Originally Posted by TARANTULA
(Post 1593448443)
Are the tires on an non Z07 the same as the Z07?
Originally Posted by djnice
(Post 1593447408)
Me too, but I haven't seen anyone run that comparison. Same with the Z06, its usually tested on the track with Z07. It would be interesting to see how much difference the Z07 package makes on the same track.
Originally Posted by sunsalem
(Post 1593447974)
I doubt the Z07 package on the GS will make a substantial difference.
The LT1 doesn't have the power of the LT4 and won't be able to utilize the added downforce of the Z07 quite as well. By comparison, the LT4's ungodly amounts of power can make the Z07 option more advantageous on-track. The Z06's main weakness is not enough grip to handle the engine's output...more downforce helps generate more grip (front & rear). |
(Post 1593447974)
Yes, i miss the "coast down" measurements that Car and Driver used to do. I still recall how they compared the 1982 Camaro to the 1982 Trans Am to show that the TA needed 0.5 less hp to maintain 50 mph. This would be revealing on the GS with Stage II aero veruss Z06 with STAGE 3
Originally Posted by village idiot
(Post 1593448976)
Considering the aero benefits really only come into play well after the Z06 is past "light up the tires" speed that's not really true at all.
Aero = slipperiness (least resistance) going thru air. Downforce = the force that pushes the car down onto the driving surface. These 2 things are not the same.
(Post 1593449331)
Also, I don't think the Z07 changes the aero on the GS. You add the Aero kit separately as I recall.
(Post 1593452639)
You are confusing "aero" with downforce.
Aero = slipperiness (least resistance) going thru air. Downforce = the force that pushes the car down onto the driving surface. These 2 things are not the same. The Z07 package is primarily concerned with downforce...something that is VITAL to track performance. aero = aerodynamics = behavior of the vehicle with relation to airflow. That includes drag, lift, downforce, etc. downforce is a component of aerodyanmics drag is another is another (though technically, downforce is just drag in the up down direction) From a practical matter, increasing downforce almost always increases "drag" (as used in day to day terms- front to back drag). downforce is far from "vital" to the Z07's or Grandsport's performance. I'm willing to bet there is relatively small difference in performance without aero package (all the downforce stuff). If you start getting to ACR levels of downforce, it becomes more noticeable, but going from Z51 to Z06 package grandsport +95% of the lap speed improvement is wider stickier tires. In any event, relating to my post, the Z06 isn't going to take much more advantage, if any, of the aero package/increased downforce than the GS. IE: if you put the same stuff on the GS and Z06, it would probably help them both almost exactly the same amount. |
(Post 1593448976)
Grand sport without the R-compound tires is probably very similar to a Stingray. It will be a little faster around a track because wider tires and likely be slightly slower in acceleration due to extra weight of wider wheels/tires and heavier brakes. But pretty close.
. I'm trying to make up my mind right now between a GS without the Z07 and a Stingray with mag ride and performance exhaust. A little information along these lines would vastly help. How much better would a GS without the Z07 package handle compare to a Stingray w/ mag ride? Not interested in cosmetic differences since both look great. Edit: I'm so vitally interested in this right now I am considering starting a thread entitled, "Handling differences between regular Stingray w/mag ride vs. Grand Sport without Z07 package." However, I'm afraid it might be redundant. I could pick up a Stingray w/ mag ride right now if the differences between this a GS without Z07 are minimal. |
Sorry - to be clear, I'm comparing the cars assuming they have the same suspension (mag ride, etc).
The GS will perform better on the track, even without R compounds, because of the wider tires. It will make a difference, but not a huge difference, if you're sticking with street tires. With Rcompound it will be a bigger difference. Also, if you're running r compound, you'll probably start stressing the Z51 brakes a good bit. If I was running r compounds, I'd definitely want the bigger 6 piston brakes of the grand sport. In short, IMO, if you're not doing any track time, stingray for sure If you're running on the track on street tires only, probably Z51 If you're going to run r-compounds, grandsport for sure. |
Originally Posted by 16sedanSS
(Post 1593437081)
Ridiculous posts like this only makes sense to those who are a slave to tradition, unable to think for themselves, and have no understanding of physics. Par for the course.
In any case, physics has nothing to do with my reasoning against AWD. Some of us just prefer the dynamics of a RWD car, and for a lot of us (not all) that is one of the reasons we choose a Corvette. Some cars are just meant to be RWD, such as an M3 (now M4) will likely not become an AWD car. |
(Post 1593453661)
Also, wider tires is more grip, but wider body helps the car keep a more stable center of gravity in the turns. Lower and wider are huge benefits for cornering. |
Originally Posted by dead of night
(Post 1593452741)
I thought the GS had upgraded springs, chassis, and sway bars compared to the regular Stingray.
(Post 1593452741)
How much better would a GS without the Z07 package handle compare to a Stingray w/ mag ride? Not interested in cosmetic differences since both look great. Edit: I'm so vitally interested in this right now I am considering starting a thread entitled, "Handling differences between regular Stingray w/mag ride vs. Grand Sport without Z07 package." However, I'm afraid it might be redundant. I could pick up a Stingray w/ mag ride right now if the differences between this a GS without Z07 are minimal. If you decide to go Z07, then it has carbon ceramic brakes which last much much longer than traditional rotors and way less brake dust which is a nice perk. You'll love any corvette but I'd say go big and get the GS. If you dont care about the brakes, skip the Z07 and upgrade to the z07 tires yourself later. |
(Post 1593452659)
lol not exactly.
aero = aerodynamics = behavior of the vehicle with relation to airflow. That includes drag, lift, downforce, etc. downforce is a component of aerodyanmics drag is another is another (though technically, downforce is just drag in the up down direction) From a practical matter, increasing downforce almost always increases "drag" (as used in day to day terms- front to back drag). downforce is far from "vital" to the Z07's or Grandsport's performance. I'm willing to bet there is relatively small difference in performance without aero package (all the downforce stuff). If you start getting to ACR levels of downforce, it becomes more noticeable, but going from Z51 to Z06 package grandsport +95% of the lap speed improvement is wider stickier tires. |
Originally Posted by themonk
(Post 1593454965)
It affects top speed pretty good.
I've raced a few Z06's with the Z07 package. I just start to pull away slowly and then at 120mph its like they let off the gas. If I was buying a dead stock car and leaving it dead stock, the 911S really does look impressive. But I didn't buy the C7 just because it was cheaper than a 911 but because for minimal money I could do what I did with it, 8K and almost 750hp in an extremely reliable package. Can't do that with a 911 unless your starting with a Turbo and screwing the warranty on a very expensive powertrain. I did not worry about he PT in the C7 because in relative terms its cheap and reliable. |
(Post 1593454965)
I was expecting some pretty awesome mpg with the C7 over my C6. It's about the same or maybe even worse despite direct injection, 7th gear and DoD, and I only have the Z51 package. I do have a splitter and side skirts though. I also cruise around 80mph, so aero is a bigger deal. |
Originally Posted by angryBits
(Post 1593454630)
Wow really? I am an engineer and actually have a minor in physics.
In any case, physics has nothing to do with my reasoning against AWD. Some of us just prefer the dynamics of a RWD car, and for a lot of us (not all) that is one of the reasons we choose a Corvette. Some cars are just meant to be RWD, such as an M3 (now M4) will likely not become an AWD car. I actually enjoy front engine RWD the most, but it's because I'm most comfortable with it. Hell, I even enjoy a my crappy slow Miata over my Z51 on the track even though I'm nearly 20 seconds faster in the Z51. It's all preference. You never realize how terrifying 450 (or 650) hp is until you start driving a really slow car hard. Then you realize how much you leave on the table with a fast car. Anyway, I don't like AWD. I really don't like weight. I don't like its driving properties. I dont like its complexity. |
I believe both the La Ferrari and the P1 are rear wheel drive, so clearly AWD is not critical if the chassis dynamics are sound, or you work in some crafty engineering like rear wheel steering that the 911 has.
At the end of the day, a good, relatively balanced car coming out of a turn should have the front tires screaming, so it's not like they are going to put a lot of power down anyway.
Corvette team has hit the sweet spot with the GS. MT and Randy really like the handling, first time i hear Randy said that a C7 puts the power down well. :thumbs:
(Post 1593452741)
So there's little advantage to getting the GS without the Z07 package, compared to the Stingray? I thought the GS had upgraded springs, chassis, and sway bars compared to the regular Stingray.
I'm trying to make up my mind right now between a GS without the Z07 and a Stingray with mag ride and performance exhaust. A little information along these lines would vastly help. How much better would a GS without the Z07 package handle compare to a Stingray w/ mag ride? Not interested in cosmetic differences since both look great. Edit: I'm so vitally interested in this right now I am considering starting a thread entitled, "Handling differences between regular Stingray w/mag ride vs. Grand Sport without Z07 package." However, I'm afraid it might be redundant. I could pick up a Stingray w/ mag ride right now if the differences between this a GS without Z07 are minimal. A GS/Z07 pulls 1.2 G's as does a Z06/7. They both have CC Brakes. FYI the difference between 1.05 and 1.20 G's is vast. |
Originally Posted by 2cnd Chance
(Post 1593460748)
To make it simple; the GS (nonZ07) pulls 1.05 G's a Z06 (nonZ07) 1.05 G's. They have the same brakes.
