Originally Posted by 60 SHARK
(Post 1593853388)
look at maybe the fuel pump rod that drives it from the cam, my 68 427 made a lifter noise and it turned out to be fuel pump related, just another idea,,,
First thing I would do is check the oil pressure next time you run this again. Your vacuum gauge is telling me it's not exhaust and neither is the slight cylinder not firing on the throttle tip in. . IF you have oil pressure I'd be looking at a split rocker arm on the fulcrum providing the rest of the obvious stuff up top checks out. Again just my $.02 |
7 Attachment(s)
Ok, I pulled the valve covers and inspected the rocker arms, pushrods, springs etc and did not find anything obviously wrong. Only some minor scoring/pitting on some of the rocker arm studs. I tried pushing down on each lifter to see if possibly they had a collapsed/broken spring and they all felt good tome. My next move is to pull the intake so I can pull the lifters to give them a better inspection, I also want to check the lifter bores to eliminate that. The attached pictures of the rocker arm and valve spring are representative of all of them.
That sound is definitely a clatter of sorts and it sounds like it has a small misfire. I'd definitely inspect the cam lobes, sounds like it may have a lobe going away.
You're going the right direction on your troubleshooting. |
5 Attachment(s)
Well I just finished inspecting the lifters and cam lobes, I did not see anything obvious. I checked a few of the feet of the lifters with the rocking test, two lifters foot to foot and verify they rock a bit, and they checked out all right. All the lifter bores looked good and the lifters were tight in them and all the pushrods were straight. I've attached some pictures of the cam so if you see something amiss chime in. While I had the rocker arms all loosened I poured some sea-foam into the intake side of the head to test the valves and they held overnight.
With nothing obviously wrong I guess I'll just leave it as is, the only other thing I could imagine it would be is something in the heads but they appear to be good. I've got it all back together now and I'll wait till a break in the weather here in the PNW so I can pull it out and give her a tune up. |
Why are the lifter footprints so far off of center ? It looks like the cam has walked to the back of the block...
https://cimg8.ibsrv.net/gimg/www.cor...6e0ef38a38.jpg Look at the third lifter where it meets the cam lobe ......or the left (first) lifter angle..... |
Originally Posted by Ryan Menzies
(Post 1593890588)
The above lifter positioning is normal and is done to encourage lifter rotation and prevent wear. The quote below is from Crower.
" The offset between the lobes and lifters aids lifter rotation and distributes valve spring loading over a wide area of the lobes and lifters assuring longer life. But most important, this off-set design, combined with tapered lobes and spherical lifter faces, is a specific cure for the greatest cause of cam lobe failure-edge loading." |
Check for exhaust leaks at the AIR ports, looks like the holes are plugged with pipe plugs.
when I first heard your video it sounded like an exhaust leak to me
1 thing for sure - your AIR exhaust ports are plugged with pipe plugs which are 27 threads per inch, the holes are tapped with 1/2"-20 NF which is 20 threads per inch. Get you some 1/2"-20NF x 3/4" socket head set screws in there and use a bit of high temp sealer.
Sounds to me like the timing chain is rubbing......the noise is not staccato like a lifter or rocker arm.....
Jebby |
Originally Posted by Jebbysan
(Post 1593897693)
Jebby |
Originally Posted by Big2Bird
(Post 1593897714)
Did those engines use the Nylon POS sprockets?
I would pull the cover and have a look..... Jebby |
(Post 1593897714)
http://i21.photobucket.com/albums/b2...psb8078ae1.jpg |
Originally Posted by CanadaGrant
(Post 1593897906)
They sure did. Here's mine after about 45 years of use. Kind of scary...
(Post 1593897979)
73 or so I worked the back of a Chevron station. I must have changed out 1 of those a month. They get real ugly when the teeth shatter and shred all over the pan. 454 pass side manifolds liked to crack as well.:lol:
My neighbor back in the 70's had a 71 454. He came home from work one day and decided to wash it including the motor. He sprayed the hot engine with the hose and promptly broke/ cracked both exhaust manifolds.:crazy: |
(Post 1593897693)
Jebby I know what CanadaGrant is saying and the theory makes sense and yes they run a taper or what have you but in my eyes, this cam is more than what's was engineered into it. That lobe on the left actually looks like the lifter is cocked...really bad unless it's a shadow. More tear down by the looks of it to find out. |
(Post 1593897893)
I believe so...the hyd 390/400 was just a passenger car engine....but it stands to reason that somebody would have changed it out when they changed the cam......but it is a consistent sound.......
I would pull the cover and have a look..... Jebby you make it sound like the 390-400 was a joke |
Likely nothing with the noise....but in that pic with the one rocker off...are all the rocker nuts in the normal running position? Because if they are we've got a pushrod length/valve height/rocker geometry issue going on too. Those nuts are way out past the end of the stud.
JIM |
Originally Posted by LT-1 kid
(Post 1593899525)
they were all passenger hi pro blocks and shared many parts,
you make it sound like the 390-400 was a joke I call it how I see it. Jebby |
