After polishing
I removed all the swirl marks with a fine cut compound. Polished with a Pro machine glaze. Then finished up with an ultimate polish.
If I wash the car, will the washing remove the oils in the polish? Just what would be best result. I want to apply a sealant. Then a couple layers of wax. Thank for the advice. |
Originally Posted by 3RD-INF
(Post 1591266943)
If I wash the car, will the washing remove the oils in the polish? Just what would be best result. I want to apply a sealant. Then a couple layers of wax. Thank for the advice. 1. Paint Cleansing Lotion 2. Commercial Solvent Wiping Agent 3. Specialty Paint prep products I have also found that a light wash (to avoid marring) with a good soap (make sure soap doesn't have wax or glossing agents in it) will indeed prep for the sealant of your choice. I have also seen a homemade mixture of alcohol/water spritzed on paint and wiped off will often remove any remaining oils also. |
CG Citrus Wash & Gloss worked good for me. I know Autogeek said to stay away from gloss enhancers..but Im pretty sure this formula is designed for this purpose..I could be wrong though :leaving: Have also heard Dawn soap does well.
I have a good shampoo. I'll use it to remove the oils and what ever is left from the polish. Thanks for all of the info. Again the C F comes through. :thumbs:
Originally Posted by pyrodav
(Post 1591268951)
Have you considered a coating instead of a sealant? You've done all the prep work already. A coating is actually quicker and easier to apply. I did my '08 fourteen months ago, and it still looks great. |
I use Menzerna top Inspection from Autogeek on a MF bonnet with the DA. Works great!
I just gave my car a quick wash after the paint correction to ensure I got all the dust off the car and had the paint perfectly clean before I went ahead with the sealant. Came out great!
