What short thrower shifter do you recommend for your c5
Im thinking about installing a short thrower shifter in my c5 and need some advice! Is hinson the way to go? Is it worth installing or just keep it stock?
MGW, Hinson, Kirban... take your pick all seem to be liked by whoever gets them...:cheers: I got a C6 Z06 and love it.. it isn't short throw but a great improvement...
MGW is awesome:thumbs:
The latest generation MGW with their lower box is a great setup!
http://i29.photobucket.com/albums/c2...pseqdgoun6.jpg |
from what I understand I have the older generation MGW, and its a huge improvement over the stock shifter
Very precise shifts, sort of just "clicks" into place, shorter throws..I like it |
I have a hurst and think it is probably the shi&$?@$? Shifter I have ever owned. Others may like them but I don't like the way it feels.
FrankLP i like that set up a lot! How was the install?
I have a Hurst and while I think it's over fiddly and notchy, that 2-3 shift is better than sex.
Originally Posted by FrankLP
(Post 1592515530)
(Post 1592515530)
:steering:....Kirban here, I have had this shifter for 12 years and it still works great, plus, I bought it new/used !! I can't say whether one shifter excels over the other, but almost any aftermarket short shifter is light years better than a stock one !!!...:cheers:
* Side note - Drove my friends 02' Z06 last week with the factory shifter, I thought I was trying out for the next row boat olympic trials !!!!!!! |
After reviewing all the opinions I ordered an MGW for my car last night.
People here seem to love the mgw. People here also seem to love chrome tail light louvers.
If you see where that's going, you know to take advice on things such as shifters/appearance mods with a grain of salt. I, for one, like a ahifter that is really stiff. Almost too stiff for an average person to shift. C6 didn't do it for me, hurst didn't do it for me, rsd didn't do it for me. Ended up with a B&M and it's perfect. If someone gets in my car the first thing they say is "holy crap this shifter is stiff" but it's exactly what I want. Good luck, enjoy your mgw |
Originally Posted by Studda07
(Post 1592517644)
Originally Posted by danh52
(Post 1592518551)
Did you orient the shifter in the 12 o'clock position or the 6 o'clock position? Assuming you have the latest version with the offset stick.
It was certainly supposed to be the latest version; ordered it last February and it came with the lower box, but I honestly will have to check when I have time to tear it apart again. |
You can spend anything from hundreds of dollars to $50 to get short shifting. First, you need to decided how much more shift effort you want - physics 1.01 tells us half the shift travel = twice the shift effort. Then what you want it to look like, and how much you want to spend.
I and quite a few others run the economy solution - a cut down C5 shifter, Cut down as in shorter lever and shorter throws. You need a new knob, say $30-40 and a $10 die to extend the thread. Oh, and a hacksaw. |
Originally Posted by dbgoodwin
(Post 1592520181)
(Post 1592520962)
That's actually a good question! IIRC I installed it at the 6 o'clock position, but now that you have me thinking about it, I'm wondering if I received the offset stick.
It was certainly supposed to be the latest version; ordered it last February and it came with the lower box, but I honestly will have to check when I have time to tear it apart again. If your stick is round stainless steel (which it appears to be in your picture), it is the standard C5/C6 stick. There IS no offset stainless steel stick that I'm aware of. HTH |
Also whatever you do, don't listen to the guys who tell you "you wasted your money on a short shifter, the slop is in the transmission not the shifter. Stock shifter is just as fast as a short shifter."
They don't fully understand physics, or understand that a short shifter is about feel, not actual speed. That said, anyone in NC have an MGW? A curious soul wants to give it a try :rofl: |
