Brembo performance brake kits
BREMBO PERFORMANCE BRAKE KITS CHEVROLET CORVETTE C6 Z06 | GRAND SPORT FRONT 6-PISTON MONOBLOCK | 350X34 MM (13.8") | 2-PIECE DISCS TYPE III SLOTTED Front kit contains: v Two 6-piston monobloc calipers (Black, Red, Silver, or Yellow) v Street performance brake pads v Two 2-piece floating type III slotted rotors 13.8”/350mm diameter v Front Goodridge stainless steel braided brake lines v Adapter brackets These 6-piston monobloc calipers have more brake torque using a wide annulus,kit uses the VERY high thermal 34mm thick rotor ring with 72 vanes. This kit is excellent for everyday driving and HPDE events http://www.xplosiveperformance.com/C...d-_p_2987.html https://www.corvetteforum.com/forums...s-image008.jpg CORVETTE C6 FRONT 05-13 BREMBO RACING CALIPER (EXC ZO6/GS) 4-piston caliper, 2-piece, machined from casting 355x32x64a Type-5 The design of the new “race-ready” brake systems also meets or beats the requirements of numerous sanctioning bodies including SCCA, NASA, Grand-Am, BMWCCA and PCA, among others. Engineered for motorsports competition and dedicated track cars These race systems include: Ř New cast racing caliper with hard-anodized finish to improve resistance to thermal and mechanical stresses typical in the racing world. During the design stage, particular attention was paid to obtaining the best ratio of stiffness and weight reduction using special machining techniques. Ř Brembo thermo tape on the caliper Ř Type 3 & 5 groove assembled floating discs (from 328mm to 380mm) with high thermal capacity and heat dissipation Ř Caliper brackets Ř Steel braided brake lines http://www.xplosiveperformance.com/C...S_p_3801.html# https://www.corvetteforum.com/forums...s-image003.jpg CHEVROLET CORVETTE C6-PISTON MONOBLOCK | 355X32 MM (14") | 2-PIECE DISCS SLOTTED BREMBO GT SYSTEMS Front kit contains: v Two 6-piston monobloc calipers (Black, Red, Silver, or Yellow) v Street performance brake pads v Two 2-piece floating type II slotted rotors 14”/355mm diameter v Front Goodridge stainless steel braided brake lines v Adapter brackets These 6-piston monobloc calipers have more brake torque using a wide annulus This kit is excellent for everyday driving and HPDE events http://www.xplosiveperformance.com/C...ed_p_3331.html https://www.corvetteforum.com/forums...s-image008.jpg Rear kits also available |
brembo performance brake kits
brembo performance brake kits |
chevrolet corvette c6 z06 | grand sport front 6-piston monoblock | 350x34 mm (13.8") | 2-piece discs type iii slotted
