Need Carpet replaced...
The carpet is about completely ruined. Need to install heat shield and new floor mats or carpets. What's the best way to do this from a novice's perspective. (low budget) Kim
Carpet replacement
Originally Posted by Kim Moulton Miller
(Post 1592300876)
Hey morning, As long as you do not mind taking a day to strictly do it. You would have to remove the seats, door sills, and l loosing up the center console so that you could move it and then put it all back. Strip the carpet out, shopvac it completely out, wipe it down with like scrub sponge of sorts with soapy water to clean anything like dirt and such out. Let it dry, choose your best budget heat/sound barrier (several to choose from at not bad prices), but get enough to cover the floor completely and the back behind the seats. Note - some come already with adhesive on them others you have to spray, and you have to cut it to fit. Lay the new carpet in with spray adhesive with something to hold it in shape of applied area to keep its form wait a couple of hours and replace the components that you pulled from the car (seat, sills, center console). Not bad job mostly time consuming. You can do it all under $500 easy. Just do not know your budget. |
Moving from Parts For Sale/Wanted classifieds to General discussion area.
Originally Posted by SFCC3
(Post 1592301435)
Hey morning,
Originally Posted by Vettebuyer6369
(Post 1592301482)
:cheers:
What I did,
http://www.vettenuts.net/ C3 Corvette Pre Cut Insulation Kit I only did the front floors up to the rear of the seats. Didn't do the doors either. Get the Carpet from http://willcoxcorvette.com/ Your choice on the floor mats. I bought mine from http://www.ecklerscorvette.com/ The 89.99 dollar ones. As you take things apart place the screws in a bag and label them. That way you know what goes were. Also take pictures 1st as you take it apart. http://i1235.photobucket.com/albums/...psrkttug6y.jpg http://i1235.photobucket.com/albums/...psl7tpxqhh.jpg http://i1235.photobucket.com/albums/...psgp2oe741.jpg |
Got it! Saved your suggestions, too!!
Thanks guys! |
Not sure how much you want to spend on floor insulation, but I went to the Heating/ducting department at lowes and bought a couple roles of the Reflex duct insulation from them.
http://www.lowes.com/pd_409814-56291...insulation#img Workes perfectly and is cheap too. Ken |
Check out this article on California Stingrays web site:
http://www.californiastingrays.us/Articles/TonyGriffitts/Carpet.html :thumbs: |
w/ken home depot sells its too. Cheap light and works
pick up a can of 3m spray adhesive while youre there While not cheap Lloyds mats makes some real nice ones good coverage little thicker/plush Havent been in a C3 forever but some insulation /heat barrier on the firewall/tunnel over the ex most important to keep the heat off your feets. Theres a vendor in C4 gen that sells some interesting lightweight sound deadener looks like it actually does something, most doesnt. Sells it in sheets Pretty much any dense roll of foam will help.Not a fan of jute collects moisture too easy but youre not hosing your interior down so- Did put some up in the roof of my Abody with 3m spray Wow what a difference cant even hear rain hit it. tap it with your finger just a solid thud. |
You will regret it if you don't install the hushmat or Amazon knock-off derivative as I did). It makes a minor difference in a C3's noise, vibration and harshness. Buy a roll of foil tape when you buy the roll of Reflectix and seal the Reflectic to the floor. Be sure to use a double layer of Reflectix which is virtually identical to the thickness of the original (and smelly) jute backing that you'll scrape off, first. The quieting effect was amazing and unexpected on my car. Even the door closing sounds more solid, let alone the much more muffled sounds/rattles when driving on rough roads.
Lots of good suggestions..I'm printing them all! Will post when this project takes place...will be a while I'm sure.....rebuilding the engine and transmission wiped me out!
Originally Posted by Lakeside49
(Post 1592309176)
Originally Posted by ddawson
(Post 1592302710)
What I did,
http://www.vettenuts.net/ C3 Corvette Pre Cut Insulation Kit I only did the front floors up to the rear of the seats. Didn't do the doors either. Get the Carpet from http://willcoxcorvette.com/ Your choice on the floor mats. I bought mine from http://www.ecklerscorvette.com/ The 89.99 dollar ones. As you take things apart place the screws in a bag and label them. That way you know what goes were. Also take pictures 1st as you take it apart. Carpet is on sale this weekend too.. ;) https://www.corvetteforum.com/forums...e-savings.html Willcox |
The hardest part I found was the rear compartment area. Oh and something sharp and, heavy duty to cut with
I am just about to finish my carpet replacement... put in a thin foil insulation in the front area of the foot well and tunnel and added a complete cloth-felt-insulation (1/4" thick Max.) in the entire interior. Carpet trimming is a bit more difficult but worth the effort. I ordered the cut pile carpet from ACC!
Good luck! Cheers... René |
I used ACC carpet as well.
Some real good scissors (I used Zwilling kitchen shears) are best for the trimming. I used no thermal or sound barrier, and only glued the bulkhead section of carpet. Do some real good cleaning while you got the interior and old carpet out. Not a hard job, and very rewarding once completed. Carter |
