and install this fluid to see if that solves your problems. I have no idea why RedLine would recommend an ATF fluid for power steering applications when they make a very good power steering fluid. |
Originally Posted by c4cruiser
(Post 1591255280)
After a year or so of doing track days where the engine ran at higher RPM's (4000+ RPM) I noticed that the pump would start to whine loudly when the fluid got hot. So I flushed out all of the old PS fluid and re-filled the system with RedLine Synthetic power steering fluid. All of the noise from the pump went away. At the same time I added a small PS fluid cooler. This also made a big difference. I still track the car and it still has the original PS pump in place. No noise, no difficulty with steering effort, no problems. I find that very significant considering the pump is 28 years old. I would suggest that you purchase some RedLine Synthetic PS fluid (not the D4 stuff), flush the system and install this fluid to see if that solves your problems. I have no idea why RedLine would recommend an ATF fluid for power steering applications when they make a very good power steering fluid. What do you think if i will try to stay with AMS OIL psf |
(Post 1591255708)
This question is pretty controversial, when i turn application guide year on redline web from 87 to 95 vette, their power steering fluid isn't in guide anymore. The d4 is in place of it.
What do you think if i will try to stay with AMS OIL psf Another question if you have the Owner's Manual for you '95: What power steering fluid recommendation is shown in the manual? Does it show a specific GM part number or simply show what type of fluid is to be used. There should be a table in the back of the book in the "Maintenance Schedule" section that will list the recommended fluids & lubricants. There will be a box for "Power Steering System" and that's where you should see the specific fluid to use. |
The Cold Climate stuff either makes the whine/noise go away OR you've larger issues. I've used the CC GM stuff in a ton vehicle with hydro-boost and that system had whine, it was a rather expensive new pump so we did the GM Cold Climate as pretty much a test.
The last time I saw the truck and rode in it the system was maybe 3 years older and there was no normal operation whine. It doesn't FIX a failed/failing part but it's a remedy for many conditions. Yours is a driver so I doubt the need for all the conversations regarding straight synthetic. Like the Texaco stuff I imagine the GM CC is a "blend" and for likely a reason. I referenced 3 products that maybe meet the requirements, 2 of them should be available locally. |
(Post 1591256198)
Just try the Red Line synthetic power steering fluid! You originally mentioned that the pump itself may have a bad bearing. No fluid will fix that.
Another question if you have the Owner's Manual for you '95: What power steering fluid recommendation is shown in the manual? Does it show a specific GM part number or simply show what type of fluid is to be used. There should be a table in the back of the book in the "Maintenance Schedule" section that will list the recommended fluids & lubricants. There will be a box for "Power Steering System" and that's where you should see the specific fluid to use. It says gm part No. 12345866 or 12345867 Also could it written on it, not sure cause not have it in hand, or equivalent syntetich power steering fluid |
(Post 1591255708)
I run Lucas Power Steering Fluid with conditioners and autox and some track time. Never had any issues. Currently still have the original ps pump on the 91.
Rubie autox too with the Redline Power Steering fluid so it should work fine as well. :cheers: |
(Post 1591259205)
That's not true, they recommend their Synthetic P/S fluid for my '89 C4 in their online guide. That's what I've been running for years.
PS fluid for 87 89, but if you put year 95 you will see that the reccomended fluid for ps is d4 |
(Post 1591261360)
That is what i said.
PS fluid for 87 89, but if you put year 95 you will see that the reccomended fluid for ps is d4 Still don't get why the '87 and '89 would have a different recommended P/S fluid (the Synthetic) when other years they recommend their D4 ATF fluid??? What's different? Isn't the GM P/S fluid spec the same for all late model C4's?? |
1 Attachment(s)
From my OM
Question is is which an equivalent?
Add another user of the Red Line PS fluid on a track only 92.
I found a in-line Auto Trans / Power Steering Fluid Filter set-up on an on-line auction site a number of years back, and installed that in the return line. So far - no problems, and while there is a factory cooler in the system - I'm pretty sure that fluid has gotten pretty warm on occasion. |
