C7 z06 throttle response
Anyone have any good ideas for a better throttle response that would be more on par with a N/A motor? I know a SC motor will always act differently than a N/A motor however, I was looking for better throttle modulation capabilities especially while on the track.
I have heard that a ported throttle body helps combats this somewhat?? If not, is there any thing else that can help? Thanks |
A tune will fix a lot of it. Is it too sensitive? Or dull/numb?
The blade doesn't actually open all the way until 5000 rpm/ish. Its very much reducing torque even when driver demand is at 100% |
Originally Posted by GSpeed
(Post 1591422635)
The blade doesn't actually open all the way until 5000 rpm/ish. Its very much reducing torque even when driver demand is at 100% Very dull on the initial application of the throttle. A noticeable delay. Or if you ever need to jab the throttle for a short burst. It's just not there like a NA car. Sweeping corners also it's very noticeable. If your mid throttle to full then back to mid then back to full throttle etc. Modulation seems very difficult. Almost as if the throttle is a normal light switch rather than a dimmer light switch lol. |
I have a video showing the opening rates of a Stock C7. You would crack up at what it does. Ill work on posting it. The C7Z, is worse.
(Post 1591425456)
