TTS Data Master no longer supports GM vehicles
About 2 weeks ago I tried to install TTS Datamaster on my Windows 10 computer. After spending the better part of a day discovered Windows 10 doesn't work. So I found another computer on eBay that arrived today with Windows 7, while installing Datamaster got the message that it was no longer supporting GM vehicles.:rock:
Any other programs that work for data logging a 93 LT1? :cheers: |
1 Attachment(s)
If it's an LT1, then my app (Scan9495) should work because it also does the 93 F-car LT1. The 93 Y-car has the same data set as an F-car, for which Scan9495 was written. It has several actuators also, but I am not sure those work on a Y-car. It also has ABS and SIR capability, but I haven't checked to see if those Y-car modules are the same as an F-car. It uses the same cable and pc setup as TTS Datamaster. I would be interested to find out how everything works on your car. Best of all, it's completely free!
https://www.mediafire.com/folder/gon...-LT1-V8_folder By the way, Datamaster does work on Windows 10. But you would have to install an old version that only has 30 uses. I do have some information about using an even older version (3.4?) that runs on XP only and that can be made to give unlimited use. |
Originally Posted by GaryDoug
(Post 1592713902)
https://www.mediafire.com/folder/gon...-LT1-V8_folder By the way, Datamaster does work on Windows 10. But you would have to install an old version that only has 30 uses. I do have some information about using an even older version (3.4?) that runs on XP only and that can be made to give unlimited use. Can I use this on a 1992? I clicked on your link-But not sure what to download. I am using Windows 10. Thank you, Steve |
Originally Posted by STEVEN13
(Post 1594056923)
Hello,
Can I use this on a 1992? I clicked on your link-But not sure what to download. I am using Windows 10. Thank you, Steve also get the user guide pdf file If anyone reading this has a pc with Windows XP, this may not work. Win 7 or later only. Download the zip file and extract all files from it. Run the scan9495.exe file. You may get a warning message asking if it's ok to use this file. Select yes anyway. |
(Post 1594057991)
Scan9495 V2-5-1.zip
also get the user guide pdf file If anyone reading this has a pc with Windows XP, this may not work. Win 7 or later only. Download the zip file and extract all files from it. Run the scan9495.exe file. You may get a warning message asking if it's ok to use this file. Select yes anyway. Steve:cheers: |
Sent you an Email.
Right click on Datamaster ICON on desktop and it allows you to run it in Windows 7 compatibility. Version 4.01 is the one I have on my laptop. Works fine.
TunerPro also works as a datalogger. There is ALDLDroid which works on android and uses the definition files from TunerPro..
Both are great solutions |
This presents a pricey but possibly much easier solution to a problem I've been trying to solve. Several of the backlight incandescent bulbs behind the buttons across the bottom have burned out. While I have purchased replacement bulbs (very cheap), I'm not sure I want to chance breaking the pushbuttons while disassembling them, snipping out the burned out bulbs, and soldering in their replacements. If I buy a remanufactured unit for half the original list price, I will have to send mine back to them as a core. Sounds like a good plan to me.
