Now available from SCP: Corvette C6 ZR1 K&N Air Intake Kit - Carbon Fiber
Corvette C6 ZR1 K&N Air Intake Kit - Carbon Fiber 63-3080
The AirCharger Air Intake System is guaranteed to increase your ZR1 Corvette's horsepower and it comes with K&N's Million Mile Limited Warranty. This K&N air intake system replaces your ZR1 Corvette's restrictive factory air filter and air intake housing with a low restriction intake that includes an oversized high-flow air filter. The air filter and engine intake are joined with a low restriction custom carbon fiber design that will attract attention when the hood is open. The K&N air filter matches with a carbon fiber top and base. http://www.southerncarparts.com/images/63-3080.jpg The filter will provide outstanding engine protection and it can be used for up to 100,000 miles before servicing is needed depending on driving conditions. The air intake is easy to install with common tools and bolts into existing factory mounting points. Available here: Corvette C6 ZR1 K&N Air Intake Kit - Carbon Fiber 63-3080 |
:cheers:
Thank You for shopping at https://www.southerncarparts.com/cor...c-805-558.html
