New Radio Display
All of a sudden my radio display has changed. Half of the screen now shows XM radio station option rather than just the lower section of the screen. I now also have bluetooth for the radio. When I first turned the car on this morning it was playing a song from my I phone. Has new software been downloaded from XM or GM? My car is a 2015.
No software downloads from outside sources. More likely the system just needs a reset. Turn it off for an hour or two.
Without a picture it's hard to know what you mean. If you suddenly have more than 1 row of "channel buttons" you may have accidentally swiped up on the display. The cure is to swipe the top of the top row of buttons down to hide them. The touch screen is tricky and takes a lot of trial and error.
If I misunderstand your issue, please post a picture. Good Luck! Ron |
It's not GM.
Did you just upgrade to iOS 9.2 on your iPhone? To change the display, switch to another source (AM, FM, USB, etc.) or if you see a lot of preset station buttons, try to press the top part of the top row and drag them back down. |
Hit your HOME button and see if anything changes.
I did learn about the swipe up/dn. I did not know about that feature. It may be the IOS software that connected the blue tooth. Thanks for the replies.
Definitely due to the iOS update many others are complaining about.
Let's not start another sue GM thread....:toetap:
