Gennsi Projector LED H6054 Headlight review
This is just a quick review of my initial impressions.
Part # GEN-7X6PRO Utilizing authentic CREE XM-L2 LEDs 3x Projector Lens for perfect beam cut-off DOT Approved Street Legal Low beam and High beam in the same light. Durable Aluminum Shell Body and Heatsink 2042 Lumens Low Beam Per Assembly 3180 Lumens High beam Per Assembly Input Voltage from 9V-32V DC Wattage: 32W Waterproof: IP68 UV Resistant with ultra clear polycarbonate lens Die-Cast Aluminum Housing for max heat dissipation Polycarbonate front Lens Lifetime: Up to 50,000 Hours Dimensions: 3" (DEPTH) x 7" (WIDTH) x 6" (HEIGHT) 2.8lbs each Compatible with headlights: H6014 / H6052 / H6054 / 6054 Black Housing as shown Adult Signature Required for Delivery. This cannot be waived. Listing is for one lamp. Please buy 2 if you need a pair. The same light can be used in either side of your vehicle.
I need to get better pics of the cut off. The pic of the cutoff on the garage is really close and doesn't do it justice. These lights great so far. I did the circut doctor mod to retain the function of the factory fog lights. I paid $280 for the pair. The price is starting to fall for the LED plug and play setups. https://cimg2.ibsrv.net/gimg/www.cor...641a53e3f2.jpg https://cimg2.ibsrv.net/gimg/www.cor...fe4600077a.jpg https://cimg0.ibsrv.net/gimg/www.cor...55c921f607.jpg https://cimg9.ibsrv.net/gimg/www.cor...82411c4d80.jpg https://cimg8.ibsrv.net/gimg/www.cor...71c7a9da67.jpg https://cimg7.ibsrv.net/gimg/www.cor...f663c2981f.jpg https://cimg6.ibsrv.net/gimg/www.cor...892f7db032.jpg https://cimg5.ibsrv.net/gimg/www.cor...65b4a094a3.jpg https://cimg4.ibsrv.net/gimg/www.cor...a93c19b33e.jpg https://cimg3.ibsrv.net/gimg/www.cor...7ffe5530e0.jpg |
You will love these
:DMoney well spent
https://cimg6.ibsrv.net/gimg/www.cor...abb1e5a646.jpg https://cimg4.ibsrv.net/gimg/www.cor...00a4c6127c.jpg I love these headlights https://cimg2.ibsrv.net/gimg/www.cor...c7d96c99f2.jpg |
I thought the item should be a 7X5 to replace a H6054
These are the ones I ordered & they just dropped in like the stock ones.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Wow! What a cool headlight option, I love the way they look. Could you explain the 'circuit doctor' mod that you said is needed to keep the factory fog lights?
I didn't do that mod,cause I only use my fog lights when driving with my parking lights on. The lights are so bright they will wash out most fog lights anyway.
Originally Posted by DMITTZ
(Post 1592961817)
These or the night hawks are my next C4 upgrade for sure |
This is the Circuit Doctor method to fixing the foglight issue. The problem with the later C4 is that the fog light circuit is grounded through the high beam filament. LED's have no filament as they are nothing more than a "light emitting diode." The circuit doctor method places a small 163 bulb to add a grounding filament.
There are other ways to do this, but to me at this point it was the easiest. https://www.corvetteforum.com/forums...-solution.html |
I noticed that pre 90' cars are wired differently... wonder what is required to make these work on my 88'?
(Post 1592962370)
It was the fog light issue I was referring to. I'll do some research on it. Thank for sharing about the headlights they look awesome!
(Post 1592962670)
I don't want to get too off topic for this thread but, if I understand the thread by circuit doctor the 1990-1996 cars had an issue where turning the fog lights on also turned the high beams on which is not ideal for fog...
No mention was made in that thread of 84-89' cars. |
My '86 has the fog lights connected directly to ground so there is no issue with HID or LED headlights. I think that changed in 1990 with the redesign of the car.
(Post 1592963507)
That cutoff looks amazing:cool:
Looks good but after reading the reviews some came DOA or had moisture problems. Sure Amazon will make them right if returned right away. Looking forward to see how they hold up.
(Post 1592963507)
(Post 1592963507)
Originally Posted by 95wht6spd
(Post 1592980050)
I did the Euro H4 upgrade on mine, and have this issue. I could never figure it out. Turn on the driving lights, and it activates the high beams, and these are halogen. I like the driving lights on too, because they have a wide pattern, and right in front of the car.
