2008 TPMS don't work on 2010's...True or False?
Recently got some new wheels and tires as a complete set with TPMS installed from an 08 base c6. Since I own a 2010 base c6 I figured they systems should be able to pair right up. At the very least since I have the newer vehicle there would be some type of backward compatibility to them. I could understand if its from a newer car to an older car. I've done a bit of research and its possible that I'm not reading it correctly but apparently 2010 was the only whacky year for TPMS where the system is different from 2005-2009 and the 2011-2013 models. I've also gone to 2 different tire shops to have them paired up to DIC before I began doing some research and neither of the two were successful. I was told it was also possible that they are damaged or dead but to have all 4 sensors fail both times seems a little unlikely to me. If anyone can point me in the right direction or shed some light on whats going on with these TPMS I'd appreciate it.
2010 uses a different sensor.
2005 to 2009 p/n 25758220 2010 to 2013 p/n 15268606 |
2010 sensor will not work with earlier year C6s.
Originally Posted by 01Z06 Black
(Post 1592482630)
2005 to 2009 p/n 25758220 2010 to 2013 p/n 15268606 On a side note if anyone is interested in 2005-2009 tpms let me know hahaha |
Originally Posted by ihealy16
(Post 1592484552)
Appreciate the info! I'll hunt down these parts and get them swapped out...
Originally Posted by Funky
(Post 1592484806)
How much shipped to 33991?
(Post 1592484552)
