C3 Corvette Exterior Parts At RPI Designs
Rpi Designs is now expanding into the C3 Corvette. We are adding new restoration products every week. Our goal is to be a one stop shop for all of your Corvette needs no matter what generation of Corvette you drive.
1968-1972 C3 Corvette Front Bumper $327.74 with code PHIL5 at checkout Add a new high quality Chrome Front Bumper to your 1968-1972 Corvette and attract the attention of all those around you. Made using the latest techniques in chrome triple plating, you will be amazed at the reflectiveness and purity of these replacement Corvette chrome bumpers! https://cimg9.ibsrv.net/gimg/www.cor...ab9afc2f78.jpg http://www.rpidesigns.com/shop/item....-front-bumper/ 1968-1973 C3 Corvette Rear Bumper Driver's Side $261.24 with code PHIL5 at checkout Add a new high quality chrome rear bumper to your 1968-1972 Corvette and attract the attention of all those around you. Made using the latest techniques in chrome triple plating, you will be amazed at the reflectiveness and purity of these replacement Corvette chrome bumpers! https://cimg2.ibsrv.net/gimg/www.cor...45c8b8cda4.jpg http://www.rpidesigns.com/shop/item....-drivers-side/ 1968-1973 C3 Corvette Rear Bumper Passengers Side $261.24 with code PHIL5 at checkout Add a new high quality chrome rear bumper to your 1968-1972 Corvette and attract the attention of all those around you. Made using the latest techniques in chrome triple plating, you will be amazed at the reflectiveness and purity of these replacement Corvette chrome bumpers! https://cimg5.ibsrv.net/gimg/www.cor...650091bceb.jpg http://www.rpidesigns.com/shop/item....ssengers-side/ 1968-1973 C3 Corvette Front Bumper License Plate Bar $37.99 with code PHIL5 at checkout This Corvette reproduction license plate bumper bar has been manufactured to original factory specifications using today's modern manufacturing techniques. You will find the fit, finish and function will work superbly for your restoration. Add a new high quality chrome front bumper license plate bar to your 1968-1973 Corvette and attract the attention of all those around you. https://cimg0.ibsrv.net/gimg/www.cor...e953d17224.jpg http://www.rpidesigns.com/shop/item....nse-plate-bar/ Corvette Forum Member Save With Code PHIL5 At Checkout. See these and many more part at our web site http://www.rpidesigns.com/shop/ |
C3 Corvette Chrome Wheel Trim, Scissor Jack, Spare Tire Y Bracket
1972-1973 C3 Corvette Reproduction Chrome Wheel Trim Rings Set 8 Inch $71.24 with code PHIL5 at checkout.
Over the years there is a good chance your 72 or 73 Corvette chrome wheel center cap rings are looking, well, like they have seen better days. We have a great reproduction set that is affordable and build like the originals. These 1972-1973 C3 Corvette chrome wheel trim rings are 8" as original and come in a set of four pieces. https://cimg7.ibsrv.net/gimg/www.cor...5b8cc9705c.jpg 1972-1973 C3 Corvette Chrome Wheel Trim Rings Set 8 Inch 1968-1974 C3 Corvette Reproduction Scissor Jack and Handle Package $166.24 with code PHIL5 at checkout. After a decade or two there is a good chance your scissor jack is rusted out or just needing to be replaced. We have a great reproduction scissor jack and handle that is affordable and build like the original. This 1968-1974 C3 Corvette scissor jack and handle also feature the correct black finish as original. https://cimg3.ibsrv.net/gimg/www.cor...4fc426bd2e.jpg 1968-1974 C3 Corvette Scissor Jack and Handle Package 1968-1982 C3 Corvette Reproduction Spare Tire Carrier Y Bracket $71.24 with code PHIL5 at checkout. After a decade or two there is a good chance your spare tire Y bracket is rusted out or just needing to be replaced. We have a great reproduction Y brackets that is affordable and build like the original. This 1968-82 C3 spare tire Y bracket is build sturdy and finished in black just like the original piece. https://cimg0.ibsrv.net/gimg/www.cor...b4eac2c233.jpg 1968-1982 C3 Corvette Spare Tire Carrier Y Bracket Corvette Forum Member Save With Code PHIL5 At Checkout. See these and many more part at our web site www.rpidesigns.com |
C3 Corvette Washer Nozzles Set, C3 Corvette Wiper Arms, C3 Wiper Blades Refills
1968-2000 Corvette Reproduction 16 Inch Wiper Blades Refills $37.99 With Code PHIL5 At Checkout.
Available in Stainless Steel or Black Stainless Steel Replacing the wiper refills on your 1968-2000 Corvette should be done every couple of years. We have a very nice reproduction set that is built to look and function like the originals. Our wiper refills are 16" long and fit 1968-2000 Corvette. https://cimg4.ibsrv.net/gimg/www.cor...44d283df67.jpg http://www.rpidesigns.com/shop/item....lades-refills/ 1968 C3 Corvette Reproduction Washer Nozzles Set $46.54 With Code PHIL5 At Checkout. After replacing your C3 wiper arms and possibly related switches you will probably want to change out your washer nozzles. We have a very nice reproduction set of 1968 Corvette washer nozzles. These nozzles are the correct size and shape as original. https://cimg6.ibsrv.net/gimg/www.cor...33c0f8950d.jpg http://www.rpidesigns.com/shop/item....r-nozzles-set/ 1968 C3 Corvette Replacement Wiper Arms $123.49 With Code PHIL5 At Checkout. After many years of use it's not unusual for your C3 Corvette wiper arms to wear out and need replaced. RPI Designs has a very nice reproduction product LH and RH. Our 1968 Corvette wiper arms are correct and have the correct angles, bends and finish as original. Sold as a set. https://cimg9.ibsrv.net/gimg/www.cor...0a04ad4a2f.jpg http://www.rpidesigns.com/shop/item....nt-wiper-arms/ 1969 -1974 Early C3 Corvette Replacement Wiper Arms $137.74 With Code PHIL5 At Checkout. After many years of use it's not unusual for your C3 Corvette wiper arms to wear out and need replaced. RPI Designs has a very nice reproduction product LH and RH. Our 1969-1974 Early Corvette wiper arms are correct and have the correct rubber tube for washer fluid as original. Sold as a set. https://cimg9.ibsrv.net/gimg/www.cor...7dc8a9d3da.jpg http://www.rpidesigns.com/shop/item....nt-wiper-arms/ 1974 Late - 1982 C3 Corvette Replacement Wiper Arms $123.49 With Code PHIL5 At Checkout. After many years of use it's not unusual for your C3 Corvette wiper arms to wear out and need replaced. RPI Designs has a very nice reproduction product LH and RH. Our 1974 E-1982 Corvette wiper arms are correct and have the correct rubber tube for washer fluid as original. Sold as a set. https://cimg7.ibsrv.net/gimg/www.cor...752a75afc0.jpg http://www.rpidesigns.com/shop/item....nt-wiper-arms/ Corvette Forum Member Save With Code PHIL5 At Checkout. See these and many more part at our web site www.rpidesigns.com |
1968-1977 C3 Corvette Weatherstrip and Seals
RPI Designs is proud to sell american made METRO weatherstripping for classic Corvettes. Other than a quality American made product at a great price here is the other reason we carry METRO weatherstripping. It is simply the best weatherstripping out there. What makes Metro’s rubber superior?
METRO’s rubber is made from an advanced, proprietary EPDM formula which has superior ozone and UV resistance. METRO’s rubber products are also molded using high heat and 40-to-125 tons of pressure, which gives them a longer life and clean, smooth looks. METRO’s parts quality, and look and feel usually surpasses the quality of the original rubber parts. All the fine details of the original parts are precisely duplicated, even the details that won't show after installation. The most advanced materials are combined with the latest technologies to make METRO rubber the highest quality rubber parts available. METRO’s SUPERSoft sponge rubber is the softest and most durable auto rubber you can buy. SUPERsoft has a unique closed micro-cell structure. This cell structure helps give SUPERsoft its superior softness. The material formula and secret manufacturing process gives SUPERsoft better shape "memory", better looks, and better durability and resistance to abrasion, tearing and ripping. Unlike other auto weatherstripping, SUPERsoft does not absorb water – a key condition to completely sealing out water. 1968-1977 C3 Corvette T-Top Seals $60.37 With Code PHIL5 At Checkout. T-Top Seals. Includes clips and molded corners. No core. For early '77 models. May be modified for '68. Pair R&L https://cimg1.ibsrv.net/gimg/www.cor...c21f11228d.jpg http://www.rpidesigns.com/shop/item....e-t-top-seals/ 1969-1972 C3 Corvette Basic Kit for T-Top Coupe $174.32 With Code PHIL5 At Checkout. Basic Kit., for T-Top Coupe. Door (LM 19-C) Pillar Post (CZ 2001) T-Top (TP 2000) Rear Vertical (ELP 2050), Seals. https://cimg1.ibsrv.net/gimg/www.cor...d367f88549.jpg http://www.rpidesigns.com/shop/item....r-t-top-coupe/ 1969-1977 C3 Corvette Molded Door Seals $45.12 With Code PHIL5 At Checkout. Molded Door Seals with Molded Ends and Clips. Fits Coupes only. Pair R&L https://cimg4.ibsrv.net/gimg/www.cor...c56d011ddd.jpg http://www.rpidesigns.com/shop/item....ed-door-seals/ 1968-1977 C3 Corvette Rear vertical window seals $18.38 With Code PHIL5 At Checkout. Rear vertical window seals. '68-'77 Corvette coupe. 10-1/2 in. long. Pair. R&L. https://cimg4.ibsrv.net/gimg/www.cor...c80ed0f846.png http://www.rpidesigns.com/shop/item....-window-seals/ 1968-1972 C3 Windshield Pillar Post Seals for Convertibles $38.95 With Code PHIL5 At Checkout. Windshield Pillar Post Seals for Convertibles, with attached hinge pillar. 27-3/4" long. Pair https://cimg5.ibsrv.net/gimg/www.cor...d4bd560964.jpg http://www.rpidesigns.com/shop/item....-convertibles/ Corvette Forum Member Save With Code PHIL5 At Checkout. See these and many more part at our web site www.rpidesigns.com |
C3 Corvette Wheels Center Caps Package
1976-1979 C3 Corvette Wheels Center Caps Package $79.79 With Code PHIL5 At Checkout
Our reproduction center caps package includes four pieces and feature the 1976-1979 C3 Corvette flags pace car logo. These center caps are exact replicas of the original pieces. Our 1976-1979 C3 wheels center caps are official GM Restoration Licensed Parts. Fitment: 1976, 1977, 1978, 1979 C3 Corvette https://cimg9.ibsrv.net/gimg/www.cor...f9fd43184c.jpg http://www.rpidesigns.com/shop/item....-caps-package/ 1978 C3 Corvette Pace Car Wheels Center Caps Package $79.79 With Code PHIL5 At Checkout Our reproduction center caps package includes four pieces and feature the 1978 C3 Corvette flags pace car logo. These center caps are exact replicas of the original pieces. Our 1978 C3 wheels center caps are official GM Restoration Licensed Parts. https://cimg3.ibsrv.net/gimg/www.cor...d0632dc938.jpg http://www.rpidesigns.com/shop/item....-caps-package/ 1980-1981 C3 Corvette Wheels Center Caps Package $85.49 With Code PHIL5 At Checkout Our reproduction center caps package includes four pieces and feature the 1980-1981 C3 Corvette flags logo. These center caps are exact replicas of the original pieces. Our 1980-1981 C3 wheels center caps are official GM Restoration Licensed Parts. https://cimg2.ibsrv.net/gimg/www.cor...7353123410.jpg http://www.rpidesigns.com/shop/item....-caps-package/ 1982 C3 Corvette Wheels Center Caps Package $85.49 With Code PHIL5 At Checkout Our reproduction center caps package includes four pieces and feature the 1982 C3 Corvette flags logo. These center caps are exact replicas of the original pieces. Our 1982 C3 wheels center caps are official GM Restoration Licensed Parts. https://cimg4.ibsrv.net/gimg/www.cor...9fccec52a7.jpg http://www.rpidesigns.com/shop/item....-caps-package/ 1982 C3 Corvette Wheels Center Caps Emblems Package $28.49 With Code PHIL5 At Checkout Our reproduction center caps emblems package includes four pieces and feature the 1982 C3 Corvette flags logo. These center caps decals are exact replicas of the original pieces. Our 1982 C3 wheels center caps decals are official GM Restoration Licensed Parts. https://cimg1.ibsrv.net/gimg/www.cor...0462c00663.jpg http://www.rpidesigns.com/shop/item....blems-package/ 1976-1982 C3 Corvette 20 Piece Aluminum Lug Nut Package $37.99 With Code PHIL5 At Checkout. If the time has come to replace your wheels or just your lugnuts then we have what you need. Our 1976-1982 C3 Corvette aluminum lug nut package includes 20 pieces, enough to complete the job on all four C3 wheels. These aluminum lugnuts have the correct polish as original. https://cimg0.ibsrv.net/gimg/www.cor...15ca06ace5.jpg http://www.rpidesigns.com/shop/item....ugnut-package/ Corvette Forum Member Save With Code PHIL5 At Checkout. See these and many more part at our web site www.rpidesigns.com |
1975-1981 C3 Corvette Gas Door Emblem At RPI Designs
1975-1976 C3 Corvette Gas Door Emblem $66.50 With Code PHIL5 At Checkout.
Give your 1975-1976 C3 Corvette a fresh, new look by replacing your old, discolored gas tank lid emblem with a high-quality replacement emblem. Our reproduction emblem has the fit and finish you need for your restoration. These are replicated to match the original so the authenticity is not compromised on your classic C3 Corvette. Fitment: 1975-1976 C3 Corvette https://cimg2.ibsrv.net/gimg/www.cor...1c10cf2d55.jpg http://www.rpidesigns.com/shop/item....s-door-emblem/ 1977-1980 C3 Corvette Gas Door Emblems $47.50 With Code PHIL5 At Checkout. Give your 1977-1981 C3 Corvette a fresh, new look by replacing your old, discolored gas tank lid emblem with a high-quality replacement emblem. Our reproduction emblem has the fit and finish you need for your restoration. These are replicated to match the original so the authenticity is not compromised on your classic C3 Corvette. 1977 C3 Corvette Gas Door Emblem https://cimg4.ibsrv.net/gimg/www.cor...7a78d52db2.png http://www.rpidesigns.com/shop/item....s-door-emblem/ 1979 C3 Corvette Gas Door Emblem https://cimg1.ibsrv.net/gimg/www.cor...6c49f1354a.jpg http://www.rpidesigns.com/shop/item....s-door-emblem/ 1980 C3 Corvette Gas Door Emblem https://cimg5.ibsrv.net/gimg/www.cor...b88d4806a5.jpg http://www.rpidesigns.com/shop/item....s-door-emblem/ 1981 C3 Corvette Gas Door Emblem https://cimg8.ibsrv.net/gimg/www.cor...5a6d428a6b.jpg http://www.rpidesigns.com/shop/item....s-door-emblem/ |
1968-1979 C3 Corvette Tail Light Lenses
1968-1979 C3 Corvette Tail Light Lenses $41.80 With Code PHIL5 At Checkout
After years of use, even the best cared for tail lights will turn dull and crack. Our reproduction 1968-1979 C3 Corvette tail lights are a perfect match to your original tail lights and will provide years of good looks. https://cimg0.ibsrv.net/gimg/www.cor...cd3786c1c5.jpg https://www.rpidesigns.com/shop/item...-light-lenses/ 1968-1979 C3 Corvette Backup Lenses $41.80 With Code PHIL5 At Checkout After years of use, even the best cared for Backup Lenses will turn dull and crack. Making it difficult to see where you are going at night. Our reproduction 1968-1979 C3 Corvette backup lights are a perfect match to your original backup lights and will provide years of good looks. https://cimg7.ibsrv.net/gimg/www.cor...a887e0bde3.jpg https://www.rpidesigns.com/shop/item...ack-up-lenses/ |
1968-1982 C3 Corvette Headlight Bezel (Fiberglass) $104.49 With Code PHIL5 At Checkout
The factory bezel on the C3 Corvette can be very brittle after years of use. Our quality reproduction bezels are exactly the same shape and size as the original. They feature the correct black micro finish and come ready for primer and paint. We include the mounting screws and clips for a complete package. https://cimg8.ibsrv.net/gimg/www.cor...cc04aca443.jpg https://www.rpidesigns.com/shop/item...el-fiberglass/ 1977-1982 C3 Corvette Sport Door Mirror With Remote Control Drivers Side $126.35 With Code PHIL5 At Checkout Do not put your old worn out sport mirror back on your fresh restoration. Our great looking reproduction mirror will give your car a factory fresh look in no time. Our mirror includes all needed hardware and is ready to paint. https://cimg8.ibsrv.net/gimg/www.cor...c2ea2fc108.jpg https://www.rpidesigns.com/shop/item...-drivers-side/ 1968-1975 C3 Corvette Soft Top Rear Latch $82.65 With Code PHIL5 At Checkout These 1968-1975 C3 Corvette Soft Top Rear Latches are perfect for replacing your old Soft Top Rear Latches. Fits, functions, and installs just like the original. https://cimg9.ibsrv.net/gimg/www.cor...6f997dd277.jpg https://www.rpidesigns.com/shop/item...p-rear-latch-/ 1968-1969 C3 Corvette Lower Grille Moulding $95.00 With Code PHIL5 At Checkout Restore the front end of your 1968-1969 Corvette back to its original beauty by replacing the chrome trim around the front grille with our 1968-1969 C3 Corvette Front Grille Moulding. You will find the fit, finish and function will work superbly for your restoration. Using our reproduction moulding will save you time and money over trying to repair your broken and rusted original. https://cimg1.ibsrv.net/gimg/www.cor...5a01e56694.jpg https://www.rpidesigns.com/shop/item...ille-moulding/ |
C3 Corvette Allen's Exhaust Sets At RPI Designs
If you are looking for the best exhaust pipes for your C3 Corvette look no further than our 1968-1982 C3 Corvette AllensExhaust Sets. These exhaust pipe sets are made here in the USA and are the choice of top restoration shops competing for Bloomington Gold.
We also have Mufflers, Side Pipes, Y-Pipes, and other accessories. We offer these systems in your choice of three different materials.
https://cimg2.ibsrv.net/gimg/www.cor...fa659195ed.jpg https://cimg0.ibsrv.net/gimg/www.cor...e510a5c8b6.jpg https://cimg0.ibsrv.net/gimg/www.cor...7928454122.jpg https://cimg3.ibsrv.net/gimg/www.cor...2248c6716c.jpg |
1982 C3 Corvette Wheels Center Caps Emblems Package $29.99Our reproduction center caps emblems package includes four pieces and features the 1982 C3 Corvette flags logo.These center caps decals are exact replicas of the original pieces. Our 1982 C3 wheels center caps decals are official GM Restoration Licensed Parts. https://www.rpidesigns.com/shop/item...blems-package/ https://www.rpidesigns.com/images/19...%20emblems.jpg 1978-1982 Chevy Corvette C3 Fuel Gas Tank Filler Neck Gasket Boot Seal $19.95Restoring any Corvette can be a daunting process and sometimes intimidating. One place to start can be with the 1978 through 1982 C3 Corvette fuel tank filler neck gasket boot seal to ensure that there are no breaks or leaks in your fuel system. This is the seal that mounts between the gas tank in the rear deck, and it is built to the exact specifications as the original. The quality is top-notch and the function is seamless. This filler neck seal is sure to get your C3 back on the road in no time. Here at RPI designs, we take pride in providing the very best reproduction Corvette restoration parts available. So, rest easy knowing that your C3 is going to be taking care of. Fitment: 1978, 1979, 1980, 1981, 1982 C3 Corvettehttps://www.rpidesigns.com/shop/item...eck-seal-boot/https://www.rpidesigns.com/images/78...eck%20seal.jpg 1968-1976 C3 Corvette Rear Deck Vent Grille Pair Chrome $148.45We always enjoy helping our customers find the proper reproduction or restoration part for their 1968-1976 C3 Corvette. If you're looking for a set of rear deck vent grills free 1968 through 1976 Corvette then these reproduction grills are just what you are looking for. These high-quality rear deck vent grills are made out of cast metal just as the original ones were but these features a high-quality triple chrome plated finish for a great custom look. These rear deck vent grills will install quickly and easily with the included hardware to give your car a great-looking finished appearance. When buying reproduction parts for your Corvette is always important to make sure you get the finest quality parts so that your restoration will go quickly and easily. We sell only the finest high-quality restoration parts that are sure to fit right the 1st time every time.Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976 C3 Corvettehttps://www.rpidesigns.com/shop/item...e-pair-chrome/ https://www.rpidesigns.com/images/19...Chrome%20p.jpg |
1963-1982 C2 And C3 Corvette Adjustable Strut Rods With Polyurethane Bushings $104.99It's great to have a top running 1963 through 1982 C2 and C3 Corvette, it's also great to have the same Corvette look just as good as it runs and looks as good as it performs. If you're in the market for new reproduction Strut Rods then take a good look at this. We all know that over time these original strut rods fail due to rubber deterioration which causes issues with alignment. The old fix has been for the alignment shop to manually bend the strut rod to get the rear wheels in alignment. However, now you can replace those old worn-out rods with a completely new unit. These strut rods are adjustable, having polyurethane bushings and are manufactured to the exact specifications as the original using the most modern techniques. So quit fighting the alignment fon your restoration and get the best fix available right here at RPI designs. FITMENT: 1963, 1964, 1965, 1966, 1967, 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980, 1981, 1982 C2 & C3 CORVETTEhttps://www.rpidesigns.com/shop/item...te-strut-rods/ https://www.rpidesigns.com/images/19...Strut-Rods.jpg |
1969-1973 C3 Corvette Stingray Fender Emblem Pair By Trim Parts $104.90If you are looking to replace the stingray fender emblems on your 1969 through 1973 C3 Corvette this emblem set from trim parts it's the best that you can get. These amazing fender emblems are the highest quality reproduction parts on the market today. If you are restoring your car and plan on taking it to Bloomington for certification these are the emblems that you will need to have on your car.Who is TRIM PARTS? TrimParts, Inc. manufactures GM licensed restoration parts for Chevrolet and other GM cars and trucks. We are dedicated to manufacturing the highest quality products offered in the restoration industry by using the original GM tooling under licensing from GM when tooling is available. Otherwise, TrimParts engineers and builds in-house tooling to meet the original GM Specifications and TrimParts Quality. When you see the “GM Restoration Parts” emblem associated with our restoration parts, you can be assured that each part is licensed by General Motors for reproduction and meets GM guidelines for quality and authenticity. TrimParts products are fully guaranteed against any manufacturing defects. If for any reason you are not satisfied with the quality of workmanship, please tell us and we will gladly replace that item. Fitment: 1969, 1970, 1971, 1972, 1973, C3 Corvettehttps://www.rpidesigns.com/shop/item...by-trim-parts/https://www.rpidesigns.com/images/19...Emblem-Set.jpg |
Thank you for the orders!
1968-1972 C3 Corvette Nose Emblem By Trim Parts $37.95If you are having you Corvette repainted then now is the perfect time to replace your worn and pitted nose emblem. This nose emblem is a GM restoration part that will fit perfectly and last for years. This great-looking nose emblem is just what you need to keep your Corvette looking is best. When you are taking the time to do a quality restoration on your Corvette nothing looks worse than reinstalling your worn out original emblems back on to your freshly painted car. If you are looking to replace your old emblems with the highest quality emblems available on the market today is no further than Trim Parts brand restoration parts. All of Trim Parts emblems exceed the highest standards available and are guaranteed to be a noticeable improvement over regular restoration parts.Replaces Original GM part # 3912706 Who are TRIM PARTS? TrimParts, Inc. manufactures GM licensed restoration parts for Chevrolet and other GM cars and trucks. We are dedicated to manufacturing the highest quality products offered in the restoration industry by using the original GM tooling under licensing from GM when tooling is available. Otherwise, TrimParts engineers and builds in-house tooling to meet the original GM specifications and TrimParts Quality. When you see the “GM Restoration Parts” emblem associated with our restoration parts, you can be assured that each part is licensed by General Motors for reproduction and meets GM guidelines for quality and authenticity. TrimParts products are fully guaranteed against any manufacturing defects. If for any reason you are not satisfied with the quality of workmanship, please tell us and we will gladly replace that item. Fitment: 1968, 1969, 1970, 1971, 1972, C3 Corvettehttps://www.rpidesigns.com/shop/item...by-trim-parts/https://www.rpidesigns.com/images/19...Trim-Parts.jpg1969-1973 C3 Corvette Fuel Door Emblem By Trim Parts $46.90If you are having you Corvette repainted then now is the perfect time to replace your worn and pitted fuel door emblem. This fuel door emblem is a GM restoration part that will fit perfectly and last for years. This great-looking fuel door emblem is just what you need to keep your Corvette looking is best. Trim parts design and builds the highest quality reproduction accessories. Their parts are truly the best you can buy.Replaces Original GM part # 3957809 Who are TRIM PARTS? TrimParts, Inc. manufactures GM licensed restoration parts for Chevrolet and other GM cars and trucks. We are dedicated to manufacturing the highest quality products offered in the restoration industry by using the original GM tooling under licensing from GM when tooling is available. Otherwise, TrimParts engineers and builds in-house tooling to meet the original GM specifications and TrimParts quality. When you see the “GM Restoration Parts” emblem associated with our restoration parts, you can be assured that each part is licensed by General Motors for reproduction and meets GM guidelines for quality and authenticity. TrimParts products are fully guaranteed against any manufacturing defects. If for any reason you are not satisfied with the quality of workmanship, please tell us and we will gladly replace that item. Fitment: 1969, 1970, 1971, 1972, 1973 C3 Corvettehttps://www.rpidesigns.com/shop/item...em-trim-parts/https://www.rpidesigns.com/images/19...Trim-Parts.jpg |
1963-1980 C2 C3 Corvette Rear Spring Cup Installation Tool $39.55Sometimes having the right tool is all you need to make a complex job simple. This 1963 through 1980 Corvette rear spring Insulation tool is just one of those tools. This tool will allow you to replace the rear spring cushion retainers in your Corvette with no need to unmount the trailing arms or springs. Unlike other methods, this amazing time-saving tool enables you to install the retainers without removing the mounts. This will work for the rear trailing arm/control arm or rear spring. This tool is simple to use and will definitely save you time and money because your only other alternative is to remove this parts from your car taken into a professional shop to have these parts installed costing you time and money. Check out the video below to see just how easily this task can be accomplished with this great tool.All required parts come in one convenient package: Flare/Crimp Tool Alignment/Jack Nut Mount Cup Spacer Plate Lock Bolt 1/2-20 Hex Bolt Grade 8 1/2-20 Hex Nut Grade 8 1/2 Flat Washer Grade 8 1/2 FlatWasher 2" OD 3/8-16x x 11/4 Hex Bolt Additional tools required: Two 3/4" wrenches 9/16" wrench Fitment: 1963, 1964, 1965, 1966, 1967 C2, 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980 C3 Corvettehttps://www.rpidesigns.com/shop/item...allation-tool/https://www.rpidesigns.com/images/19...20Tool%20s.jpg |
1963-1982 C2 C3 Corvette Power Steering Control Valve
1963-1982 C2 C3 Corvette Power Steering Control ValveReplace your failing valve before it's too late with this 1963-1982 C2-C3 Corvette Power Steering Control Valve.If you want to keep your power steering system working the way you need it to, replacing an old power steering control valve is paramount. The Corvette Power Steering Control Valve will help keep your power steering from malfunctioning. If your ride isn't as smooth as it used to be and turning your wheel is harder than it should be, it's probably time to check the system and replace parts. With a new Corvette Power Steering Control Valve installed, you can have a perfect handle on your Corvette, leaving it steering like an absolute dream. this valve controls the hydraulic functions of your steering and can be the cause of numerous steering problems and leaks. Replacing your worn out unit with our quality reproduction valve will ensure many years of trouble-free driving. Fitment: 1963, 1964, 1965, 1966, 1967 C2, 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980, 1981, 1982 Corvettehttps://www.rpidesigns.com/shop/item...control-valve/ https://www.rpidesigns.com/images/19...trol-valve.jpg |
1975-1979 C3 Corvette Windshield Washer Bottle Tank
1975-1979 C3 Corvette Windshield Washer Bottle Tank $25.99Our reproduction 75-79 Corvette C3 windshield washer bottle tank is a very nice quality and accurate reproduction of the OE piece. This is the correct tank that mounts to the inner fender area.Fitment: 1975, 1976, 1977, 1978, 1979 C3 Corvettehttps://www.rpidesigns.com/shop/item...r-bottle-tank/ https://www.rpidesigns.com/images/19...r%20bottle.jpg |
1969-1976 Corvette Windshield Header Corner Molding Pair
1969-1976 Corvette Windshield Header Corner Molding Pair By Trim Parts $100.80 With Code PHIL5 At CheckoutThese moldings are probably the most highly abused trim part on your C3 Corvette. No matter how careful you are removing and installing your roof panels these quarter moldings always end up getting scratched and damaged. And because they all end up scratched and damaged it is nearly impossible to find good used ones at a reasonable price. So if you are restoring your car and you need to replace your corner moldings why not get the best fitting and best-looking header quarter moldings available on the market today? These are brand-new highly polished chrome-plated replacement moldings designed and manufactured by trim parts. These quarter moldings will make your car look like new again. These windshield header corner moldings will fit both convertible and T top Corvettes. These moldings replace the original GM part number 3966601/2.Fitment: 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976 Corvette https://www.rpidesigns.com/images/19...r-Moldings.jpg |
1977-1982 C3 Corvette Sport Door Mirror w Remote Control Drivers Side
1977-1982 C3 Corvette Sport Door Mirror With Remote Control Drivers Side $127.68 With Code PHIL5 At CheckoutWe take great pride in providing the best quality reproduction parts available for you 1977 through 1982 C3 Corvette. Our driver-side outside mirror is no exception. Has your mirror failed or just needs to be replaced after years of wear and tear? If so, our reproduction piece is just what you need. We always enjoy helping our customers find the right reproduction parts for the restoration of their C3 Corvette. This mirror is a high-quality piece that has been copied from an original GM piece ensuring that the fit, function, and look is as authentic as possible.RPI Designs is committed to making Corvette restoration as true, and high quality as possible. So, you can rest assured knowing that you have chosen the very best for your C3 Corvette. Fitment: 1977, 1978, 1979, 1980, 1981, 1982, C3 Corvettehttps://www.rpidesigns.com/shop/item...-drivers-side/ https://www.rpidesigns.com/images/19...Mirror%204.jpg |
1968-1982 C3 Corvette Coverking Satin Stretch Car Cover
1968-1982 C3 Corvette CoverKing Satin Stretch Car CoverThere are many options when it comes to an indoor car cover for your C3 Corvette. Perhaps the best quality and value is the CoverKing Satin Stretch. This car cover uses a heavy satin material that is great for any indoor use. With the ultra-soft fleece er you will not have to worry about getting scratches in your Corvettes paint. The fabric is heavy enough that it will not let dust through the cover and onto your Corvette yet light enough to let your car breath. CoverKing gives you many color options to choose, even two-tone options. Use the configurator that allows you to build your own cover, to your specifications.https://www.rpidesigns.com/shop/item...tch-car-cover/ Indoor Satin Stretch C3 Corvette CoverKing Car CoverThis car cover is built to the highest quality standards. You can customize colors for base, sides, mirrors, thread, and piping, plus racing stripes!. Made from form-fitting lycra fabric Ultra-plush fleece liner to pamper your car's finish. Designed for indoor use only. Elasticized edges keep dirt and dust out and off the cars painted surface.Coverking's Satin Stretch indoor car cover provides superior protection for your Corvette from dirt, dust, nicks, bumps, and scratches. Made with an elastic synthetic fabric, the cover stretches in all directions and molds to the contours of your Corvette to highlight its design. The cover includes a unique fleece lining allowing for a soft enclosure all around. Each CoverKing Satin Stretch cover is made with your specific vehicle in mind including mirror and antenna pockets to create a complete custom fit. This cover is meant for indoor use only and not intended for outdoor exposure.
Like a fine suit, your cover is made to fit the curves and features of your vehicle. Our designers spent time with your model vehicle and used 3D scanners to record every compound, curve, and detail. That data is used to create a world-class cover with the fewest seams possible. Custom mirror and antenna pockets are sewn in to allow the cover to rest perfectly on your vehicle’s exterior. THE COVERKING ADVANTAGE Coverking designs its own fabrics and works with the world’s leading textile mills to handle manufacturing. With quality assurance teams dedicated to checking every batch of fabric, Coverking ensures that the material used in our products meet the most stringent assessments. We check to see if our material is breathable, allowing for the proper release of moisture. We exposed our fabrics to intense UV rays to make sure our fabrics do not fade over time. We go through a series of stress test to make sure the materials hold up for everyday conditions. Above all, our covers are checked before reaching our customer to ensure quality. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1980, 1981, 1982, 1983 C3 Corvettehttps://www.rpidesigns.com/images/co...ch%20guide.jpghttps://www.rpidesigns.com/images/In...ar%20Cover.jpg https://www.rpidesigns.com/images/sa...ar%20cover.jpg |
