Left turn signal on instrument cluster is not working but turn signals still work
Left turn signal on my instrument cluster is not working but turn signals are still working? Right one works fine on the gauge cluster but the left one just will not come on.
Will this fix my issue or am I needing to look elsewhere? https://www.corvetteenvy.com/collect...-flash-harness Also what is the factory part that could fix this as well? I have a GM hook up, so I might just go that route. |
:iagree: the link you provided is for preventing hyper flash when led lights are installed.
It is most likely the bulb. They are removable and you can install another. No soldering required. Just need to remove the IPC.
Let us know if you need all the DIY info. Mr. Sam |
Originally Posted by dadaroo
(Post 1592096224)
I remember when it was a 10 minute job to replace a dash bulb. Just reach up behind, pull out the old and put in the new. I also remember when you could see the engine under the hood!
I agree, all my other cars are just that simple.
Mr. Sam |
Thanks guys, and yes 10 minutes would have been nice.
Forgot to tell you what type bulb you need to use. I have that info at home. It just mounts into the plastic holder. Very obvious once you remove the holder. Lefty loosey to remove it.
Mr. Sam |
