Best tire for Z06? Who knows?
Toyo Proxes 1 or Toyo Proxes T1 Sport?
Have any of you replaced your tires for the street, desiring a high performance tire that can be driven in wet and dry? If so, what tire(s) would you recommend. Best |
Originally Posted by RBK
(Post 1591310550)
I can get correct sizes but unsure as to the best "street" performance tire. Toyo has a few choices and not sure how they differ (I cannot get enough from internet search). I am curious as to P1's compared to Toyo after knowing which Toyo is recommended. I have a friend who put Toyo's on car and he likes them. Best
Originally Posted by lgodom
(Post 1591312260)
Haven't seen any posts of members running Toyos. I went to their site and the Z06 only has front tires showing in the right size.
I've put 8k on a set of Continental DW extremes on a 2015 Z07. Quiet, great in the rain, no wandering, better grip cold than Michelin. They come in the Z06 Size although they don't have the same square look as MSS, a bit rounded off. I'll buy another set for the street when worn I expect 25k out of them.
Now the problem, they suck on the track unless your working on your 4 wheel drifting skills. https://cimg1.ibsrv.net/gimg/www.cor...201af2e965.jpg Look good too! |
Given that many here have had a Z06 for a year or more, and nobody has any expereience with a replacement tire?
As this is written, I appreciate the report regards Continental. I have "gleened" from different readings the following; Toyo T-1 Sports but in downsized form - one user likes them. Michelin Super Sport - sounds good on paper Pirelli P Zero's, reportedly compromised grip and a bit more road noise I would like any reports of "experience" - Best |
Michelin Pilot Super Sports seem to work well on everything in autodom. They've improved everything I've tried them on, from a C6 to a Miata, and they even ride very well. Amazing tire. They would be my first choice for an aftermarket C7 tire.
The stock run flat super sport handles pretty good and last a fair amount of mileage. The Toyo's may be cheaper but they aren't going to compete with the Michelins. If you know how to drive cool weather and rain won't bother you as the Michelins are quite capable in those conditions if you don't use your throttle as on/off switch. Now if you have the Cup tires and don't go to the track it may be worth while to switch to the super sports that come on the non Z07 Z06.
I have run Toyo R888s on the track but I haven't seen anything in the Toyo street tire line up that is as good as the Michelins. Bill |
Helpful, thanks. Best
(Post 1591318045)
Bill- wrote to you on my other thread (was trying to get responses so went "fishing" with two threads). Bottom line - going with MPSS tires. Best
(Post 1591318045)
Being in the Pacific NW, the Cup 2s were just not going to cut it for half of the year. I swapped them out for the MPSS and have been very pleased with their wet and dry performance.
MPSS's in non run flat are great. I've bought many of them and put many miles on them. Especially when I had my 11 Grand Sport. Put over 90K miles on it and from the factory alignment it ate tires like crazy. I had a more street, Hi mileage, alignment done and it wasn't as bad, but I was hard on tires. For the most of its life it had over 750hp. So lighting them up at will was easy. You should see my driveway.
(Post 1591310550)
Originally Posted by LouieM
(Post 1591318028)
You have to go 325 rear and 275 front. Funny thing is the rear tread is .1 inch wider on the 325 non run flat vs the 335 factory PSS. The ride is much better a lot less tire noise and they are several pounds lighter in weight. They are .2 and .3 shorter. Which seemed noticeable on the ZR1 but not this car:crazy: This is my second second set. I ran the same tire on the ZR1! They are the number 1 tire! Bar none! |
Originally Posted by 3 Z06ZR1
(Post 1591343202)
I have put non runflat Michelin SS on mine. They just don't come in the stock sizes.
(Post 1591343202)
I'll be swapping the Cup2's for the SS's but I'm planning to go +1 on the size in the rears (345).
Can anything really top MPSS's for overall street use? It's a hard to tire to beat. They used the word "super" with good reason.
(Post 1591343202)
You have to go 325 rear and 275 front. Funny thing is the rear tread is .1 inch wider on the 325 non run flat vs the 335 factory PSS. The ride is much better a lot less tire noise and they are several pounds lighter in weight. They are .2 and .3 shorter. Which seemed noticeable on the ZR1 but not this car:crazy: This is my second second set. I ran the same tire on the ZR1! They are the number 1 tire! Bar none! I dont want the speedo to be off, and I definitly dont want less rubber on the road. But it seems like the Continentals run small and Michelins run large, correct? |
I also run the MPSS (non-run flat) 325 rear and 275 front. I went through three sets of MPS Cup 2. I was only getting 2 tracks days out of these tires and daily driving until the second track day, then replacement. I have now driven about 6,000 miles on the MPSS (non run flats) + 6 track days and they are maybe 50% worn. I consider them the best bang for buck and they work well on the track and street. I live in Northern California (San Jose) so winters are mile 40*-50* are typically the low temps I drive in, and they work fine if you given them 10 minutes to warm up.
Shameless plug of me (Silver Z06) passing a buddy during a track day on the MPSS (non-run flats).
(Post 1591343202)
Originally Posted by centennialGS
(Post 1598372865)
Alright, bringing this thread back. I will need some new tires for spring, and hopefully can find a good black Friday deal tomorrow. I currently have 285/30/19 and 335/25/20 Continentals on the car, and hate the rounded stretch look. I'm considering going with Michelins this time, but really don't want the run-flats. Should I go with the 275/30/19 and 325/25/20 Pilot Sport 4S? Or Should I just get another set of Continentals in stock size and not worry about it?
