New Build: Forged 370, ECS 2200-SL, RPM TR6060 and more
Last year we completed this build https://www.corvetteforum.com/forums...200-build.html I was happy with the power (700rwp 63xtq on 12lbs) but my T56 was not:ack: At the last ½ mile event in Sept 2015, I was having issues with my RPM T56 and decided at the first on the year I would fix it or replace it. A few months later I got my hands on a RPM Lv6 TR6060 Lv 6. While removing the transmission I ended up selling my LS6 and decided to build a motor. The order for the motor was placed on the first week of March and should be arriving in the next week or so. My goal for this build is to have a 1000hp street car and run in the 190mph range at the ½ mile events:D. All work and tunning is being done at LSXPERTS in Ball Ground, GA.
Parts list consist of: Motor TMS 370 ci Short Block (Painted Black) • Blueprinted GM 6.0 block Seasoned core • King racing main bearings • King racing rod bearings • TMS cam bearings • K1 4340 Forged crankshaft • TMS 4340 forged H-beam connecting rods and ARP rod bolts • TMS Moly rings • Diamond pistons 4.030" • ARP main stud set • ARP 2000 connecting rod • Stainless top ring • Brain Tooley Custom Cam* LS3 Top End • Stock LS3 Intake Manifold (Painted Yellow) • Stock LS3 Heads • LS2 Throttle Body (Painted Black) • Brain Tooley .660 Valve Springs • ARP Head Studs Nitrous Outlet Water Vapor Bleed Cross Over Kit Eddie Motorsports Valve Covers (Painted Black) ECS Supercharger C5 Kit • Polished Paxton SL-2200 • 3.25 blower pulley • Innovators West 8 rib 10% Overdrive Balancer • Polished Bracket • Black Ducting Exhaust • LG Motorsports LT Headers • Borla 3” Exhaust, quad 4” tips Clutch/Shifter/Transmission Monster LT1-R Twin Disc Clutch MGW Short Throw Shifter RPM TR6060 LV6 • Media blast transmission case • Hand fit sliders and hubs • Assembly to our specifications • Bronze fork pads on all gears 1-6 including reverse • Micropolish by Performance Metal • Bronze shifter bushing when applicable • Transmissions fitted with pump are upgraded to ZR1 pickup tube • Carbon blocking rings • Cryogenic tempering • Pinon Gear Re-splined from 28 to 30 Fuel • FIC 850cc Injectors • ECS Fuel Block • Holley Dominator In-Line Billet Fuel Pump • Holley Billet Fuel Regulator • Custom Fuel Lines Alky Dual Nozzle Methanol Kit I'll update the thread with pictures once I get back to the shop. As for now here is a few. This is what started the whole build :D. In order to make the RPM TR-6060 work in the C5Z without swapping to a C6z cradle RPM resplined the pinon gear from 28 to a 31 spline. https://cimg1.ibsrv.net/gimg/www.cor...a3ff16f296.jpg Painted LS3 Intake https://cimg0.ibsrv.net/gimg/www.cor...b91a0044f3.jpg After talking to Doug about my goals he advised me that I might need to go up to the 2200R or the YSI in order to reach my goals. This build has broke the bank:willy: and for now we are going stick with the SL and see what it can do. https://cimg6.ibsrv.net/gimg/www.cor...5e6c5d6f0e.jpg Holley Fuel Pumps and regulator. We will be running both Holley pumps + the stock pump on this build. https://cimg4.ibsrv.net/gimg/www.cor...d5e0cb6d04.jpg Monster LT1-R Clutch. Installed this on the previous build and loved it! Will be reusing it as it is still in great shape with only 2,000 miles. https://cimg0.ibsrv.net/gimg/www.cor...77edf11470.jpg Picked up some 315/40/18 Nitto NTO5R in hopes of being able to get some sort of traction. I plan on doing a 15in conversion later on. https://cimg2.ibsrv.net/gimg/www.cor...5f118d0573.jpg |
Good hunting with the new build, and thanks for mentioning this shop. I live just up 515 near Jasper, and have been running a C5R block based 427 with an F1C Procharger for a few years that needs some updating. I'll take a ride over there to see what they recommend.
Originally Posted by marco383
(Post 1591966333)
Nice build man. It'll be a blast!!!
Speaking from experience, I hope you plan on upgrading to a C6Z rear soon. I ran a 6060 with a c5 diff and still broke 2 diff cases. Lucky enough it didn't damage the trans. No issues since going c6Z diff. |
Cool build! Keep us posted with how things turn out!
Originally Posted by CamminC5
(Post 1591967451)
Originally Posted by MVP'S ZO6
(Post 1591967979)
Lots going on there...but how many similar vehicles are running 190+ in the half with only 1000hp ?
I think it'll take a lot more. |
Originally Posted by stevieturbo
(Post 1591968288)
I think it'll take a lot more. I believe it will come down to what gears I run. With the stock 3.42 gears I believe I'm going to be in the mid to high 180's. If I switched to a 3.15 that should put me in the 190-195mph range. But again I could be wrong. |
Looking at results from recent events...it looks like 1000hp is getting people into the low 180mph range
At a guess maybe another 2-300hp or so to get into the 190+ range |
nice! really curious to hear your thoughts on how the tr6060 is compared to the t56. I'm on a built stageV RPM Built t56 and will likely upgrade to some zr1 geared tr6060 at some point.
Sounds good! Good luck with the build! On a base 2200 with your setup, I would expect 165-175mph. Should make 800-850rwhp on boost. Good luck!
(Post 1591968288)
If you search some of the Wannagofast results pages and then google the various cars, 1200hp seems about right just to get into the 190's for something like a Vette.
Nice build!
The Wanna go fast VA event is awesome but the altitude will hurt you a bit. I was only making 12 psi when I normally make 15 I had some issues and broke a half shaft there but only got 154. In comparison I ran the omega 1/2 last year in may ( running it again this year) and ran 168 with C5Z gearing (same set up as wanna go fast). I make 715rwhp/605rwtq. I am running again this year with same power but just put in a gforce/RPM t56 with C6Z 1-4 and Zr1 5th and 6th. I hope for 170+. You should be 180ish but I'm not sure in that altitude. |
Originally Posted by neverstop
(Post 1591971427)
Originally Posted by winters97gt
(Post 1591971540)
Originally Posted by PEETYZ
(Post 1591972825)
Nice build!
The Wanna go fast VA event is awesome but the altitude will hurt you a bit. I was only making 12 psi when I normally make 15 I had some issues and broke a half shaft there but only got 154. In comparison I ran the omega 1/2 last year in may ( running it again this year) and ran 168 with C5Z gearing (same set up as wanna go fast). I make 715rwhp/605rwtq. I am running again this year with same power but just put in a gforce/RPM t56 with C6Z 1-4 and Zr1 5th and 6th. I hope for 170+. You should be 180ish but I'm not sure in that altitude. I only run 2 half mile events which are the GA and FL wannagofast events. I'm not sure on either ones altitude though. With my last setup we ran 161.98 making 676 on 12lbs of boost and shifting into 5th about 150-200 feet out from the finish. My biggest problem is staying out of 5th gear. In order to do that i need to go to a lower gear. Are you going to the May event in Ga or the Omega event? |
Thanks! I will be going to the Omega in May and Wanna go fast in October (Indiana)
You should be good at the GA event. The VA one is on top of a mountain. Great views but not the best DA. When I hit 168 on stock C5Z trans ratio I was pretty deep into 5th on a 27 inch tire with stock rear gear. You will still be in 5th crossing the trap now but with longer gears you will be in the boost longer before and should build more speed. 4th is 1 to 1 ratio in all the manual transmissions so it will depend on your rear end and tire size to go faster in 4th. you will be doing 160ish at the top of 4th |
Originally Posted by Atrain59
(Post 1591980532)
With my last setup we ran 161.98 making 676 on 12lbs of boost and shifting into 5th about 150-200 feet out from the finish. My biggest problem is staying out of 5th gear. In order to do that i need to go to a lower gear. Are you going to the May event in Ga or the Omega event? I guess they do so as traction is easier that way. I'm done around 150mph at the 1/4 on an airfield in 4th ( heavier and less aero than a vette ) and when racing 1km, 5th will take me anywhere I need to go. It does 194mph in 1km in 5th and about 183mph at the 1/2. Without better traction I doubt it would do much better, as it starts spinning the wheels a little again around the 1/2 as car must start to lift a bit. I've the standard old T56 with the 0.74 and 0.5 5th and 6th. Makes 5th ideal for speeds and still a nice lazy 6th for cruising. I'd think the car would be terrible to drive if it was geared to hit 200mph in 4th ! |
1000-1100RWHP I truly feel is what is needed in a PERFECT SETTING in a corvette to hit 190mph in the half. Unfortunately, every runway I have been to is slick so applying the power in a RWD car is easier said than done(why we see 1300rwhp cars doing 190-200mph in the half). It depends on the track,...last few I went to have been in Florida...and it's always slick. I have been in relatively low powered cars,...all hitting 5th gear well before the traps. Georgia, seems to have the higher top speeds that I have seen, and better track surface. Best wishes on your venture, goals. I'll be rooting for you!
Nice build, let us know how you do.
It's been a busy couple weeks with moving and work but I finally made it to the shop and found that the motor had arrived and was in the process of being installed. Here is a few pics, nothing to crazy.
https://cimg8.ibsrv.net/gimg/www.cor...d5355bcb21.jpg https://cimg3.ibsrv.net/gimg/www.cor...c9087518ba.jpg https://cimg4.ibsrv.net/gimg/www.cor...c1f7d64cc5.jpg One of my favorite cars at the shop! Motor, Twins and a Powerglide. Making 1100+rwhp on 18lbs :D https://cimg7.ibsrv.net/gimg/www.cor...94ffb6599e.jpg https://cimg3.ibsrv.net/gimg/www.cor...96dd8dd8f6.jpg |
