Gulstrand Eng.
FIRST posting so please be gentle, been following you guys for years but was more interested in "listening than talking"
Has anybody successfully communicated with Gulstrand since Dick passed away? I've talked to "Kevin" and "Phil" but neither follows up on requests for parts info. Website won't load past Homepage for me. Thanks, John Special thanks to Rex (Dr L-88) for all his help and the great headers. |
Can't help with your question, but welcome to the forum. We have some first class people here who are very knowledgeable and willing to help.
Bet you get your answer pretty quickly! |
I know Phil Roche, but I haven't spoken with him for awhile.
I'll see if I can reach him tomorrow and see if there's a problem. |
There is generally nothing left!
First most here don't consider me as one of the first class members! But oh well! :D
I tried to help Kevin organize what was there and see if it was possible to continue the parts line, but that didn't go so good, not enough left to continue, it was just scraps! The Porsche guy at the former shop location did a number on Dick! He had toe adjusters, no bolts, or no lube thru bolts He had Bump Steer blocks small hole, no bolts He had the tapered machine pieces for the front sway bars, but you would have to source everything else! But those are the important piece He had various Heim Rods and some misc heim ends, but nothing labeled with part numbers He has two front spring sets, not marked as to which ones He had some concentrically drilled upper a-arm bushings No lowers No ball joints No sway bars No kits of any type No 5 link parts No trailing arms No brake stuff No rear springs No half shafts Etc etc etc It is pretty bleak!!!!!! Having a catalog would do you no good, as nothing left was numbered to the catalog! The parts bins numbered differently (inventory numbers) 90+ percent of those empty! I even suggested they keep like one of whatever they could find, but they were willing to sell me the very last one that existed of many of the items that were still there! I shot pictures of how bad it is! I bought basically from Dick what was left that was worthwhile, which wasn't much! That was a few weeks before he died and that was a sad visit in many ways! He just gave me some things, being a long term friend and customer! Therefore I might have been his last parts customer! And then I visited with Kevin a few times and picked up a few more of the scraps and went through every box! |
Thanks it's a shame to think that all that old school engineering could be lost for good.
The only thing really not available are the toe adjusters & 5 link stuff
Originally Posted by jpcarter48
(Post 1592417864)
Duntov Motors has bushings Global West are really good bushings, not concentrically drilled! No one has the real old heavy duty adjustable ball joints, except me and I use precision four bolt Howards You can get the springs from many outfits You can buy lube or channeled bolts with zerks You can get offset trailing arms from Van Steel and others You can buy big block parts and upgrade some things that way, as his Catalog used much of that, like the latter relay rods! The bump steer block came originally from Vette Brakes You can buy a strut rod brace of a heavier duty reinforced from Global West or Toms a Differential! Someone should be able to assemble a heim set up sway bar You can buy a Daytona or F41 rear spring and shorten one The long rear suspension bolts could be made or found! The rear trailing arm spherical a were crap, ask me why I know!!! Other cool things had left his Catalog a long time ago! HD idler arm go get a Vette Brakes unit! I never liked his shock combinations with his springs! The Bilsteins just weren't ever right and the cheaper Monroes weren't any.better than the red generic Konis single adjusts! The custom lugs haven't been offered since the 80s And on and on! If I missed something you wanted, let me know and I probably know who markets such! I not only have enough Guldstrand components to freshen up my three cars, but I also own everything and more of all of the stuff I just mentioned! The loss is the 5 links, but he told me that he has only sold in all of the years about 50 sets! I feel I could easily make one, since I have two to pattern off of! |
(Post 1592409902)
Has anybody successfully communicated with Gulstrand since Dick passed away? I've talked to "Kevin" and "Phil" but neither follows up on requests for parts info. Website won't load past Homepage for me. Thanks, John |
Originally Posted by TCracingCA
(Post 1592418273)
If I describe where I saw those, I bet Kevin can get you a set!
Duntov Motors has bushings Global West are really good, not concentrically drilled! No one has the real old heavy duty adjustable ones, except me and I use precision four bolt Howards You can get the springs from many outfits You can buy lube or channeled bolts with zerks You can get offset trailing arms from Van Steel and others You can buy big block parts and upgrade some things that way, as his Catalog used much of that, like the latter relay rods! The bump steer block came originally from Vette Brakes You can buy a strut rod brace of a heavier duty reinforced from Global West or Toms a Differential! Someone should be able to assemble a heim set up sway bar You can buy a Daytona or F41 rear spring and shorten one The long rear suspension bolts could be made or found! The rear trailing arm spherical a were crap, ask me why I know!!! Other cool things had left his Catalog a long time ago! HD idler arm go get a Vette Brakes unit! I never liked his shock combinations with his springs! The Bilsteins just weren't ever right and the cheaper Monroes were any.better than the red generic Konis single adjusts! The custom lugs haven't been offered since the 80s And on and on! If I missed something you wanted, let me know and I probably know who markets such! I not only have enough Guldstrand components to freshen up my three cars, but I also own everything and more of all of the stuff I just mentioned! The loss is the 5 links, but he told me that he has only sold in all of the years about 50 sets! I feel I could easily make one, since I have two to pattern off of! |
It is actually kind of the culture out here
Originally Posted by jimgessner
(Post 1592421073)
Thank you Derek. Some day, Dick's engineering will get recognized. I pleaded with him in the 80's to get better organized. He was a great person, but terrible business man.
Only people like the Edlebrocks and similar took it to these big greed empires ! Dick Guldstrand was very recognized! I probably am the only guy with all of his catalogs! And know what he offered year to year! It is fact that some of the cool items were available in the early 70s! I probably singularly have more purchases than anyone else, playing with 3 Camaros, 5 Corvettes that got Guldstrand sold goods! Here are most of the earlier catalogs and I have the latter ones and some others with the same covers like the early brown one, but maybe some changes of the pages year to year! Appears that he usually did a new catalog every year and a half or two or like on three I pictured the ink color of the covers was changed! http://i65.tinypic.com/3sttx.jpg |
