License plate light dilemma !
Ok .. 1965 C2 Vert.. So i switched to lED lights from Bruce (ohiovet) and their perfect.. Then i got a LED light for the license plate and its very bright.. One side .. The right side is very bright .. Left .. Not so much.. Problem is only 1 bulb.. Looks retarded.. Anybody .. Have a fix ? Ty Joe :crazy:
Just a thought...:hide:
Is the ground on the week side making full contact were its connected? |
Originally Posted by 66jack
(Post 1591509967)
Is the ground on the week side making full contact were its connected? Going to send back the this bulb an order the tower LED bulb which is longer , slimmer and has a better field of view.. 360.. Eh ! |
Have OhioVette's LED Tail Lamps and Front LED Parking lights.. All top Quality.
I would PM him with your Phone number.. He'll call you back... I'm sure he will work with you.:thumbs: |
Originally Posted by ACCURATE
(Post 1591509786)
Are you saying the thing is BUILT WITH only 1 bulb, or that only 1 bulb is not working correctly? |
Originally Posted by SI67
(Post 1591511580)
Joe,
LED bulb for license plate light.
Typically the standard license plate bulb works with the lens to scatter the light and light the license plate.
I have found that many LED bulbs tend to "focus" the light and therefore it is not scattered or defused by the lens. My suggestion is to try different style LED bulbs to see if one works better then another. There are also some nice license plate frames that have LED lights built into them. There are some good deals on Ebay at times. |
Originally Posted by ohiovet
(Post 1591514467)
(Post 1591515666)
Exactly what i'm going to do..Ty Bruce .. Love the LED lights ..Joe
Thanks : Mark |
#5008 incandescent bulb. Try one and be done. Won't melt your lens, has no dim spots and is twice as bright as the original #68 bulb.
LEDs are great for a lot of applications, but sometimes they just don't get the job done. |
LEDs are great for a lot of applications, but sometimes they just don't get the job done.[/QUOTE] :iagree:.going to one more suggestion an 1156 bulb from LED .. If that does not work then 5008 it is .thanks. Joe :cheers: |
(Post 1591517243)
LEDs are great for a lot of applications, but sometimes they just don't get the job done. :iagree:.going to one more suggestion an 1156 bulb from LED .. If that does not work then 5008 it is .thanks. Joe :cheers:[/QUOTE] New bulb 1156. Worked like a charm. .,, bright and even.. Problem solved !! |
1156 Bulb
Just watch out---1156 bulbs generate a lot of heat. Their main use was for back up lights. Make sure your lens doesn't start to melt---Keep an eye on it !!!
RON |
