Edelbrock SuperChargers-C7 Corvettes
3 Attachment(s)
Edelbrock SuperChargers C7 Corvettes Stage 1 Systems Supercharger System, E-Force, Grey, Serpentine, With Tuner, Dry Sump Oil System, Corvette, C7, 6.2L, If 460 horsepower from the factory is not enough for you... then Edelbrock E-Force C-7 Corvette Supercharger systems are what you need for your Stingray. These systems are designed with the same precision as the new Corvette, making it the perfect forced induction solution for the C7. Best of all Edelbrock E-Force superchargers fit under the stock hood with no modifications allowing you to retain the factory look of this highly engineered masterpiece. If you want to take your C-7 to the next level then Edelbrock E-Force C-7 Corvette Supercharger systems are what you're looking for! Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) $9400.00 Installed Stage 2 Systems 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ $9500.00 Installed Call Toll Free/PM/Email for non installed pricing Authorized Edelbrock Installer Attachment 47946274 Attachment 47946275 Attachment 47946276 |
Edelbrock SuperChargers C7 Corvettes Stage 1 Systems Supercharger System, E-Force, Grey, Serpentine, With Tuner, Dry Sump Oil System, Corvette, C7, 6.2L, If 460 horsepower from the factory is not enough for you... then Edelbrock E-Force C-7 Corvette Supercharger systems are what you need for your Stingray. These systems are designed with the same precision as the new Corvette, making it the perfect forced induction solution for the C7. Best of all Edelbrock E-Force superchargers fit under the stock hood with no modifications allowing you to retain the factory look of this highly engineered masterpiece. If you want to take your C-7 to the next level then Edelbrock E-Force C-7 Corvette Supercharger systems are what you're looking for! Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) $9400.00 Installed Stage 2 Systems 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ $9500.00 Installed Call Toll Free/PM/Email for non installed pricing |
Is that 599hp from the stage 2, RWHP or crank hp? Also what is the stage 1 RWHP or crank hp?
Thanks |
Originally Posted by BlueDevilZ51
(Post 1591426332)
Thanks |
Stage 1 Systems Supercharger System, E-Force, Grey, Serpentine, With Tuner, Dry Sump Oil System, Corvette, C7, 6.2L, If 460 horsepower from the factory is not enough for you... then Edelbrock E-Force C-7 Corvette Supercharger systems are what you need for your Stingray. These systems are designed with the same precision as the new Corvette, making it the perfect forced induction solution for the C7. Best of all Edelbrock E-Force superchargers fit under the stock hood with no modifications allowing you to retain the factory look of this highly engineered masterpiece. If you want to take your C-7 to the next level then Edelbrock E-Force C-7 Corvette Supercharger systems are what you're looking for! Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) $9400.00 Installed Stage 2 Systems 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ $9500.00 Installed Call Toll Free/PM/Email for non installed pricing Authorized Edelbrock Installer |
Edelbrock SuperChargers C7 Corvettes Stage 1 Systems Supercharger System, E-Force, Grey, Serpentine, With Tuner, Dry Sump Oil System, Corvette, C7, 6.2L, If 460 horsepower from the factory is not enough for you... then Edelbrock E-Force C-7 Corvette Supercharger systems are what you need for your Stingray. These systems are designed with the same precision as the new Corvette, making it the perfect forced induction solution for the C7. Best of all Edelbrock E-Force superchargers fit under the stock hood with no modifications allowing you to retain the factory look of this highly engineered masterpiece. If you want to take your C-7 to the next level then Edelbrock E-Force C-7 Corvette Supercharger systems are what you're looking for! Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) $9400.00 Installed Stage 2 Systems 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Wet Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ Edelbrock 2014-15 Corvette Stingray Z51 Dry Sump (LT1) STAGE 2 / TRACK SYSTEMS / 599 HP & 547 TQ $9500.00 Installed Call Toll Free/PM/Email for non installed pricing Authorized Edelbrock Installer |
Originally Posted by Xplosive Performance
(Post 1591429063)
Both systems are close to the same RWHP the stage 2 putting down about 550RWHP the stage 1 just a little less. The Stage 2 is slightly underdriven giving it a little more power and uses an Edelbrock wider pulley system. The stage 1 uses stock pulley system and is not underdriven.
You would think that 2 psi would net you more than 13 HP over the stage one 537 HP. |
Originally Posted by RichardT
(Post 1591544358)
Then why is the advertisement saying 599HP? I am about 48 hours from buying an EForce system and don't really know which one to get. The stage 2 is supposed to be 2 psi more - 6 psi versus 8 psi.
(Post 1591545036)
Advertising unless stated will normally use Flywheel HP ratings which is higher than Rear Wheel HP (RWHP). All HP ratings are subjective given the conditions in which the test was run, they are a guideline.
So far, nobody including Edelbrock can answer what the true rwhp or crank hp of the stage 2 system is. 624 flywheel HP loosely translates to 537 RWHP. Yet, the stage 2 system has 2 more PSI! Does anyone here understand the point I am trying to make? Do I just go out and buy the stage two system and hope for the best? The guy at the technical line at Edelbrock really didn't know what he was talking about - I had to correct him several times and both times he admitted his info was incorrect. Yet, he told me that the stage 2 system also has the supplemental warrantee. Is this correct? |
(Post 1591546637)
I don't mean to be adamant, but Edelbrock says their stage one system has 624 flywheel HP and that their stage two system has 537 RWHP.
Thank You! This is the most information anyone has ever provided regarding the two systems and your reply makes perfect sense.
Best case, if the stage two makes 670 RWHP, taking off 14% with an M7, gives us about 575 RWHP. It is my hope traction is not so non existent at 5000 ft elevation..... I get some wheel hop now, does that go away with more power, or do I just break half shafts? |
(Post 1591548708)
