Motul/Redline/Castrol Fluids
Hey Guys,
I currently run Motul 600 for regular HPDE track use in my Z51, and I bleed the system often. Can I begin a switch over to 660 by just using it for my regular pre-track session bleeds? In other words, can I mix the two until I have eventually bled all the 600 out, rather than a one time flush/replace? Thanks. JV |
2 Attachment(s)
Originally Posted by Jet Vet
(Post 1593004575)
Hey Guys,
I currently run Motul 600 for regular HPDE track use in my Z51, and I bleed the system often. Can I begin a switch over to 660 by just using it for my regular pre-track session bleeds? In other words, can I mix the two until I have eventually bled all the 600 out, rather than a one time flush/replace? Thanks. JV Attachment 48016535 Attachment 48016536 |
https://www.corvetteforum.com/forums...-motulrace.jpg Motul Oils https://www.corvetteforum.com/forums..._face_0w15.jpg MOTUL 300 V 0W20 CHRONO 2-LITER http://www.xplosiveperformance.com/M...r-_p_4110.html MOTUL 300 V 10W40 CHRONO 2-LITER http://www.xplosiveperformance.com/M...er_p_2642.html MOTUL 300 V 0W15 CHRONO 2-LITER http://www.xplosiveperformance.com/M...r-_p_4112.html MOTUL 300 V 0W40 CHRONO 2-LITER http://www.xplosiveperformance.com/M...r-_p_4111.html MOTUL 300 V POWER 5W40 2-LITER http://www.xplosiveperformance.com/M...er_p_2646.html MOTUL 300 V 5W30 POWER RACING 2-LITER http://www.xplosiveperformance.com/M...er_p_2645.html MOTUL 300 V 15W50 COMPETITION 2-LITER http://www.xplosiveperformance.com/M...er_p_2643.html MOTUL 300 V 0W20 HIGH RPM 2-LITER http://www.xplosiveperformance.com/M...er_p_2641.html MOTUL 300 V 20W60 "LE MANS" 2-LITER http://www.xplosiveperformance.com/M...er_p_2644.html Motul Brake Fluid https://www.corvetteforum.com/forums...rbf600_usa.jpg MOTUL RBF600 http://www.xplosiveperformance.com/M...00-_p_648.html https://www.corvetteforum.com/forums...rbf660_usa.jpg MotulRBF660 http://www.xplosiveperformance.com/M...T4_p_2403.html https://www.corvetteforum.com/forums...-react-srf.jpg CASTROL SRF RACING BRAKE FLUID http://www.xplosiveperformance.com/C...id_p_4091.html Redline Fluids https://www.corvetteforum.com/forums...l-fluids-2.png https://www.corvetteforum.com/forums...-fluids-16.png RED LINE’S SYNTHETIC ENGINE OILS 10WT (0W10) RACE OIL http://www.xplosiveperformance.com/R...Oil_p_921.html RED LINE’S SYNTHETIC ENGINE OILS 20WT (5W20) RACE OIL http://www.xplosiveperformance.com/R...il-_p_922.html RED LINE’S SYNTHETIC ENGINE OILS 40WT (15W40) RACE OIL http://www.xplosiveperformance.com/R...l--_p_924.html RED LINE’S SYNTHETIC ENGINE OILS 50WT (15W50) RACE OIL http://www.xplosiveperformance.com/R...l--_p_925.html RED LINE’S SYNTHETIC ENGINE OILS 30WT (10W30) RACE OIL http://www.xplosiveperformance.com/R...il-_p_923.html RED LINE’S SYNTHETIC ENGINE OILS 5W30 http://www.xplosiveperformance.com/R...W30_p_918.html RED LINES SYNTHETIC ENGINE OILS 10W30 http://www.xplosiveperformance.com/R...W30_p_913.html RED LINE’S SYNTHETIC ENGINE OILS 10W40 http://www.xplosiveperformance.com/R...W40_p_914.html RED LINE’S SYNTHETIC ENGINE OILS 15W50 http://www.xplosiveperformance.com/R...W50_p_915.html RED LINE’S SYNTHETIC MANUAL TRANSMISSION LUBRICANTS MTL 70W80 GL-4 http://www.xplosiveperformance.com/R...4--_p_932.html RED LINE’S SYNTHETIC GEAR OIL 75W90 http://www.xplosiveperformance.com/R...W90_p_926.html |
MOTUL
Pioneers in synthetic lubricants, Motul has developed the300V Motorsport range based on the unique ESTER Core® technology that gives youunrivaled power increase, outstanding lubrication and optimal protection foryour vehicle, creating the perfect conditions for ultimate victory! ESTER CORE® TECHNOLOGY Over several decades, Motul has perfectly mastered thetechnology of esters. Combining this technology with an optimal selection ofhigh performance synthetic base oils, coupled with an innovative additivespackage, gives exceptional synergy. This is the latest Motul technologicalevolution: ESTER Core. Used exclusively in the 300V range, this technologyguarantees to obtain maximal performance, over and beyond existing standards. GUARANTEES YOU MORE: POWER - Reduced internal friction RELIABILITY - High temperature resistance and oil pressurestability PROTECTION - Optimized polarity for maximal adherence of theoil film LOW LUBRICANT CONSUMPTION - Exclusive formulation of lowvolatility synthetic base oils During the ‘dyno test’ 300V Trophy 0W40 showed significantpower increases up to 7.2 HP compared to competitors |
MOTUL
I would like to change my transmission fluid for my C7 M7 with Redline how much do I need? Thanks.
Originally Posted by Xplosive Performance
(Post 1595508885)
