*Comp Trunnion Replacement... LONG POST/LOTS OF PICS*
a lot of us are familiar with the bad design of the stock ls trunnions and the benefits of replacing them... years ago I had replaced mine with a set of comp trunnions and thought I would never have to worry about them again, I had even recommended them to many people... granted at that time they were the only ones offered and now you can get them from brian tooley and straub technologies and possibly other companies I am unaware of... the ones from btr are nearly identical in design to comp, they both use a sealed needle bearing to support the trunnion... the kit from straub is different in that it uses a bushing rather than needle bearings to support the trunnion and also has a flat machined into the tops of each trunnion that provide a passage for oil... this is where the design flaw is in the comp and btr kits, there isn't a clear passage for oil to lubricate the needle bearings and over time the trunnion begins to wear prematurely... I want to thank LoneStarFRC for bringing this to my attention in a thread from a week or so ago... after looking through the link he posted about comp's trunnions wearing prematurely I decided that I didn't even want to take the risk with mine, I was just going to replace them no question... a good friend of mine named Bret (blownbluez06 on the forum) happened to have the straub kits in stock so I visited him earlier today and picked up a kit... I also figured since I was already there I might as well get some bigger pushrods due to the increased cylinder pressures on my car... I went with manton 11/32" diameter .120" wall thickness pushrods, to my knowledge these are the biggest that will fit stock heads... I originally wanted to go with 3/8" .135" wall thickness rods until I found out I would have to remove the heads and open them up in order for those to clear, I'm not going through that so the mantons are a good medium between 5/16" and 3/8" pushrods... they are 10% thicker in diameter and 50% thicker wall thickness than the 5/16" .080" chromoly pushrods I had in the car... the guys at manton are awesome, they had my pushrods out the same day and I got them the following day just like they promised... ok enough rambling, here's some pics:D
the straub trunnion kit http://i164.photobucket.com/albums/u...702_161027.jpg here you can see a clearer shot of the machined flat that supplies oil to the bushings http://i164.photobucket.com/albums/u...702_161054.jpg the bushings and snap rings http://i164.photobucket.com/albums/u...702_161116.jpg manton pushrods http://i164.photobucket.com/albums/u...702_161330.jpg http://i164.photobucket.com/albums/u...702_161202.jpg side by side comparison of the mantons (on the right) next to my old 5/16" chromolys... the mantons are also 3 piece, the ends are made separate from the body http://i164.photobucket.com/albums/u...702_201605.jpg the mantons also have a smaller hole for better oil control http://i164.photobucket.com/albums/u...702_201649.jpg passenger side rockers with comp trunnions and 5/16 pushrods before removal http://i164.photobucket.com/albums/u...702_181627.jpg passenger side rockers and pushrods removed http://i164.photobucket.com/albums/u...702_183346.jpg driver side before removal http://i164.photobucket.com/albums/u...702_184351.jpg closer shot of driver side http://i164.photobucket.com/albums/u...702_184406.jpg driver side after removal http://i164.photobucket.com/albums/u...702_185613.jpg at this point I only have it disassembled... as time permits I still need to press out the old comp trunnions, install the straub trunnions, and reassemble everything... I will update this post as things progress... sorry for the lengthy post but hopefully it will be helpful to other members and if anyone has anything to contribute please feel free, after all if it wasn't for me hijacking another thread I might have never known about the issue with comp trunnions to begin with:lol: |
Pretty sure you'll like those puppies. Easy installation, just same as the Comps.
Nice pushrods as well........:thumbs: Be sure to post up some pics of your Comp trunnions when you get them removed. In particular, the underside, as that's where the needle bearings exert the greatest pressure. Vehicles with higher open-spring pressures are more susceptible to the excessive trunnion wear that I've seen. My springs are in the 460-480lb range. Btw, speaking of pushrods, Smith Bros are also now distributors for the Straub RA upgrade kits. Seems they like them as well. http://www.pushrods.net/trunnion.html |
Manton is just a couple of miles away so I picked mine up from the shop. They do nice work.
I picked up a set of 11/32"/.120" wall like yours with LS7 lifter preload for my setup with HS roller rockers. http://i131.photobucket.com/albums/p...psopkgsonc.jpg http://i131.photobucket.com/albums/p...pswwkvmds2.jpg Got a free t-shirt :D http://i131.photobucket.com/albums/p...psqiuvlahm.jpg |
that's funny, I had noticed that they were in the same city as you when I was looking for their info:lol:... I will definitely be posting pics of the findings of my comp trunnions as soon I get them apart, I'm going to try to get that done tomorrow or Monday hopefully... I'm using pac 1518 beehives so the pressures aren't as high as yours and my cam is quite a bit under .600 lift, I'm not sure if the added cylinder pressure could cause more stress on the rocker trunnions but if it can make pushrods deflect then I don't see why not
From what I have been reading, the bushed bearings (Straub) are quieter than the needle bearings. Also, the larger pushrods are an excellent upgrade. Not sure if you plan any dyno time but I found that my 3/8 double tapers (thread on this here LINK ) smoothed out the dyno curve above 6K RPM.
I called Manton several years back about the 11/32" pushrods. Terry actually called me back from his car and made me one special purpose pushrod that could be easily disassembled so I could play with the length when setting up my engine. Super nice guy, great company and excellent customer service. Be interested on your thoughts/feedback once its together again and running. |
I'm VERY interested in what you find, when you press the Comp trunions out of you rockers. I, too, installed the Comp kit 3-4 years ago, and thought it would be the "end all" fix, at least for the reasonably easy driving that my car sees. I will say, however, that the bushing kit that CHE was offering, back then, was tempting. Their price of $400 (installed in my rocker arms), as well as the "down time" of my car, while the work was done, turned me off, however.
EDIT...........when I had mine apart, I installed a set of Manley pushrods. |
Originally Posted by vettenuts
(Post 1592552359)
Originally Posted by leadfoot4
(Post 1592552452)
EDIT...........when I had mine apart, I installed a set of Manley pushrods. http://i164.photobucket.com/albums/u...703_130624.jpg some close up shots of the damage http://i164.photobucket.com/albums/u...703_130757.jpg http://i164.photobucket.com/albums/u...703_130808.jpg http://i164.photobucket.com/albums/u...703_130817.jpg http://i164.photobucket.com/albums/u...703_130826.jpg close up of the new straub trunnions installed http://i164.photobucket.com/albums/u...703_140616.jpg http://i164.photobucket.com/albums/u...703_140625.jpg my only minor gripe about the straub kit, they should include these small washers... it makes the install super easy, luckily I held onto these when I installed the comps years ago http://i164.photobucket.com/albums/u...703_140653.jpg everything is ready to go back in but I'm not so sure about this, the comp trunnions have a recessed area where the bolt goes and the straubs are just flattened out... I don't have the original rocker bolts anymore and it looks like the comp bolts are about 2-3 threads shorter than what they should be when installed... stock bolts show to be 52.5mm long according to a parts catalog and the comps are about 45mm long below the head... I might have to find me a new set of bolts http://i164.photobucket.com/albums/u...703_135900.jpg |
Nice job documenting your work Neutron82... looks like this might wind up being another STICKY for the tech section.... keep up the good work :thumbs:
What did the needle bearings look like? They have to show some pretty bad wear as well as the trunions... glad you are getting those out before something serious went down :eek: Some of your pics should definitely be in the C5 vette porn section...those trunions are too pretty to install |
thanks:thumbs:... I didn't get any close up shots of the needle bearings but I still have all the comp parts in my toolbox at work, I can get some next time I'm up there... they are really small though so it might be hard to see but I'm sure they are worn
(Post 1592556343)
http://i164.photobucket.com/albums/u...703_130757.jpg http://i164.photobucket.com/albums/u...703_130808.jpg http://i164.photobucket.com/albums/u...703_130817.jpg http://i164.photobucket.com/albums/u...703_130826.jpg Hell, even the factory OE pieces don't have the needles riding directly on the trunnion body. :ack: I wound up reusing my OE r/a bolts. They work fine. Glad to see you got this taken care of. |
Originally Posted by LoneStarFRC
(Post 1592557685)
You were well on your way to complete trunnion failure, not to mention the slowly eroding metal being eaten away from the trunnions, and entering your engine oil. Ungood. Mine were worn a bit more than yours after 14K miles.
If I remember correctly, the first few mm of the stock bolts are not threaded, so the actual engaged thread length may be the same.
https://cimg7.ibsrv.net/gimg/www.cor...e21dfa4461.jpg |
(Post 1592556343)
...........everything is ready to go back in but I'm not so sure about this, the comp trunnions have a recessed area where the bolt goes and the straubs are just flattened out... I don't have the original rocker bolts anymore and it looks like the comp bolts are about 2-3 threads shorter than what they should be when installed... stock bolts show to be 52.5mm long according to a parts catalog and the comps are about 45mm long below the head... I might have to find me a new set of bolts
http://i164.photobucket.com/albums/u...703_135900.jpg Great pictures! HOWEVER, now I'm concerned that my trunnions might look the same!! FWIW, and if it helps you at all, I just measured the length of the OE rocker arm bolts from just underneath the "shoulder" of the bolt, to the tip at it's end. It came out at 2.065"......basically 2 and a sixteenth. (I'm a pack-rat, I kept my OE bolts in my "bolt bin", "just in case I ever needed them for something"....) :cheers: |
You got my attention for sure. I just installed the BTR trunion upgrade in my car when I did the cam job. What did the trunion and pushrod set up cost you?
What valve springs are you using and do you know the difference of the spring load over stock if you are using other than stock ????? Do you think extra valve spring pressure has a bearing on the wear of the trunnion assembly if your not using stock springs ??? What rpm's do you run ??? Thanks !!
(Post 1592558044)
Originally Posted by SuperVetteC5
(Post 1592558619)
Originally Posted by akapounder
(Post 1592558939)
My stock bolts are rounded just like the pic that VetteNuts showed. Mine are out of a 2004
(Post 1592559975)
Crapola! Guess I'll be pulling my Comps to take a look. Did you happen to give Comp a call?
How's the weight of the manton push rods? |
Originally Posted by Rx7Rob
(Post 1592560356)
