Help with build...have a look!
Thanks for looking! This is kinda lengthy so bear with me. I've owned my 2006 Z for a year and I'm ready to build. It's a 90k mile weekend beater, and aside from cosmetics it's bone stock. I've posted little but read religiously on this forum, 6 months ago I had it all figured out, problem is the more I read and gather info, the more I 2nd guess the correct mods I'm after....the one consistent thing I see asked is "what are your goals"....well that's easy, it's not a 405 pro-mod...but an absolute street monster with no other vocabulary but Murder every time something/someone pulls up beside me! I really don't have a set hp goal, but I won't be running any 1 mile events, and have serious doubts of any 1/2 mile events either. Now 1/4 mile runs? Absolutely! Keep in mind that this is/will be a 95% street car, with some 1/4 mi track runs just a few times a year for kicks. So supporting mods are fairly common and are as follows:
Halltech 103 (or 108) MSD/NW102 (mamofied) ARH 1 7/8 with X + cats What I'm struggling with: Heads- wcch,ahp,mamo,other???? Cam- ???? (insert here) I've read the K501 builds, listened to all Torquer 110 & 116 clips, and have vip access to youtube for all the vids I've watched, from VR to Hennessey to Livernois........ Im ready to pinpoint a proven, can't miss package that hits it outta the park, because I can only afford to swing once! I will add that im in NW TN, so by whom said package will be tuned by is TBD, the install i will do myself. I appreciate your time, I'll hang up & listen. |
Go with Tony Mamo's TFS heads, and have him spec a cam for you.
Originally Posted by 5hunnit5-C6Z
(Post 1592362538)
Originally Posted by RGT
(Post 1592362656)
Originally Posted by ZilverZ06
(Post 1592362782)
It all depends on what you're driving style is. Are you looking for a daily driver street car? I had the opportunity to drive cars with different cams. For me, the Katech Torquer 116 fit my needs. Great stock like drivability and power. You're going to get different opinions based on each different needs. At the end of the day, you will need to decide on what is best for you:cheers:
(Post 1592362538)
I learned LONG AGO with fast cars there is always somebody faster and with more HP than you. Its a losing battle. With the parts you have laid out 550-600whp is attainable for certain. Just pick your cam. For a 95% street car, go with a smaller cam that will be a torque monster. I did a BTR stage 2 and I am over 450 ft. lbs. of torque by 3500 rpm, over 500 by 4500 rpm and dont drop below 450 ft. lbs until 6500rpm. If you are looking at doing ported heads(dont just get them fixed, get them ported and polished and milled .030 provided you have 93 octane fuel), a ported manifold and NW102, get the Halltech 108, skip the 103. You want all the airflow you can get. |
Originally Posted by rjacobs
(Post 1592364118)
Good luck.
if you have 93 mill the heads .030. Supposedly its worth 30whp(10 per .010 you mill), again supposedly from what I read on here. AHP did my heads and, I dont want to put words in Kohle's mouth, but he said something along the lines of "if you only have 91, mill .020, but if you have 93, mill .030. We recommend this to everybody as its a big gain". Something along those lines. I would guess WCCH would recommend similar, although I never talked to them.
Local guy has a bigger cam than I do, but no head milling or P&P and he is down 30whp from me(with other mods being "similar"). If he gets his heads milled and P&P I bet he will pick up 40-50whp due to his cam specs. As far as the BTR Stage 2, im VERY happy with mine. Here was my build thread so you can see my mods. https://www.corvetteforum.com/forums...hp-510wtq.html Ive got a ported FAST manifold/NW102/FIC 60lb injectors sitting in my living room waiting to go on and im hoping to pick up 20-30 whp/wtq with the combo. With what you are talking about above dont forget injectors as you will max out your factory injectors with all the air flow. |
(Post 1592364248)
(Post 1592364324)
Injectors is not something I've considered, but will certainly heed the advice of tuner when the time comes.
With what you are talking about doing(pending your final cam choice, port work, milling, etc..) my guess is you will also run the risk of running out of injector too. I did not get injectors right off the bat due to talking with the other local guy who has a build similar to mine(save for all my head work) and he was at mid 80's on his IDC(think he said 85%). So with my heads flowing a ton more air the fuel needs went up a bit. I am roughly 30whp more than him which is around 5% more whp, and im using roughly 7% more IDC. Now a lot of that depends on the tune and I dont know what his tuner targets for AFR, I believe I am slightly rich at ~12:1 at WOT, his tuner might target 12.3-12.5(seems to be more common) so slightly leaner. |
(Post 1592364448)
Now a lot of that depends on the tune.
You say NW Tennessee. Brian Tooley is just outside of Louisville. Probably 3 hour drive from you. Otherwise up in to southern St. Louis at CBI Street Cars. Beyond that, no clue. There has to be a few shops in Memphis or Nashville that are decent.
(Post 1592364682)
(Post 1592362656)
Email sent to Tony Mamo, awaiting response to see what the offerings are.
(Post 1592364448)
With that build as it sits today(without the manifold and throttle body) I was at 92% IDC, which is to high IMO.
Originally Posted by rio95
(Post 1592368801)
If u go with a larger cam he's probably right. I have a very similar setup, except mamo fast with stock TB, and I'm at 92% duty with stock injectors. I don't seem to have a problem being at 92% but I wouldn't puah them much farther. Oh and I'm running on the richer side at 0.85 lambda. LS7s like fuel and need it to keep the #7 cylinder in one piece in my opinion.
My build was done at Redline and it is insane and a track monster. Nothing crazy but heres the list.
2011 zo6 w/ 20,000miles : MSD intake Trick flow heads out of the box! Torquer 110 GM race lifters C5R TC TC damper ARH 1 7/8 no cats, stock mufflers stock TB ATI damper balancer Redline tuned Car is a completely different car, very reliable, fast as hell. 565 RWHP and 528 rwtq. I am not a drag racer I do HPDE. I am not looking for 1/10ths. I am looking for torque everywhere and my car now hangs with the best of them reliably. |
Originally Posted by seamus2154
(Post 1592369025)
2011 zo6 w/ 20,000miles : MSD intake Trick flow heads out of the box! Torquer 110 GM race lifters C5R TC TC damper ARH 1 7/8 no cats, stock mufflers stock TB ATI damper balancer Redline tuned Car is a completely different car, very reliable, fast as hell. 565 RWHP. I am not a drag racer I do HPDE. I am not looking for 1/10ths. I am looking for torque everywhere and my car now hangs with the best of them reliably. |
(Post 1592369025)
2011 zo6 w/ 20,000miles : MSD intake Trick flow heads out of the box! Torquer 110 GM race lifters C5R TC TC damper ARH 1 7/8 no cats, stock mufflers stock TB ATI damper balancer Redline tuned Car is a completely different car, very reliable, fast as hell. 565 RWHP and 528 rwtq. I am not a drag racer I do HPDE. I am not looking for 1/10ths. I am looking for torque everywhere and my car now hangs with the best of them reliably. Ran 10.50's at 130+ at the drag strip too :thumbs: |
