Catalytic Converter Heat Shields for C7/C7 ZO6
4 Attachment(s)
Catalytic Converter Heat Shields for C7/C7 ZO6 Prevent catalytic converter heat soak from raising your oil temperatures. Due to the location of the stock converters heat soak that can raise your oil temperature on the track is a common concern. Help prevent elevated oil temperature with DEI TITANIUM PIPE SHIELD. DEI’s Titanium Pipe Shield combines the high heat tolerance of DEI’s proprietary LR fiber technology with a unique rivet-based clamp shield design to improve heat dissipation and cooling. Titanium Pipe Shield provides heat protection up to 1350°F. LR fiber technology is a two-ply material. The outer layer is made from pulverized and stranded lava rock into a proprietary tightly woven weave for durability and strength. The inside material is made of a special high temperature resistant fabric (89% silica) designed to withstand 350 degrees more heat than glass fiber. This proprietary fiber technology combined with DEI’s unique shield standoff bracket design provides an air gap between the shield and pipe that together provides the maximum potential for cooling and heat dissipation. Attachment 47961631 Attachment 47961632 http://www.xplosiveperformance.com/D...d-_p_4070.html DEI C7 CORVETTE OIL COOLER LINE HEAT SHROUD Attachment 47967431 Attachment 47967432 http://www.xplosiveperformance.com/D...ud_p_4075.html |
Yesterdays orders shipped Thanks
http://www.xplosiveperformance.com/D...12_p_4070.html |
All orders shipped
http://www.xplosiveperformance.com/D...d-_p_4070.html |
I think I am going to pick one of these up soon for my Z51 just to see if it makes any difference down here in the TX heat. I should have just had my cat pipes ceramic coated while they were off, but oh well!
Do you need 2 of these if you want to cover both cats?
Originally Posted by EcoBrick Bob
(Post 1591829550)
(Post 1591829550)
Originally Posted by Kracka
(Post 1591834717)
If I do it, I will likely only do the one near the oil cooler.
Catalytic Converter Heat Shields for C7/C7 ZO6 Prevent catalytic converter heat soak from raising your oil temperatures. Due to the location of the stock converters heat soak that can raise your oil temperature on the track is a common concern. Help prevent elevated oil temperature with DEI TITANIUM PIPE SHIELD. DEI’s Titanium Pipe Shield combines the high heat tolerance of DEI’s proprietary LR fiber technology with a unique rivet-based clamp shield design to improve heat dissipation and cooling. Titanium Pipe Shield provides heat protection up to 1350°F. LR fiber technology is a two-ply material. The outer layer is made from pulverized and stranded lava rock into a proprietary tightly woven weave for durability and strength. The inside material is made of a special high temperature resistant fabric (89% silica) designed to withstand 350 degrees more heat than glass fiber. This proprietary fiber technology combined with DEI’s unique shield standoff bracket design provides an air gap between the shield and pipe that together provides the maximum potential for cooling and heat dissipation. https://www.corvetteforum.com/forums.../wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1140x1461.https://www.corvetteforum.com/forums...7converter.jpg https://www.corvetteforum.com/forums...ipe-shield.jpg http://www.xplosiveperformance.com/D...d-_p_4070.html DEI C7 CORVETTE OIL COOLER LINE HEAT SHROUD https://www.corvetteforum.com/forums...15-x-4-5_2.jpg https://www.corvetteforum.com/forums...oler_line3.jpg http://www.xplosiveperformance.com/D...ud_p_4075.html |
Prevent catalytic converter heat soak from raising your oil temperatures. |
Prevent catalytic converter heat soak from raising your oil temperatures. Due to the location of the stock converters heat soak that can raise your oil temperature on the track is a common concern. Help prevent elevated oil temperature with DEI TITANIUM PIPE SHIELD. DEI’s Titanium Pipe Shield combines the high heat tolerance of DEI’s proprietary LR fiber technology with a unique rivet-based clamp shield design to improve heat dissipation and cooling. Titanium Pipe Shield provides heat protection up to 1350°F. LR fiber technology is a two-ply material. The outer layer is made from pulverized and stranded lava rock into a proprietary tightly woven weave for durability and strength. The inside material is made of a special high temperature resistant fabric (89% silica) designed to withstand 350 degrees more heat than glass fiber. This proprietary fiber technology combined with DEI’s unique shield standoff bracket design provides an air gap between the shield and pipe that together provides the maximum potential for cooling and heat dissipation. |
(Post 1591844573)
I have it from a good source that by using only one, that the temperature difference between the after cat exhaust will make your car sound like a Voltswagen Diesel.....:ack:
Can folks chime in on their experience with the DEI CAT cover on the track? Really curious as to how effective this is to lower Oil Temps.
How well do these keep your oil cool? Do you need both cats covered? Will it hurt the cats/exhaust?
Originally Posted by Checkmate1
(Post 1594428336)
Originally Posted by bsedwebt
(Post 1596677379)
