Logan176 |
05-02-2016 08:40 PM |
Holley carb choke issue... fuel hit the ceiling!
I'm not going to lie. I almost crapped myself when fuel shot out of my carb and reached the ceiling in my garage today. So... I kinda need some help again. I will most likely misname some parts as I explain this, but I'll detail as much as possible.
The choke on my Holley carb has not been hooked up since I took ownership of my 72 convertible several years ago. I learned that I was missing the link that goes from the choke pull-off to the fast idle cam cage, so I went to install it today.
The first thing that I thought was weird (but perhaps normal) was that the choke cam (yellowish plastic piece) prevented the lever between the two parts of the cage from dropping, which did not allow the flap on top of the carb to close. But once I pressed the gas pedal, the lever (attached to the throttle shaft) moved and the flap closed, so this didn't seem like an issue.
Once the flap dropped as I was pumping the gas, I fired up the car. It idled for a few seconds and then cut off. I thought it was strange that the flap immediately flung wide open and did not stay closed. I thought the flap was supposed to stay closed until the engine was warm enough. The car had not been running and the outside temp was only about 60 degrees. I also noticed that when the flap was open, the spring on the choke pull-off was compressed all the way, as if it was not strong enough to push the lever and keep the flap closed.
I tried turning over the engine a couple more times, but it cut off both times after only a few seconds. Then, I tried giving it a little more gas after the engine turned over. This time the engine began idling high (1,500 rpm). This seemed strange since I have the idle set to 1,000 rpm (which I know is higher than usual) because the car tends to stall out on cold mornings with the choke not functioning. I let the engine run for about 5 minutes.
When I saw that the idle was not dropping (it actually climbed to 1,700) I turned the key to cut the engine. The engine sounded like it didn't want to turn off. It stuttered for a few seconds and that's when a stream of fuel shot out of the top of the carb and hit a joist 7 feet above the garage floor! It looked like someone pulled the trigger on a Super Soaker with a bad nozzle. By the time I jumped out of my car and bolted out of the garage, the engine cut off.
I have seen a much smaller amount of gas spray out of the carb on a couple occasions when the air filter was removed and I was turning the engine off. But I had never seen anything like this before. Needless to say I require a little help before I set my car on fire. I have no idea what the hell happened. I will take whatever advice you guys can give.
I am attaching a pic of my carb so you can see what I did.
https://cimg8.ibsrv.net/gimg/www.cor...ac625112aa.jpg
