Transmission failure warning signs?
I apologize for (possibly) using the wrong terms ...
This evening on the way home from work, a strange thing happened ... I was coming to a stop for a red light, foot gently applying the brake (my personal style, coast up to the stops) ... the car was nearly stopped, then it jumped ... and came to a stop. Just a glitch? Random? It startled me. I had visions of sudden acceleration syndrome. :hide: The only transmission failures I've encountered were in previous cars, and the car would completely lose the gear and fall into neutral. This is a lot of fun at 75 mph. (Not). Thoughts? I know the advice will be "Wait and see if it happens again." :lol: ETA The C6 has less than 40,000 miles on it. |
I've never heard of this kind of surging on any LS engine.
Wait and see if it happens again. ;) |
What year is it?
2007
Originally Posted by the kid C6
(Post 1592130405)
(Post 1592130405)
I am a long way away from being an expert. However, what you are describing sounds a lot like happened to my previous car, a 2008 Jaguar XK. When coming to a stop, it was like someone bumped me from the back. The Jag dealer said it was a small part in the transmission that needed to be replaced. They fixed it as the car was under warranty. The problem went away for a week or two and came back. I brought the car back to the dealer and it turned out there was a common fault in Jag XK transmissions. This time the factory paid the dealership to rebuild the transmission and the problem disappeared for good.
I hope this gives you insight to what may be the problem. You may get lucky and find that it some small part in the transmission that needs replacing. |
If it's an A6 trans, were you in Auto mode or using the paddles?
Your lurching/jumping problem has been reported before. Here are some threads;
https://www.corvetteforum.com/forums...lete-stop.html https://www.corvetteforum.com/forums...-shifters.html https://www.corvetteforum.com/forums...in-the-a6.html Some report it as normal and others say not so much. Keep us posted on what you find. |
Mines done it from time to time....esp when its not warmed up yet. Never seemed to be an issue and its never gotten any worse. I'm kinda just thinking its a little glitch in the A-6 programming. At least I hope anyway !!!
I'm not sure about the C-6, but my C-3 driveshaft slip joint needed grease. It would stick than release with a jolt. Worth looking in to.
Thank you for all the replies!
I read the previous topics, and my problem wasn't that severe. It didn't feel like someone bumped my car, it wasn't that hard. However, I will be paying a lot more attention, as I only have a few months remaining on the warranty. To answer some questions, it's an automatic transmission, and I wasn't using the paddle shifters. When I say coasting up to the stop light, that's the way I drive. I see a red light, lift off the accelerator, and roll a bit before applying the brake (as opposed to the way some folks accelerate all the way until they use their brakes. I've often thought a brake shop would be a profitable business.) |
(Post 1592137252)
(Post 1592137252)
