Video: 1978 intermittent runs rough
I put together a video of my 1978 behaving badly.
At cold idle, the car seems to run well. A slight feeling of a "miss" here and there but generally, pretty well. As the engine begins to heat up, it will begin to intermittently start running rough. Originally it felt like a cylinder missing to me, however I'm noticing the whole engine will start to dog in general: runs smooth, kicks down and starts running rough, clicks back in runs smooth. When it's been at operating temperature for a good 10-15 minutes, it will continuously run rough, and will barely come back to run smooth. I've replaced a lot of the standard culprits, so I'm sort of at a loss and would appreciate any insight? I'm hesitant to take it to a shop where they start replacing stuff as a shot in the dark without a good diagnosis. Thanks very much for any help. Work that's been done over the last 6 months: Plugs and Wires, AC Delco / premium wires routed correctly through mounts and heat shields Distributor Cap and Rotor Ignition Control Module Distributor Coil Distributor vacuum advance still holds vacuum Complete Carburetor Rebuild including accel pump, fuel filter etc. Valve Cover Gaskets Fuel Pump and flex lines Water Pump Vacuum hoses generally checked and replaced where faulty Alternator looks like relatively new replace by previous owner Battery |
Originally Posted by 1978BackToLife
(Post 1593003817)
https://youtu.be/fQ-ZGkyS73I At cold idle, the car seems to run well. A slight feeling of a "miss" here and there but generally, pretty well. As the engine begins to heat up, it will begin to intermittently start running rough. Originally it felt like a cylinder missing to me, however I'm noticing the whole engine will start to dog in general: runs smooth, kicks down and starts running rough, clicks back in runs smooth. When it's been at operating temperature for a good 10-15 minutes, it will continuously run rough, and will barely come back to run smooth. I've replaced a lot of the standard culprits, so I'm sort of at a loss and would appreciate any insight? I'm hesitant to take it to a shop where they start replacing stuff as a shot in the dark without a good diagnosis. Thanks very much for any help. Work that's been done over the last 6 months: Plugs and Wires, AC Delco / premium wires routed correctly through mounts and heat shields Distributor Cap and Rotor Ignition Control Module Distributor Coil Distributor vacuum advance still holds vacuum Complete Carburetor Rebuild including accel pump, fuel filter etc. Valve Cover Gaskets Fuel Pump and flex lines Water Pump Vacuum hoses generally checked and replaced where faulty Alternator looks like relatively new replace by previous owner Battery |
It sounds like when the engine is hot you have a bad lifter or maybe a broken rocker arm,could be a bent pushrod.If you still have an EGR valve and a air cleaner valve one or both could have a leak when the engine gets up to temp.Unplug one vac line at a time with the engine at temp and see if they are holding vac also pull one valve cover off than the other and check to see were that ticking noise is coming from.
(Post 1593003817)
That valve train knock or click needs looking at . I you aren't an experienced mechanic , I would suggest taking it to to someone who knows old engines inside out.
I agree with Sparky about the EGR valve. The EGR valve is tied to the vacuum source through a thermal switch. When the engine is cold, the vacuum thermal switch blocks the signal to the EGR valve. As the engine heats up, the valve opens and activates the EGR. One symptom of a failing EGR is rough idle and misfire.
I would think if your problem was caused by a bad valve train component, you would hear it more when the engine is cold and the rough idle would be there regardless of temperature. Good luck, idle problems can be a bitch to find. Maj D |
I had this same problem on a Monza I once owned.
Closed the plug gaps some and it idled nice and smooth. I suggest closing the plug gaps to .040" and try that..... Have you done a compression check with engine both hot and cold to see if the engine is in good health? |
Common HEI failure mode of running good when cold and then rough like starving for fuel once hot. Pop the cap and rotor and you'll see what looks like rust on the advance mechanism from a bad rotor allowing sparks to hit the module and over time causing it to fail. Replaced rotor and modules in several cars over the years for this exact issue.
if you had electronics coolant spray you could hit the module after its hot and it would then run good until it warms back up. |
I 3rd the EGR. Sounds like the engine definitely has lifter noise but that's not going to cause you "intermittent". However it certainly needs some attention.
I can just imagine the carbon build up on the EGR pintle though ! As suggested above, remove the hose and plug it. Give the EGR a few little taps on the side with a small hammer and let us know. |
