Vin
Hello everybody,
I own a 1989 Z51 with manual trans mission. I am trying to find out what the cars original paint color was. What number or letter in the code tells me the color. 1g1yy2182k5125141. Thank you Joe |
None of the above. There is a RPO sticker that list all options and colors for the car. I think for your year it's under one of the storage bins
Check under the center console lid or the passenger side storage compartment lid. If the SPID sticker (also called the RPO sticker) is there, look at the very bottom line. There will be a 6-digit code that starts with "WA". Post that number.
You may want to pull back a section of carpet and look for overspray. The body shell was painted before any interior parts were installed. |
Originally Posted by c4cruiser
(Post 1592121547)
You may want to pull back a section of carpet and look for overspray. The body shell was painted before any interior parts were installed. Base Coat/Clear coat WA L9567 U9567 212 Thank you |
your car was or is white exterior with blue leather interior
Originally Posted by jseremba
(Post 1592121973)
On the RPO sticker in the center console it says
Base Coat/Clear coat WA L9567 U9567 212 Thank you L9567 = Lower - White U9567 = Upper - White 212 is interior = Blue |
Originally Posted by RollaMo-LT4
(Post 1592122288)
White exterior with Blue interior
L9567 = Lower - White U9567 = Upper - White 212 is interior = Blue Thank you. It is still white. The car needs paint I am stripping all of the paint off. There are some body repairs and some peeling paint. And the hood looked like it was black paint underneath the tan/yellow coating. So I was wondering if it was black at one time. Thank you. Stripping it is so tough. I was using Citristrip with some success. But, it is 50 degrees her in NJ and the Citristrip needs at least 70 degrees to work. Once again thank you |
The underhood paint done at the factory is a semi-flat black. Just use a single-stage paint.
(Post 1592128624)
