D3PE C6/ZR1 Ice Tank!
D3PE PROSPEED A2W Ice Tank for C6 Corvette - Use the same tank we run in our builds, from 700-2000+WHP!
Introducing our air to water intercooler trunk mount ice tank for the C6 and ZR1 Corvette platform. This adds approximately 7 gallons of extra fluid capacity while allowing use of ice to bring IATs to sub ambient temperatures! This tank features full .125 aluminum construction complete with precision in house tig welding, cnc cut fittings, large 6.00" lid kit, billet drain valve kit, and an option to include a high flow internal Rule 3700 water pump and components. Works with factory and aftermarket internally cooled superchargers as well as any external air to water intercooler! OPTION 1: Build with 1" Barb, -12AN, or -16AN Inlet/Outlet OPTION 2: Build with 2nd set of Feed/Return Fittings (EXTERNAL PUMP USE ONLY) OPTION 3: Include internally mounted Rule 3700 pump, mount, and wire pass through ** Please call for any other custom options ** ** Requires trimming of carpet and drilling of body for mounting bolts and hoses ** ** Made to order part ** AVAILABLE HERE Standard http://i68.tinypic.com/dczgvq.jpg http://i68.tinypic.com/6jjadw.jpg Dual Inlet/Outlet for External Pump Use http://i68.tinypic.com/1zw2ftg.jpg http://i68.tinypic.com/34jactg.jpg D3 Performance Engineering 832-230-1094 Houston, Tx |
How long does it take to get one of these tanks with Option 1?
Originally Posted by narush
(Post 1593417529)
Originally Posted by D3PE
(Post 1593423836)
We can have one built and ready to ship in a week!
Two calls in and still no calls back to order.:toetap: |
