Successful Retrofit of Bluetooth to 2007 c6 Corvette
Hello All,
I would like to report that I have successfully retrofitted my 2007 c6 Corvette with OEM bluetooth capability. Thanks to this forum, and most notably, Lee Cromwell, Kent1999, Ray Kawal, and Dcasole for their input, suggestions, and comprehensive posts, I was able to research, disseminate the information, and proceed with my retrofit in a more confident manner. So, anyone out there still thinking that it can't be done, well I'm here to tell you that it can be done, provided that you have the correct parts. You will need a 2007+ clockspring, 2011-13 Nav radio, SWC (audio and bluetooth), and the most important, and difficult to find, 2009+ OnStar module with bluetooth (thanks Kent1999). Now GM may make the OnStar bluetooth module for other vehicles that might work in the Corvette, but that I don't know that for sure. I was lucky enough to find a unit out of a 2010 Corvette z06. The wire harness plugs were the same, (thank God), and no dealer reprogramming was necessary. Also, on the SWC, make sure, if you are retrofitting those controls into your current steering wheel, (like I did), you have the controls with the 5 pin connections on them (thanks Lee Cromwell). I also installed the center console with USB and Aux ports. You may not need to have the center console installed to have Bluetooth, but since I was upgrading my radio, I wanted to have the feature of iPod control and optional connectivity for any source of media I chose to listen to. As Ray Kawal mentioned in his posting about the newer Nav radios interface being better than previous Nav radios, he was truly correct! I love being able to search, and control my iPod while seeing the song information readily. The only thing I have left to upgrade is the A-pillar microphone. On the calls that I have made from the car so far, people have said they can hear me clearly with the current 2007 microphone. But, since I have the upgrade bug, I will change it to the newer model microphone soon. Good luck to anyone wanting to do this mod. You will enjoy it, and the best part is that it is all OEM! |
That is good news since I also have a 2007 and already added a 2012 Nav (and center console). You say a 2007+ clock spring? Does that mean you just kept using your original clock spring? Thanks!
Originally Posted by 07MontyRed
(Post 1592468215)
Thanks for the good info.
Good to know! I was thinking it might work with pre-2009 cars --- good job stepping up and trying it!
:thumbs: |
Originally Posted by Kent1999
(Post 1592471411)
:thumbs: Glad my posts helped Dave |
Awesome job! I know I'll soon follow your footsteps! I know the challenges you faced but you pushed through! Great job!
Lee |
I wonder if you still need the on star module of you've changed out the radio to aftermarket and running a programmable steering wheel control module with it
I was wondering if you can use a 2009 system with Bluetooth or does it have to be 2011 or newer, I have found a 2009 with Bluetooth, I was told it did.
Thanks |
Originally Posted by glamis.man
(Post 1592481352)
Thanks The Bluetooth is in the onstar unit so any VCM that has blue tooth will work , the only issue is if you use Onstar they will think that your car is the donor car as there is no way to change it in their system There are a few guys that can reprogram it to your car but for me it was not worth it I was lucky and found one that was out of a red 2011 coupe ..what's the chances of that happening lol lol Dave |
(Post 1592471411)
:thumbs: |
Originally Posted by 1FUNC5
(Post 1592475630)
(Post 1592481352)
Thanks |
Originally Posted by Dcasole
(Post 1592481381)
What system are you talking about, the onstar VCM or your head unit
Originally Posted by Lee Cromwell
(Post 1592475158)
Lee |
Originally Posted by ben dover
(Post 1592468449)
Originally Posted by 0Sevnvette
(Post 1592482059)
Thank you. Let me know when I can be of service to you. I'm always glad to help out fellow Corvette enthusiasts. My motto is to always pay it forward. When information is gained, it should be shared, not sat upon....
:iagree: |
Can you provide what your total cost came to in adding the integrated OEM BT functionality? I too have an 07 and have slightly lamented that it doesn't have BT.... but frankly, when I'm driving, talking on the phone is one of the last things on my mind. I would like to play my music from smartphone though.
So knowing approximately what your cost came to would be helpful in making a decision on moving fwd... or just enjoying the rig "as-is" with the Sirius/XM radio. |
(Post 1592481381)
The Bluetooth is in the onstar unit so any VCM that has blue tooth will work , the only issue is if you use Onstar they will think that your car is the donor car as there is no way to change it in their system There are a few guys that can reprogram it to your car but for me it was not worth it I was lucky and found one that was out of a red 2011 coupe ..what's the chances of that happening lol lol Dave I don't use the onstar. Thanks |
(Post 1592482020)
If you have a 2009 OEM Nav radio, I am pretty sure the 2009 bluetooth OnStar module should work. MAKE SURE, it has the bluetooth symbol on the unit before you purchase it. I believe that is the year bluetooth became available for the Corvette. However, if you wanted to have iPod control, or the ability to listen to any other media device, with a 2009 Nav radio, you will have to install a gateway of some type to listen to optional music sources.
Thanks |
