Popping sound from exhaust
I have a16 Z51 A8 . When I get on it -gas it hard I get a backfire sound coming from the exhaust as it shifts in the trans, Wondering if this is a bad thing . Does it need to be seen at shop . I haven't done this very often as the car only has 2600 miles on it . Got to feel it sometimes . HAHA your imput is wecome Thanks
Absolutely normal, nothing to worry about.
Performance shift active, it's a good thing.
No need to go to the shop. |
Originally Posted by L8ter
(Post 1593132066)
It's a Great thing! Install a Corsa or Borla x-pipe and it will get even greater.
Originally Posted by PegasusCapital
(Post 1593132135)
Originally Posted by Tboatman
(Post 1593132105)
seems like we have the color car
(Post 1593132291)
so your saying it will always pop
(Post 1593132291)
I will called it a brappp rather that a pop but it does actually pop. Love that and have had several compliments from people about the shift pop. Very desirable feature. Only does it mainly on WOT which is often difficult to find a place to do that.
All sorts of things that are normal that you might think not :
https://www.corvetteforum.com/forums...ette-does.html |
(Post 1593132135)
ARH headers
:D Put a set of ARH midlength headers on it..............:rock:
Originally Posted by Maxpowers
(Post 1593132604)
Mine snap crackles and pops. All normal.
Is it the rev limiter causing the pop or something to do with the direct injector gas system or the way the exhaust system is designed? I have heard it on my car as well. Thanks
(Post 1593131987)
Yep, completely normal. Don't you love it? (2015 Z51 A8) |
All these cars are set up on the "Rich" side from the factory.
Regards Chip |
Millisecond fuel shut off between shifts. Or so I've read.
If you could turn it into an iTunes playlist, it'd sell! |
(Post 1593132135)
