Admin ? Established ?
What does a Established member mean? I want to be able receive and send PM. What are the qualifications ? Do I have to be a donating member ? Thanks
With over 1600 posts, you should be able to PM people.
Might want to post your question in the Help section of the Forum. :thumbs:Unless something is wrong in your profile or some setting, you should certainly be able to send and receive PM's.
Originally Posted by 8VETTE7
(Post 1592954874)
Go to USER CP.
Then go to SETTINGS & Options and then EDIT OPTIONS. Scroll down to Private messages. Ensure Enable Private Messages is checked. The scroll all the way to the bottom and SAVE CHANGES. |
I have the exact same problem...
However, when I try to follow 8VETTE7's directions, I don't have a PM box to check or enable. I hve emailed the administrator, but haven't received any replies yet. Any other suggestions (I realize I am new here) |
Second Try.... Sorry if the 1st one finally shows up...
I have the same problem When I go to CP and Options, I don't have anything to Enable or Check in regards to PM's H E L P !! |
Originally Posted by Daypoblue
(Post 1592955028)
I have the same problem When I go to CP and Options, I don't have anything to Enable or Check in regards to PM's H E L P !! You're just too new. Also to the OP, make sure your message section is cleared from time to time. |
(Post 1592955028)
(Post 1592955005)
Look at the RED bar across the middle of the page. All the way to the left it says USER CP in white letters on that bar....................
(Post 1592954952)
(Post 1592955028)
Originally Posted by feeder82
(Post 1592955164)
if he's looking at the forum on a mobile version you cannot see the tools at the top of the page you need to make changes. you need to go to the full site.
i went to messages (moble devise) inbox found a red bar for " message". It works! Thank you so much. Been away from the forum for awhile things have changed. Great to be back and thanks for your kindness!!! |
Guess that would explain a lot...
Maybe same reason it occasionally won't let me reply to posts as well Any clue If/When I will get that privilege ?? Thanks |
(Post 1592955806)
That makes even more sense. I'll be patiently awaiting someone's blessing !!:lurk:
