What Vacuum Hose is this ?? (See Pic)
1 Attachment(s)
Opened hood and heard loud Hissing noise for about a week. Finally noticed it was coming from the hose below. What effect would this Vacuum hose have ? Thx🙏!
Not sure but it might be for the blend door of the hvac system.
Check if yours will switch from floor, dash and defrost vents. |
Exhaust valves
^^^This. It's the vacuum supply to the NPP vacuum tank. NPP may or may not work depending how bad the leak is.
Thank you guys! Now my next question....I have a Bassani Exhaust with no use for these vacuum lines.
Does this Vacuum now act as a vacuum leak since this hasn't been capped?? If so, should I pull fuses for exhaust AND capped these lines? |
Cap the line at a convenient place and move on. Vacuum leaks are bad.:thumbs:
Originally Posted by cclive
(Post 1592318949)
