Dyno run
Finally got a dyno run on a new tune and was surprised, was told should be 410 to 425 not 443.
http://i804.photobucket.com/albums/y...psvetzvuwb.jpg |
Badass! Video would be nice:D
Details on car and parts would help explain.
Advanced Induction ported LT1 heads and cam, Melrose headers, AFR hydra rev, Jessel shaft rockers, Coyles dual roller timing set, ewp, 58mm TB, ported intake, Ford 30# injectors
When you going to bring it out to Richmond Dragway. Friday nights are street car nights.
http://richmonddragway.com/ver9/wp-c...page-001-1.jpg |
On a dynojet it'll read more. Impressive. That's more than my built 350 with NOS.
Very impressive for a 350!
Hard to see the graph, what was the TQ and max RPM? Size of cam, and CFM of heads? |
Dyno run
Hard to see the graph, what was the TQ and max RPM? Size of cam, and CFM of heads? Cam is 565 lift 280 advertised duration and 110 sep angle. Not sure of head flow, they are AI 200's, may still have it on their site, think it is 280 or 285 with the 565 lift. Still have to work on fuel at under 4K as still a little rich, but that is better than the opposite. |
:cool:
So ah .. ya think it will spin the tires ???
That's awesome. Sure would like to see a what that set up would do with AFR 195. Basically to help me decide on what heads to buy.
Sure looks like you can't go wrong with the AI heads though. |
:lol:
Originally Posted by Amotoxracer
(Post 1592166291)
How long was the turnaround on the heads?
I assume stock bottom end? |
I assume stock bottom end? If you are thinking about it give them a call as timing is everything. One thing to point out this is on a mail order tune from pcm for less. |
Damn, stock bottom end:cool:
Are these SAE corrected #s or Standard correction?
This was measured at the crank or rear wheels? 443 by 5900?
Originally Posted by blue94
(Post 1592166592)
