Anyone spraying an MSD intake with a 102mm plate? Come inside
Just ordered a ported MSD intake to sit atop my forged piston ls7. Swapping from an OEM intake, TB and a 90mm plate to the MSD, nw102 and a 102 plate. Going to be bumping the shot up from a 150 to a 200 pill.
Looking to see how much people are spraying through the front and how the plugs look distribution wise. I guess the MSD runners are a bit more in the path of the opening than the FAST so I was to curious to see if that's impeding flow in any way. Probably reading more into this than needed but I'd love to hear some results. |
Well I'm not going to say it won't make a difference, but the fast is very similar in design with the runners and that's been a non issue, I'm about to do the same thing spraying a 200-250 through a plate on a MSD intake as well.
Originally Posted by inspector12
(Post 1592495280)
Bump for anyone that has some result
Sub for info.
:thumbs: |
sub'd
Doing the same thing. In the process of putting forged 12:1 pistons and ARP hardware into the short block. Running a Mamo'd MSD, NW102, and E85...planning on a 200-250 shot using a plate system. |
No problem with the plate kits but for bigger shots we recommend the Direct Port.
Let me know if I can help anybody out with a kit. http://i253.photobucket.com/albums/h...psszxizi6h.jpg |
Originally Posted by NitrousExpress
(Post 1592587921)
Let me know if I can help anybody out with a kit. http://i253.photobucket.com/albums/h...psszxizi6h.jpg What is the turn around time from the time you guys receive the intake? |
Originally Posted by Da Z06
(Post 1592588414)
Could you PM me a cost for a single stage direct port similar of what is depicted on the pic?
will do. What is the turn around time from the time you guys receive the intake? |
(Post 1592589469)
1 week or less
Bumping this. Have my ported MSD sitting in the house waiting to go on. Anyone with some feedback from a plate kit?
Couldn't fit a plate on there with an EWP so I'm trying a dry nozzle setup but not finished yet.
(Post 1593298564)
Originally Posted by ajrothm
(Post 1593299980)
What you putting this on? The old camaro?:cool:
Direct port is the only way to go when talking 200+ shot. Running a standalone fuel system is also suggested. I have seen successful use of the plate on the MSD at 200 shot. Bolt it on and get with a good tuner. Learn how to read spark plugs.
Originally Posted by User Omega
(Post 1593306199)
(Post 1593309696)
I generally agree with the DP but Absolutely no room for me, without making some major changes. But I am doing a dry shot so I won't have any issues. And yeah if your doing a wet kit a standalone is nice cause you can put C16 in it when your spraying the house down. I'll be running E85 so not a big concern for me.
1 Attachment(s)
(Post 1593311086)
Interesting plan for a 250 shot. Dry you say? Are you just going to run dual tunes? What fuel system/injectors are you planning on running?
I'm a flexfuel car now, and with the LNC-2000, I'll only need my one tune to run NA E54 with spray.
