Need wiring plug at rear shock? Where?
Hard launch w 2014 Z51. Broke axle and destroyed a plug at the shock. Anybody know where I can buy one? I'd rather not buy the whole rear harness. Thanks
Sorry, I don't know about your wiring plug, but can you tell us how much power and what tires you used when the axle broke? M7 or Auto trans?
Thanks and good luck. |
Can you post a picture? I may one to send you.
Originally Posted by DoubleDown
(Post 1591411774)
Thanks and good luck. 735 rwhp M&H drag radials 325/60/18 18 lbs of air 55 degrees 60% humidity -10 altitude Pro built 6 speed with stall speed 2nd car on a well prepped track. The shaft snapped at the taper point for the inner boot clamp. |
Originally Posted by 3X2
(Post 1591412031)
