FS: 2008 2LT LS3 widebody, coilovers, z06 brakes 162k miles $17,500
Before I return the car to stock to sell it I figured I would put it here first. This car has 90% highway miles between Dallas/Houston/Austin. Never seen a track or a drag strip. It is a two owner car purchased from a family member with 40k (Florida- so no salt or snow), clean title. I never intended to sell this car (evidently as I did not keep any of the original parts) but my priorities have changed and I need to exchange it for something with four doors. It is two tone cobalt red leather interior.
RPO Option codes and VIN # https://cimg8.ibsrv.net/gimg/www.cor...3780a30bf7.jpg https://cimg2.ibsrv.net/gimg/www.cor...6dea67ed11.jpg AG2 Adjuster Passenger Seat Power, Multi-Directional AJ7 Restraint System Seat, Inflatable, Driver and Passenger, Front and Side AL0 Sensor Indicator Inflatable Restraint, Front Passenger/Child Presence Detector AQ9 Seat Front Bucket, Passenger, Driver, Recliner BGR Plant Code Bowling Green, KY, USA BS1 Insulation Acoustical Package CF7 Roof Hatch, Removable, Non-Transparent CJ2 HVAC System Air Conditioner Front, Automatic Temperature Control, Auxiliary Temperature Control DD0 Mirror Outside Left and Right, Remote Control, Electric, Heated Light Sensitive DD8 Mirror Inside Rearview Light Sensitive D42 Shade Rear Compartment E2C Order to Delivery Expedite to Customer C6 Corvette RPO Codes FE2 Suspension System Ride, Handling F55 Chassis Continuously Variable Real Time Damping Magneto Rheological C6 Corvette RPO Codes GU6 Axle Rear 3.42 Ratio C6 Corvette RPO Codes IL3 Trim Interior Design (L3) JJA PT Dress Subassembly Installed (Modular Optimization Method Only) JL5 Control Manual Transmission, First to Fourth Gear Skip Shift J55 Brake System Heavy Duty K63 Generator 110 amp LS3 Engine Gas, 8 Cylinder, 6.2L, SFI, Aluminum, HO, GM MM6 Transmission Manual 6 Speed, Tremec, 85mm, 2.66 1st, 0.50 6th, O/D MN6 Merchandised Transmission Manual 6 Speed Provisions NE1 Certification Emission, Geographically Restricted Registration for Vehicles Up to 14,000 lbs GVW (Use 2003 Model Year) NK4 Steering Wheel Sport Leather NPP Exhaust System Performance NU5 Emission System California, Bin 4 QG6 Wheel 18 x 8.5 Front and 19 x 10 Rear, Aluminum, Styled UE1 Communication System Vehicle, G.P.S. 1 US3 Antenna Diversity US8 Radio AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock ETR, MP3, RDS U2K Digital Audio System S-Band U52 Cluster Instrument, Electronic U66 Speaker System 7, Custom VA5 Language Label English VDD Vehicle Information DVD, Customer Orientation VH9 Envelope Owner Information Manual VK3 License Plate Front, Front Mounting Package VT7 Owners Manual English Language 02I Interior Trim Cobalt Red (04) 023 Trim Combination Leather, Cobalt Red (3) (05) 1SZ Discount Option Package 2LT Package LT Option 2 41U Primary Color Exterior, Black (02) All maintenance completed with OEM or better parts. I have receipts for the majority of the work. All fluids flushed annually, oil change always done on time, ranger clutch method done every week. Fluid is always 100% clear. THIS IS NOT AN EXHAUSTIVE LIST and does not include things like tires batteries etc Kooks 1 7/8 in. headers and Chuck CoW tune done at 50k miles 80k Clutch master cylinder replaced w/tick adjustable 80k LS7 Clutch assembly 90k Belt tensioner pulley replaced OEM 90k Idler pulley replaced OEM 100k Infamous leaking gas tank - Tank replaced OEM, New z06 fuel pump $$$ 100k Water pump replaced 100k Thermostat replaced 100k Spark plugs 110k Starter replaced 110k High flow cats deleted Added mild to wild controller and NPP adjustable collars. Car has never failed TX inspection (Tagged this month 4/2016) 120k Coolant T fitting failure - replaced with brass 120k Driver window regulator replaced 120k PWM Fan connector melted - bypassed connector with hardwires 120k Internal baffle NPP muffler cracked - replaced muffler 120k Full set of wheel hubs 120k DRL bulbs replaced 120k Horn replaced 120k OEM Widebody installed w/ rims and z06 brake kit 120k F55 shocks leaking - replaced with LG GT2 Coilovers. F55 wiring and modules left intact - just de tuned via Tech II to get rid of error message. Can be re-enabled with just new shocks and leaf spring. 120k Dr. Front Control arm replaced 140k Sway bar end links 140k Differential whine - replaced with a brand new unit from GM 140k Involved in a very minor side swipe accident courtesy of an uninsured motorist. Minor as in panels were scratched but not cracked. No other damage. Driver's side quarter panel, fender, and front bumper now have a flawless coat of paint on them. 140k Alternator replaced 140k Harmonic balancer replaced OEM The car has plenty of aftermarket additions: Pioneer App Radio 4 w/ complete stereo - 5 channel amp behind seat, 10' subwoofer in cubby, rockford fosgate components - rear view camera MGW Shifter w/ race knob 2012 leather steering wheel w/red stitching Grand Sport widebody z06 brake kit LG GT2 Coilovers - These were adjusted, checked out by LG themselves in Plano a few months ago. Kooks 1 7/8 headers Vitesse Throttle Controller Transparent top (There is a hairline crack pictured) Full length ron fellows spoiler wrapped gloss carbon fiber. Installed with tape, NOT drilled into panel. Hardwired dash camera and passport escort radar detector 3M 25% tint sides and 10% rear hatch The bad: Driver's seat has wear as would be expected from 160k. Both seats have the seat foam rebuild kits in them. There is a few inches on the driver's door that got scuffed from hitting my garage wall. Pictured. Otherwise the paint is in exceptional condition. Nothing but microfiber ever touches the car and you wouldn't believe it has 160k miles. There are no fuel rail covers. I took them off to clean the engine and they ended up getting damaged where I left them. Never bought new ones. The transparent top has a hairline crack in it. It does not leak. The plastic can be replaced for a few hundred dollars. All of the hardware is intact. It is otherwise flawless. There is a small dent in the passenger side speaker grill from a now-ex girlfriend. There are arm rests on the door panels because I spent so much time driving with my elbow resting on the pad that it actually put a small crease which turned into a crack on the driver's side. The pads cover it up. The headlights have crazing consistent with 160k highway miles The door buttons started to show wear so I covered them in the same glossy vinyl that the spoiler is wrapped in There is wear to the driver's side Corvette plate on the bottom of the door The HVAC buttons are chipping There is some minor deterioration of the rear view mirror. Only noticeable if looking for it There are two rock chips on the hood that can be touched up. 345 / 285 Nitto Invo's need to be replaced soon. Have maybe 30% life left. One of the rims has some damage that was touched up. Other's have very minor nicks that I filled with black sharpie. Sometimes the driver door sticks. May need a new door latch in the future or a pad cleaning There is a tiny rock chip in the windshield. I have had it for 100k+ miles and it didn't spread I don't expect to recoup much from the aftermarket stuff - my price considering the mileage mainly reflects the widebody and z06 brake kit. Pictures are as the car sits APRIL 22, 2016. Mileage will go up slightly as I drive it. This car is ready to go another 100k with minor maintenance. Everything major has already been taken care of. The car / engine bay is pretty dirty. It had just finished a 250 mi. drive when the pictures were taken. I can be reached by text or call at https://cimg2.ibsrv.net/gimg/www.cor...0140b87704.jpg https://cimg4.ibsrv.net/gimg/www.cor...c2fc37dd85.jpg https://cimg7.ibsrv.net/gimg/www.cor...62fef2cdf2.jpg https://cimg2.ibsrv.net/gimg/www.cor...8ce2bde879.jpg https://cimg3.ibsrv.net/gimg/www.cor...f02a729969.jpg https://cimg4.ibsrv.net/gimg/www.cor...feeddc5459.jpg https://cimg6.ibsrv.net/gimg/www.cor...35e9e4417f.jpg https://cimg7.ibsrv.net/gimg/www.cor...d667e40ec6.jpg https://cimg8.ibsrv.net/gimg/www.cor...2781d60bc0.jpg https://cimg9.ibsrv.net/gimg/www.cor...5650b9f854.jpg https://cimg0.ibsrv.net/gimg/www.cor...4e55b7c78b.jpg https://cimg3.ibsrv.net/gimg/www.cor...7a73d77ac4.jpg https://cimg5.ibsrv.net/gimg/www.cor...b0ded37334.jpg https://cimg7.ibsrv.net/gimg/www.cor...14004ea692.jpg https://cimg9.ibsrv.net/gimg/www.cor...98b667f996.jpg https://cimg1.ibsrv.net/gimg/www.cor...8e92f153ea.jpg https://cimg3.ibsrv.net/gimg/www.cor...4b26a225fc.jpg https://cimg5.ibsrv.net/gimg/www.cor...dfd67cbf48.jpg https://cimg9.ibsrv.net/gimg/www.cor...01177c8582.jpg https://cimg1.ibsrv.net/gimg/www.cor...af5e61f3f2.jpg https://cimg5.ibsrv.net/gimg/www.cor...e8d62ec68e.jpg https://cimg8.ibsrv.net/gimg/www.cor...bf31db150e.jpg https://cimg1.ibsrv.net/gimg/www.cor...9374c69bff.jpg https://cimg4.ibsrv.net/gimg/www.cor...7daa608f2d.jpg https://cimg8.ibsrv.net/gimg/www.cor...b67a6f6b45.jpg https://cimg1.ibsrv.net/gimg/www.cor...e4a52e3658.jpg |
sent you a text this morning, Im in DFW area and want to check the car out
Nice car! I'm glad you have enjoyed it, put some miles on it, and kept up the maintenance! :cheers:
Car is sold. Sorry to those I wasn't able to respond to
