C3 recommended wheel bearing grease
Hello, I'm replacing my 72 C3 front wheel bearings, what is the recommended gease to be used? Is there a certain spec for it?
I use the valvolene spec for GM vehicles. It's a red grease.
After using Royal Purple grease on my trailers over the years and never having a failure.......I use it on all of my builds......best stuff there is....
Not easy to find. $11-12 a tube.......use it with a Lisle bearing packer..... When I take the trailer bearings out...they look excellent every time. Jebby |
Lucas Red 'N Tacky was recommended to me
It doesnt matter just pick one from your local auto parts store
Thank you all for your feedback. Just wodering to know also what quantity I need to apply after installing new bearings? Fill up all spase or some?
Coastal Uniplex. Been meaning to try the Royal Purple ultra performance. Can't say I agree with the comment to grab whatever's on the shelf at the parts store -- I would avoid Mobil 1 grease for example.
Been using Redline synthetic for years on the fronts/rears. :thumbs:
Lucas red n' tacky is what I use. Bearings look like new after many years.
Originally Posted by Mohamed
(Post 1592726441)
Use a bearing packer (like Lisle), and that's it. A bunch of grease in the cavity won't do anything for you. |
You can go with what was recommended for your car 4-5 decades ago...or you can put good quality synthetic grease in your wheel bearings and have them last a lot longer, never melt out (from heat), and never turn to caked grease.
Lots of lubricating improvements over 40+ years ago. Make use of them. |
Originally Posted by GregS_72
(Post 1592725713)
Same here! |
Originally Posted by 7T1vette
(Post 1592729585)
I use Timken brand grease.
(Post 1592726441)
DUB |
Any name brand, synthetic, high temp wheel bearing grease that is available at your local store.
