Parking Brake Question
I was never very impressed with the holding ability of my parking brake, so like many "week-end wrenches', I decided to fix it. This, of course, ended up with the brake working in an even less effective manner.
Earlier this week, I bought the proper sized drum brake measuring tool, as illustrated in the FSM, and two days ago, I set about re-adjusting the brake shoes. Initially, I found that I had way too much clearance between the p-brake shoes and the inside of the rotor, so I adjusted it to the specified 0.015" clearance. I then put everything back together, happily thinking I was good to go. Not so fast.....as the p-brake will now at least hold the car from rolling down the driveway, if I put the car in gear, and give it even a little bit of gas, the engine will still overcome the p-brake's holding ability. Is this right? |
Yes, common on all vehicles I've own, I can move all cars I have against parking brake, it's made only for parking not driving.
Yes. It's right. As mentioned, it's just so your car doesn't roll away when parked, not for stopping your car vs. movement or engine power.
:iagree:
There's a reason these are now called "Parking Brakes" and not "Emergency Brakes" like they were in decades past. Back when cars had drums on all 4 wheels and a master cylinder that had a single circuit, if any part of the hydraulic system was compromised, NONE of your brakes worked (that was changed in the late-'50s, early-'60s when dual circuit M/Cs were installed which isolated the fronts and rears). If you had a hydraulic failure, the "Emergency Brake" used a cable system to activate the rear drums. Although you only had rear brakes, it was activating the same brake shoes that the hydraulic system activated, and would stop the car, albeit a bit slower. It also doubled as a Parking Brake. Most passenger cars into the early-'90s still used drum brakes on the rear, and the "Parking Brake" still activated the rear drums that are used to stop the car. On cars with 4 discs, the most common form of parking brake is a small drum with correspondingly small shoes inside the rear disc. This is the case for the C5. Since the drums and shoes are so small, they don't have a lot of stopping power - but they can keep a parked car from rolling away. It also means they should NEVER wear out, as they should only be activated when the vehicle is completely stopped. |
Any one have a right up on this? Mine has no tension whatsoever.
Subscribed :lurk:
To the Op, mine just got a bunch of work in the past weeks. Mine holds the car fine on any hill if I reef on the handle well. No way I could overcome it with as much cam as I've got now. I just don't have the idle torque now.
Originally Posted by Chicago1
(Post 1593266567)
That said, I tried several fixes on mine to no avail. Getting to the cables under the tunnel is about impossible. I didn't bother trying to replace cables when all the how-tos didn't work. I figured I'd get it when I did my engine/trans replacement, and I did. However, I found mine to be the handle itself. I don't know if someone tried to spray some 'grease' on it to lube it or what, but the stuff basically turned to tar and the adjustment pawl would no longer engage the cam it was supposed to adjust. I had access to a new handle so I installed that and found that I had already adjusted the brakes to perfection long before. If you're getting no brake action at all, take a look at that handle and see if everything actually works. It's a lot easier than replacing cables. Be sure to look at the pawl that drops into place immediately after you start to pull the handle. If that never engages, it never pulls on the cable and there's no brake at all. |
Originally Posted by K-Spaz
(Post 1593269216)
THere are writeups on how to adjust them here on the forum. Iirc, it's a post by Evil Twin. That said, I tried several fixes on mine to no avail. Getting to the cables under the tunnel is about impossible. I didn't bother trying to replace cables when all the how-tos didn't work. I figured I'd get it when I did my engine/trans replacement, and I did. However, I found mine to be the handle itself. I don't know if someone tried to spray some 'grease' on it to lube it or what, but the stuff basically turned to tar and the adjustment pawl would no longer engage the cam it was supposed to adjust. I had access to a new handle so I installed that and found that I had already adjusted the brakes to perfection long before. If you're getting no brake action at all, take a look at that handle and see if everything actually works. It's a lot easier than replacing cables. Be sure to look at the pawl that drops into place immediately after you start to pull the handle. If that never engages, it never pulls on the cable and there's no brake at all. |
(Post 1593266567)
Everything revolves around pivot pin/bolt D
The idea is to tighten the brake with ratcheting cam C In an ideal world, you pull the handle, Pawl A moves away from stop-pin B and engages cam C thus pulling the brake cable. What happened to me was pawl A was so mucked up with sticky goo that when you pulled the handle and it rotates away from stop-pin B, pawl A never moved into cam C. It just sat there glued in place and never engaged the cam which pulls the cable. No amount of helping seemed to matter either. It was really stuck. If you have pawl A not falling into place freely, you will have no parking brake. And you certainly can't adjust it. Furthermore, if someone put grease on any parts of it and it's dried and sticky, it will never self adjust. Cam C is what does all the self adjusting up at the handle anyway. Again, if it doesn't move smoothly, forget it. I tried cleaning mine with varsol, brake clean, 2+2 gum cutter... It was improving, but I said f it and bought another one. Life is too short for that. https://cimg1.ibsrv.net/gimg/www.cor...3da20a6351.jpg |
(Post 1593273697)
(Post 1593274752)
Good stuff thanks. How much was the new one?
Ill check into mine this weekend and let you know. Finally working on getting it back on the road after a year sitting.
Parking brake on mine has been poor from brand new. It's only ever really grabbed at the top of the range. I have had the rear brakes apart and manually adjusted the shoes the old fashioned way - to a slight "rub". Worked for a while after that. You SHOULD be able to hold the car on almost any grade with the brake - in fact if you need to do a hill start on a severe slope (M6) without rolling back at all, you need an effective parking brake.
In contrast, the parking brake on my wife's 86k mile Subaru is incredibly effective - try to move with it on, and the tail just "squats" and you don't get far. |
Maybe Subaru just has a better design for the hardware inside the drum.
Originally Posted by craig-o
(Post 1593254152)
:iagree:
Originally Posted by huesmann
(Post 1593293649)
Since, as I stated in post #1, my p-brake shoes are adjusted correctly, it looks like I'm going to find some time to remove the passenger's seat, console, and e-brake boot, and take a look-see......
(Post 1593254152)
