Reminder to clean your inline Meth filter...
Hey Guys, I was having an issue with my pump/controller, and Julio asked me when the last time I cleaned my inline brass mesh filter, let's just say I was over due...
It was pretty clogged, used a freakin pressure washer to clean it, all good!! The car really likes Meth, even if it goes just a bit rich, you can feel the TQ! Went for a VERY long Canyon run yesterday, 100 degrees out on some of the ride. After almost 3 straight hours of driving, not a single glitch, she ran like a champ!! :thumbs: __________________ |
o_O
I had no idea there was one. Cleaning mine tomorrow! |
Originally Posted by Chrisrokc
o_O
Thanks for the heads up.
What does it get clogged with ?
Any sort of dirt that got into the tank or came from the jug you had the alcohol in
Where is it usually located, and what does it look like?
It is a big brass piece that'll be somewhere in line between the pump and where it'll go into the charge pipe.
Originally Posted by skull
(Post 1592365767)
I personally think it took out my last pump... |
Originally Posted by jbsblownc5
(Post 1592365860)
Thanks for jumping in, and yes it can get pretty clogged over time...
Originally Posted by a/c man
(Post 1592376002)
may be my problem any pictures.
(Post 1592384788)
I'll take one tomorrow, but just follow the line back from your nozzle until you come to the filter, it's got to be tween the pump and the nozzels...
(Post 1592391069)
I just thought it was a check valve? no pic needed now thanks! Mine goes on and off never sprays every time just replaced the pump its the same.....
most likely your afr are super lean
Originally Posted by Dave concrete
(Post 1592391154)
How did you realize it wasn't spraying?
(Post 1592391398)
no green light and lean...
Most of the cheap kits only turn the light green when the pump is commanded so you can not tell from the light if your line is clogged.
So the only way to tell is to see if afr goes lean or if you have a flow indicator in the line. |
Checked mine today after almost 10 years spotless. Not even a dot of anything. Not sure if it's the use of the washer tank, or only using VP meth
(Post 1592421744)
That's why I was wondering what on earth is clogging them ! |
