C3 Interior Parts Available At RPI Designs
Rpi Designs is now expanding into the C3 Corvette. We are adding new restoration products every week. Our goal is to be a one stop shop for all of your Corvette needs no matter what generation of Corvette you drive.
Corvette C3 1968-1982 T-Top Center Panel. If you’re replacing worn or faded T-Top Pads, be sure to install a new T-Top Center Panel too. Each panel is accurately reproduced. It is fabricated just as the original car, with vinyl and padding over a strong frame to offer many years of service. Simply remove your original worn part and install our new part. 1978-1982 panels even feature pre-cut dome light openings. Note: These can take 4-5 days to ship as they are made to order if not in stock https://cimg1.ibsrv.net/gimg/www.cor...69af43ee37.jpg Corvette C3 1968-1969 T-Top Center Panel. http://www.rpidesigns.com/shop/item....-panel-black-/ Corvette C3 1970-1972 T-Top Center Panel. https://cimg0.ibsrv.net/gimg/www.cor...1a2c36d043.jpg Corvette C3 1970-1972 T-Top Center Panel http://www.rpidesigns.com/shop/item....center-panel-/ Corvette C3 1973-1974 T-Top Center Panel https://cimg3.ibsrv.net/gimg/www.cor...28e8fcda8f.jpg Corvette C3 1973-1974 T-Top Center Panel http://www.rpidesigns.com/shop/item....center-panel-/ Corvette C3 1975-1977 T-Top Center Panel. https://cimg1.ibsrv.net/gimg/www.cor...93e0bf3097.jpg Corvette C3 1975-1977 T-Top Center Panel. http://www.rpidesigns.com/shop/item....-center-panel/ Corvette C3 1978-1979 T-Top Center Panel. https://cimg6.ibsrv.net/gimg/www.cor...b8c80d4375.jpg Corvette C3 1978-1979 T-Top Center Panel. http://www.rpidesigns.com/shop/item....-center-panel/ Corvette C3 1980-1982 T-Top Center Panel. https://cimg8.ibsrv.net/gimg/www.cor...5530434766.jpg Corvette C3 1980-1982 T-Top Center Panel http://www.rpidesigns.com/shop/item....-center-panel/ Corvette Forum Members Save With Code PHIL5 At Checkout. See These And Many More Parts On Our Website http://www.rpidesigns.com/shop/ |
C3 Corvette Shifter Console Plates
1977-1980 C3 Corvette Shifter Console Plate (plastic) With Power Windows Small Defroster $52.24 With Code PHIL5 At Checkout. Shifter Surround Plates become broken,scratched and faded over time. Our reproduction 1977-1980 automatic transmission shifter surround plate with power windows and rear window defogger is a high quality Corvette reproduction part that will rejuvenate your Corvette interior. *Note: 1977-1980 Early Shifter Surround Plates have a 11/16" High by 13/16" Wide opening for the rear window defogger switch opening. 1980 Late -1982 Shifter Surround Plates have a 1-9/16" High by 13/16" Wide opening for the rear window defogger switch opening. https://cimg6.ibsrv.net/gimg/www.cor...2535d76ed2.jpg http://www.rpidesigns.com/shop/item....all-defroster/ 1977-1982 C3 Corvette Shifter Console Plate (plastic) Without Power Windows Or Defroster $52.24 With Code PHIL5 At Checkout. If your stock Corvette shifter console plate is scratched or broken, our brand new units come with the window switch holes un-punched for a factory look on cars without power windows. This 1977-1982 Corvette shifter console plate with automatic transmission and crank windows will give you an entirely new looking console! https://cimg8.ibsrv.net/gimg/www.cor...7ad595e3c5.jpg http://www.rpidesigns.com/shop/item....-or-defroster/ 1977-1982 C3 Corvette Shifter Console Plate (plastic) With Power Windows Only $52.24 With Code PHIL5 At Checkout. If your stock Corvette shifter console plate is scratched or broken, our brand new units will help your car look like new. This shifter console plate comes with the window switch holes punched for a factory look on cars with power windows. https://cimg1.ibsrv.net/gimg/www.cor...b3b5af2acf.jpg http://www.rpidesigns.com/shop/item....-windows-only/ 1980-1982 C3 Corvette Shifter Console Plate (plastic) With Defroster, Power Windows and Power Mirrors $52.24 With Code PHIL5 At Checkout. If your stock Corvette shifter console plate is scratched or broken, our brand new units will help your car look like new. Our 1980-1982 automatic transmission with Power Windows, Power Mirrors and Rear Window Defogger shifter console plate is just what you need to give your car a factory new look. https://cimg3.ibsrv.net/gimg/www.cor...b94b201665.jpg http://www.rpidesigns.com/shop/item....power-mirrors/ 1981-1982 C3 Corvette Shifter Console Plate (plastic) Power Windows Power Mirror No Defrost $47.49 With Code PHIL5 At Checkout. If your stock Corvette shifter console plate is scratched or broken, our brand new units will help your car look like new. Our 1981-1982 automatic transmission with Power Windows, Power Mirrors and No Rear Window Defogger shifter console plate is just what you need to give your car a factory new look. https://cimg7.ibsrv.net/gimg/www.cor...a97aff123d.jpg http://www.rpidesigns.com/shop/item....or-no-defrost/ 1981-1982 C3 Corvette Shifter Console Plate (plastic) With Power Windows And Defrost $52.24 With Code PHIL5 At Checkout. If your stock Corvette shifter console plate is scratched or broken, our brand new units will help your car look like new. Our 1981-1982 automatic transmission with Power Windows and Rear Window Defogger shifter console plate is just what you need to give your car a factory new look. https://cimg3.ibsrv.net/gimg/www.cor...80591cbc09.jpg http://www.rpidesigns.com/shop/item....-and-defrost-/ 1982 C3 Corvette Collectors Edition Shifter Console Plate (plastic) With Power Windows And Defrost $113.99 With Code PHIL5 At Checkout. If your stock Corvette shifter console plate is scratched or broken, our brand new units will help your car look like new. Our 1982 automatic transmission with Power Windows and Rear Window Defogger shifter console plate is just what you need to give your car a factory new look. https://cimg9.ibsrv.net/gimg/www.cor...00def6f1f6.jpg http://www.rpidesigns.com/shop/item....-and-defrost-/ Corvette Forum Members Save With Code PHIL5 At Checkout. See these and many more parts on our website. http://www.rpidesigns.com/ |
C3 Corvette Parking Brake Console
C3 Corvette Parking Brake Console And Parts
1968-1976 C3 Corvette Parking Brake Console Reinforcement With Trim Ring $37.99 With Code PHIL5 At Checkout. Replace your broken or missing parking brake console reinforcement with trim ring. Correct in design and fit, ours is the best available in the industry! Fits 1968-1976 Corvette Bezel Only, Parking Brake Console Sold Separately Reproduction of Original https://cimg9.ibsrv.net/gimg/www.cor...ed83f31fa8.jpg http://www.rpidesigns.com/shop/item....ith-trim-ring/ 1968-1976 C3 Corvette Parking Brake Console Rear Mount $22.79 With Code PHIL5 At Checkout. Replace your broken or missing parking brake console rear mount reinforcement. Correct in design and fit, ours is the best available in the industry! https://cimg4.ibsrv.net/gimg/www.cor...37e3cc95ac.jpg http://www.rpidesigns.com/shop/item....le-rear-mount/ 1968 C3 Corvette Parking Brake Console With Power Windows And Seat Belt Holes $42.74 With Code PHIL5 At Checkout. (black) If your Parking Brake Console is cracked or has broken over the years, replace it today with this piece, which is correct in design and fit. This 1968 model fits all models with power windows and arrives in a standard black finish. Unit can be painted to match any original 1968 color with interior spray dye. https://cimg6.ibsrv.net/gimg/www.cor...cd980e1976.jpg http://www.rpidesigns.com/shop/item....ower-windows-/ 1968 C3 Corvette Parking Brake Console Without Power Windows (black) $42.74 With Code PHIL5 At Checkout. If your Parking Brake Console is cracked or has broken over the years, replace it today with this piece, which is correct in design and fit. This 1968 model fits all models without power windows and arrives in a standard black finish. Unit can be painted to match any original 1968 color with interior spray dye. https://cimg8.ibsrv.net/gimg/www.cor...f84f1b1b9a.jpg http://www.rpidesigns.com/shop/item....ower-windows-/ 1969-1976 C3 Corvette Parking Brake Console With Power Windows (black) $42.74 With Code PHIL5 At Checkout. If your Parking Brake Console is cracked or has broken over the years, replace it today with this piece, which is correct in design and fit. This fits 1969-1976 models and fits all models with power windows and arrives in a standard black finish. Unit can be painted to match any original 1969-1976 color with interior spray dye. https://cimg2.ibsrv.net/gimg/www.cor...d5c2cef690.jpg http://www.rpidesigns.com/shop/item....power-windows/ 1969-1976 C3 Corvette Parking Brake Console Without Power Windows (black) $42.74 With Code PHIL5 At Checkout. If your Parking Brake Console is cracked or has broken over the years, replace it today with this piece, which is correct in design and fit. This fits 1969-1976 models and fits all models without power windows and arrives in a standard black finish. Unit can be painted to match any original 1969-1976 color with interior spray dye. https://cimg5.ibsrv.net/gimg/www.cor...b31453a556.jpg http://www.rpidesigns.com/shop/item....ower-windows-/ 1978-1980 C3 Corvette Parking Brake Console $33.24 With Code PHIL5 At Checkout. If your Parking Brake Console is cracked or has broken over the years, replace it today with this piece, which is correct in design and fit. This fits 1978-1980 models and fits all models. Available in your choice of five colors. https://cimg6.ibsrv.net/gimg/www.cor...8aad600319.jpg http://www.rpidesigns.com/shop/item....rake-console-/ Corvette Forum Members Save With Code PHIL5 At Checkout. See these and many more parts on our website. www.rpidesigns.com |
C3 Corvette 1970-1976 Woodgrain Console Trim, Auto Shift Indicator Lens And Pointer
Is your Corvette woodgrain trim torn or faded? Then our brand new trim will help your car look like new again. Our 1970-1976 woodgrain console trim is just what you need to give your car a factory new look.
1970-1971 C3 Corvette Woodgrain Console Without AC $18.99 With Code PHIL5 At Checkout. https://cimg2.ibsrv.net/gimg/www.cor...4b53554e4f.jpg http://www.rpidesigns.com/shop/item....le-without-ac/ 1970-1971 C3 Corvette Woodgrain Console With AC $18.99 With Code PHIL5 At Checkout. https://cimg5.ibsrv.net/gimg/www.cor...7086f0ceef.jpg http://www.rpidesigns.com/shop/item....nsole-with-ac/ 1972-1976 C3 Corvette Woodgrain Console With AC $18.99 With Code PHIL5 At Checkout. https://cimg1.ibsrv.net/gimg/www.cor...dac7c111c5.jpg http://www.rpidesigns.com/shop/item....sole-with-ac-/ 1972-1976 C3 Corvette Woodgrain Console Without AC $18.99 With Code PHIL5 At Checkout. https://cimg2.ibsrv.net/gimg/www.cor...07ab9750f2.jpg http://www.rpidesigns.com/shop/item....le-without-ac/ 1977-1982 C3 Corvette Shifter Indicator Lens For Automatic Transmission $20.89 With Code PHIL5 At Checkout. Is your stock Corvette shift indicator lens broken, missing or scratched? Then our brand new units will help your car look like new again.Our 1977- 1982 automatic transmission shift indicator lens is just what you need to give your car a factory new look. https://cimg3.ibsrv.net/gimg/www.cor...c12e62dc31.jpg http://www.rpidesigns.com/shop/item....-transmission/ 1977-1982 C3 Corvette Shifter Indicator For Automatic Transmission $5.69 With Code PHIL5 At Checkout. Is your stock Corvette shift indicator broken, missing or faded? Then our brand new units will help your car look like new again. Our 1977- 1982 automatic transmission shift indicator is just what you need to give your car a factory new look. https://cimg4.ibsrv.net/gimg/www.cor...b0d89cf8cd.jpg http://www.rpidesigns.com/shop/item....-transmission/ Corvette Forum Members Save With Code PHIL5 At Checkout. See these and many more parts on our website. www.rpidesigns.com |
Corvette C3 T-Top Storage Bags Black With 1968-1982
Corvette C3 T-Top Storage Bags Black With 1968-1976 Logo $84.54 With Code PHIL5 At Checkout.
Keep your expensive stock or glass top panels safe and scratch-free with a C3 Corvette T-Top Panel Bag. Each bag is handcrafted from a soft, leather-look and feel vinyl with cotton fleece lining, micro-stitched seam and Velcro fasteners. C3 Corvette T-Top Panel Storage Bags are sold in LH and RH pairs. Fit All 1968-1982 Corvette Compatible with Painted and Glass T-Top Panels Durable Vinyl Construction Soft Cotton Cushion Lining Convenient Velcro Closures LH & RH Pair https://cimg6.ibsrv.net/gimg/www.cor...7ee56d89e9.jpg http://www.rpidesigns.com/shop/item....th-68-76-logo/ Corvette C3 T-Top Storage Bags Black With 1977-1979 Logo $84.54 With Code PHIL5 At Checkout. https://cimg3.ibsrv.net/gimg/www.cor...bd4e116ec4.jpg http://www.rpidesigns.com/shop/item....77-1979-logo-/ Corvette C3 T-Top Storage Bags Black With 1980 Logo $84.54 With Code PHIL5 At Checkout. https://cimg6.ibsrv.net/gimg/www.cor...4b3d2d288b.jpg http://www.rpidesigns.com/shop/item....th-1980-logo-/ Corvette C3 T-Top Storage Bags Black With 1981 Logo $84.54 With Code PHIL5 At Checkout. https://cimg3.ibsrv.net/gimg/www.cor...74a8c310e7.jpg http://www.rpidesigns.com/shop/item....th-1981-logo-/ Corvette C3 T-Top Storage Bags Black With 1982 Collector Edition Logo $84.54 With Code PHIL5 At Checkout. https://cimg4.ibsrv.net/gimg/www.cor...8917cbb0b2.jpg http://www.rpidesigns.com/shop/item....edition-logo-/ Corvette Forum Members Save With Code PHIL5 At Checkout. See these and many more parts on our website. www.rpidesigns.com |
C3 Corvette Seat Backs, Chrome Seat Trim And Interior Switches
1968-1969 C3 Corvette Seat Back Driver or Passenger $42.75 With Code PHIL5 At Checkout
When it comes time to replace your seat back on your 1968-1969 C3 Corvette you do have some choices on where to purchase. We truly feel we have a superior product that you'll be happy you purchased. We offer these in a black finish that can be painted to match your interior. The driver and passenger side are the same. Fitment: 1968, 1969 C3 Corvette Stock photos for illustration only https://cimg0.ibsrv.net/gimg/www.cor...b3722232be.jpg http://www.rpidesigns.com/shop/item....-or-passenger/ 1970-1978 C3 Corvette Seat Back Driver or Passenger $42.75 With Code PHIL5 At Checkout https://cimg7.ibsrv.net/gimg/www.cor...0fe7c7c37e.jpg http://www.rpidesigns.com/shop/item....-or-passenger/ 1968-1974 C3 Early Corvette Chrome Seat Side Rails Set $189.99 With Code PHIL5 At Checkout Let's face it, after 40 years of normal wear and tear your C3 chrome seat side rails are probably looking like they might need to be replaced. We carry a very nice quality reproduction set, that includes all four pieces and hardware. These 1968-1974 Corvette seat side rails will really show a nice touch to your restoration. https://cimg3.ibsrv.net/gimg/www.cor...948a2ab991.jpg http://www.rpidesigns.com/shop/item....ide-rails-set/ 1974 Late -1978 C3 Corvette Chrome Seat Side Rails Set $189.99 With Code PHIL5 At Checkout https://cimg8.ibsrv.net/gimg/www.cor...9c7237f82d.jpg http://www.rpidesigns.com/shop/item....ide-rails-set/ 1977 C3 Corvette Turn Signal Lever $20.89 With Code PHIL5 At Checkout When the time comes to replace your turn signal lever then you'll want to be sure you get the lever from a good Corvette parts supplier. RPI Designs is pleased to bring you this reproduction 1977 C3 Corvette turn signal lever. This lever is without cruise control and with tilt and telescoping. https://cimg4.ibsrv.net/gimg/www.cor...def818e852.jpg http://www.rpidesigns.com/shop/item....-signal-lever/ 1968-1982 C3 Corvette Power Window Switch $18.04 With Code PHIL5 At Checkout It's hot and you want to roll down your windows in your 1968-82 Corvette...and your switches are not working! We have a very nice quality reproduction switch available for the C3 Corvette. Our reproduction switch is chrome like original and fits both the driver and passenger side. Buy the set and save. https://cimg5.ibsrv.net/gimg/www.cor...437ec6afd0.jpg http://www.rpidesigns.com/shop/item....window-switch/ 1978-1980 C3 Corvette Rear Window Defrost Switch $45.59 With Code PHIL5 At Checkout Nothing's worse than starting your Corvette up on a cold morning and jumping in the car only to find out your cannot defrost your rear window! We have a very nice and accurate reproduction 1978-1980 C3 Corvette rear window defroster switch. This reproduction switch replaces your original switch, simply pull out your old switch and replace with this reproduction. https://cimg2.ibsrv.net/gimg/www.cor...2b30a38e6f.jpg http://www.rpidesigns.com/shop/item....efrost-switch/ 1978 C3 Corvette T-Top Alarm Switches $23.74 With Code PHIL5 At Checkout Often times one of the last things to wear out in the switch department is the T-Top alarm switches on the 1978 C3 Corvette. We've come up with a very nice reproduction set. Our switches are available for the left hand and right-hand side of the car. You can purchase both and save. https://cimg9.ibsrv.net/gimg/www.cor...af083f5570.jpg http://www.rpidesigns.com/shop/item....larm-switches/ 1979-1982 C3 Corvette T-Top Alarm Switches $23.74 With Code PHIL5 At Checkout https://cimg7.ibsrv.net/gimg/www.cor...8c7e09014d.jpg http://www.rpidesigns.com/shop/item....larm-switches/ 1968-1976 C3 Corvette Reproduction Wiper Switch $26.59 With Code PHIL5 At Checkout C3 owners know that the wiper switch from the factory will wear out and fail over time. We have a very nice reproduction 1968-1976 Corvette wiper switch that is the same size, shape, and function as the original switch. https://cimg7.ibsrv.net/gimg/www.cor...91c7276b3b.jpg https://www.rpidesigns.com/shop/item...-reproduction/ Corvette Forum Members Save With Code PHIL5 At Checkout. See these and many more parts on our website. www.rpidesigns.com |
1977-1982 C3 Corvette Center Gauge Bezels
Replace your broken or missing 1977-1982 C3 Corvette center gauge bezel with our high-quality reproduction. Our reproduction center gauge bezel will help you bring your car back it's showroom good looks. 1977 C3 Corvette Center Gauge Bezel And Clock Surround $82.65 With Code PHIL5 At Checkout. http://www.rpidesigns.com/shop/item....lock-surround/ 1978-1981 C3 Corvette Center Gauge Bezel And Clock Surround $82.65 With Code PHIL5 At Checkout. http://www.rpidesigns.com/shop/item....lock-surround/ 1981-1982 C3 Corvette Center Gauge Bezel With Oil Temp Gauge $82.65 With Code PHIL5 At Checkout. http://www.rpidesigns.com/shop/item....il-temp-gauge/ 1982 C3 Corvette Center Gauge Bezel For The Collector Car Edition $141.55 With Code PHIL5 At Checkout. http://www.rpidesigns.com/shop/item....r-car-edition/ https://cimg2.ibsrv.net/gimg/www.cor...f4ee1e33f2.jpg https://cimg4.ibsrv.net/gimg/www.cor...032dbd5717.jpg Corvette Forum Members Save With Code PHIL5 At Checkout. See these and many more parts on our website. www.rpidesigns.com |
1977-1982 C3 Corvette Heater / Air Conditioning Control Panel Unit
C3 Corvette Heater / Air Conditioning Control Panel Unit for 1977-1978 $131.09 With code PHIL5 At Checkout
This reproduction heater/ac control panel is 100% factory correct. The 1977 and 1978 C3 Corvette used a different electronic plug than 79+ models. So be careful with other companies combining 1977-1982 together, that is not accurate. This reproduction heater / AC control unit includes the clear plastic face cover panel as the original. We guarantee you will not find a more accurate or correct reproduction on the market. When quality counts! https://cimg5.ibsrv.net/gimg/www.cor...40e2aeff16.jpg https://cimg8.ibsrv.net/gimg/www.cor...fdb168f911.jpg https://www.rpidesigns.com/shop/item...nit-1977-1978/ C3 Corvette Heater / Air Conditioning Control Panel Unit for 1979 $131.09 With code PHIL5 At Checkout https://cimg2.ibsrv.net/gimg/www.cor...2c2d412f7a.jpg https://cimg3.ibsrv.net/gimg/www.cor...27e5c7f8dc.jpg https://www.rpidesigns.com/shop/item...nel-unit-1979/ C3 Corvette Heater / Air Conditioning Control Panel Unit for 1980-1982 $131.09 With code PHIL5 At Checkout https://cimg2.ibsrv.net/gimg/www.cor...d0acdbeae9.jpg https://cimg9.ibsrv.net/gimg/www.cor...1250be0d34.jpg https://www.rpidesigns.com/shop/item...nit-1980-1982/ |
C3 Horn Button Emblems
C3 Corvette Horn Button Emblem Kits
Replacing your worn out and scratched C3 Corvette horn button emblem is a great way to return your Corvettes interior back to its showroom condition. This Corvette reproduction horn button has been manufactured to original factory specifications using today's modern manufacturing techniques. You will find the fit and function will work superbly for your restoration. 1978 C3 Corvette Anniversary Horn Button Emblem Kit $38.00 With Code PHIL5 At Checkout. https://cimg9.ibsrv.net/gimg/www.cor...141e1ddac0.jpg https://www.rpidesigns.com/shop/item...on-emblem-kit/ 1980 and 1981 C3 Corvette Horn Button Emblem Kit $33.25 With Code PHIL5 At Checkout. https://cimg8.ibsrv.net/gimg/www.cor...7778106ce5.jpg https://www.rpidesigns.com/shop/item...on-emblem-kit/ 1977-1982 C3 Corvette Horn Buttons $19.00 With Code PHIL5 At Checkout. https://cimg6.ibsrv.net/gimg/www.cor...3886f944e6.jpg https://www.rpidesigns.com/shop/item...-horn-buttons/ 1982 C3 Corvette Horn Button Emblem Kit $33.25 With Code PHIL5 At Checkout. https://cimg3.ibsrv.net/gimg/www.cor...300dee0f22.jpg https://www.rpidesigns.com/shop/item...on-emblem-kit/ 1977 and 1979 C3 Corvette Horn Button Emblem Kit $33.25 With Code PHIL5 At Checkout. https://cimg2.ibsrv.net/gimg/www.cor...42cb7b2dc7.jpg https://www.rpidesigns.com/shop/item...on-emblem-kit/ 1969-1982 C3 Corvette Horn Button Retainer and Contact Retainer $14.25 With Code PHIL5 At Checkout. https://cimg7.ibsrv.net/gimg/www.cor...9acf5e0cf4.jpg https://www.rpidesigns.com/shop/item...tact-retainer/ |
1968-1982 Heater Ducts and Vents
Replace the lower duct under your dash for your C3 Corvette. You ducts go through a wide range of elements throughout the years. They often turn brittle and crack and will no longer connect properly. Our ducts are made from a durable material and are durable enough to withstand a wide range of temperatures.
1969-1973 C3 Corvette Under Dash AC/Heater Duct LH $76.00 With Code PHIL5 At Checkout https://cimg1.ibsrv.net/gimg/www.cor...dae0e618c0.jpg https://www.rpidesigns.com/shop/item...eater-duct-lh/ 1978-1982 C3 Corvette Under Dash AC/Heater Duct LH No Bracket $76.00 With Code PHIL5 At Checkout https://cimg5.ibsrv.net/gimg/www.cor...f8e5fe4f31.jpg https://www.rpidesigns.com/shop/item...lh-no-bracket/ 1969-1977 C3 Corvette Under Dash Duct Non-AC $23.75 With Code PHIL5 At Checkout https://cimg1.ibsrv.net/gimg/www.cor...04c098ea8c.jpg https://www.rpidesigns.com/shop/item...h-duct-non-ac/ 1968-1977 C3 Corvette Non AC In Dash Center Ductl $24.65 With Code PHIL5 At Checkout https://cimg0.ibsrv.net/gimg/www.cor...b5ed1ec000.jpg https://www.rpidesigns.com/shop/item...h-center-duct/ 1977-1982 C3 Corvette Center Dash Vent With Chrome Trim $15.20 With Code PHIL5 At Checkout https://cimg5.ibsrv.net/gimg/www.cor...2c81ec19f1.jpg https://www.rpidesigns.com/shop/item...h-chrome-trim/ 1969-1977 C3 Corvette Center Dash Vent (chrome) $18.05 With Code PHIL5 At Checkout https://cimg0.ibsrv.net/gimg/www.cor...0fadcb0658.jpg https://www.rpidesigns.com/shop/item...h-vent-chrome/ 1974-1975 C3 Corvette Defrost Bezel $26.60 With Code PHIL5 At Checkout https://cimg3.ibsrv.net/gimg/www.cor...0f8cb75872.jpg https://www.rpidesigns.com/shop/item...froster-bezel/ |
1968-1978 Corvette C3 Seat Backs
1968-1978 Corvette C3 Seat Backs $45.60 With Code PHIL5 At Checkout.
A quick and easy way to dress up your interior is to replace the worn and scratched plastic seat back with our quality reproduction. These seat backs will arrive in the color of your choice so there is no need to buy messy spray paints to color your seat backs to match the rest of your interior. Your seat backs are easy to replace and they make a quick, inexpensive improvement to your interior. Just fasten them into place. Seat Back Metal Retainers are NOT required with these seat backs. Fitment: 1968, 1967, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978 Corvette https://cimg2.ibsrv.net/gimg/www.cor...15ad53c427.jpg https://www.rpidesigns.com/shop/item...3-seat-backs-/ |
1968-1978 C3 Corvette Seat Foam 4 Piece Set
If you are driving your C3 Corvette with the factory foam still in your seats now is the time to replace it with some fresh foam. Our 1968-1977 C3 Corvette Seat Foam 4 Piece Set will replace all of the foam in both of your seats giving you the brand new feel that your seats have not had in years. Corvette America Seat Foam is correctly formed and includes pre-installed wire supports where applicable.
1968-1969 C3 Corvette Seat Foam 4 Piece Set $207.10 With Code PHIL5 A Checkout. https://cimg6.ibsrv.net/gimg/www.cor...853ef59274.jpg https://www.rpidesigns.com/shop/item...m-4-piece-set/ 1970-1974 C3 Corvette Seat Foam 4 Piece Set $207.10 With Code PHIL5 A Checkout. https://cimg1.ibsrv.net/gimg/www.cor...2a6c424656.jpg https://www.rpidesigns.com/shop/item...m-4-piece-set/ 1975 C3 Corvette Seat Foam 4 Piece Set $207.10 With Code PHIL5 A Checkout. https://cimg0.ibsrv.net/gimg/www.cor...2cef755826.jpg https://www.rpidesigns.com/shop/item...m-4-piece-set/ 1976-1978 C3 Corvette Seat Foam 4 Piece Set $207.10 With Code PHIL5 A Checkout. https://cimg9.ibsrv.net/gimg/www.cor...8da03d40d7.png https://www.rpidesigns.com/shop/item...m-4-piece-set/ |
1968-1982 Corvette Power Window Motor Drivers Side $85.49 With Code PHIL5 At Checkout
Do not put your old worn out power window motor back on your fresh restoration. Time and water will ruin your power window motor leaving it rusted and no longer working. Our reproduction motor will fit and function as the original. https://cimg3.ibsrv.net/gimg/www.cor...4c974c93e5.jpg https://www.rpidesigns.com/shop/item...-drivers-side/ 1968-1982 Corvette Power Window Motor Passengers Side $85.49 With Code PHIL5 At Checkout Do not put your old worn out power window motor back on your fresh restoration. Time and water will ruin your power window motor leaving it rusted and no longer working. Our reproduction motor will fit and function as the original. https://cimg0.ibsrv.net/gimg/www.cor...1980d58fab.jpg https://www.rpidesigns.com/shop/item...ssengers-side/ 1968-1977 C3 Corvette Speedo/Tach Lens And Center Gauge Lens Set $46.55 With Code PHIL5 At Checkout Replace all of your clear gauge lenses with our easy money saving lens set. Our set included one center gauge cluster lens and a pair of Speedometer and Tachometer lenses. https://cimg5.ibsrv.net/gimg/www.cor...d446d548df.jpg https://www.rpidesigns.com/shop/item...auge-lens-set/ 1969-1977 C3 Corvette Door Latch Assembly $111.15 With Code PHIL5 At Checkout Replace your broken or missing 1969-1977 C3 Corvette Door Latch Assembly with our high-quality reproduction. Stop fighting with your old rusted door latch assembly. Our reproduction door latch assembly will help you bring the door of your car back it's showroom ease of use again. https://cimg0.ibsrv.net/gimg/www.cor...7fab9d8227.jpg https://www.rpidesigns.com/shop/item...atch-assembly/ 1978-1982 C3 Corvette Door Latch Assembly $111.15 With Code PHIL5 At Checkout https://cimg8.ibsrv.net/gimg/www.cor...0693bcb68a.jpg https://www.rpidesigns.com/shop/item...atch-assembly/ |
1978-1982 C3 Corvette Sunvisor Vanity Mirror $104.50 With Code PHIL5 At Checkout
These vanity mirrors will add a renewed look to the interior of your C3 Corvette. These reproduction C3 Corvette vanity mirrors are available in several factory colors. They will fit the 1978-1982 C3 Corvette and install just like the original vanity mirrors. Factory Colors Available - Black, Red, Doeskin, Oyster and Dark Blue Reproduction of Original Fitment: 1978, 1979, 1980, 1981, 1982 C3 Corvette https://cimg7.ibsrv.net/gimg/www.cor...aaddafa5d4.jpg https://www.rpidesigns.com/shop/item...vanity-mirror/ 1969-1976 C3 Corvette Sunvisor Hardware Pin Set $23.75 With Code PHIL5 At Checkout This 4 piece set of 1969-1976 C3 Corvette Sunvisor Hardware Pin Set will replace your rusted or missing original parts. Fitment: 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976 C3 Corvette https://cimg1.ibsrv.net/gimg/www.cor...633cdfa8c2.jpg https://www.rpidesigns.com/shop/item...dware-pin-set/ 1968-1977 C3 Corvette Kick Panels $37.05 With Code PHIL5 At Checkout The kick panels in your car take a lot of abuse over the years. With our quality reproduction kick panels, you will no longer have to deal with your broken or scratched originals.These fit great and will get you interior looking like new quickly and easily. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977 C3 Corvette https://cimg5.ibsrv.net/gimg/www.cor...750ae158a3.jpg https://www.rpidesigns.com/shop/item...e-kick-panels/ 1968-1977 C3 Corvette Door Lock Knob $14.25 With Code PHIL5 At Checkout Replace your broken or missing 1968-1977 C3 Corvette Door Lock Knob with our high-quality reproduction. Replacing your door lock knob will help you bring the door of your car back it's showroom good looks again. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977 C3 Corvette. https://cimg9.ibsrv.net/gimg/www.cor...b9cc583fb8.jpg https://www.rpidesigns.com/shop/item...oor-lock-knob/ 1968-1977 C3 Corvette Inside Door Handles (Pair) $37.05 With Code PHIL5 At Checkout Replace your damaged 1968-1977 C3 Corvette Inside Door Handles with our high-quality reproductions. Our C3 Corvette inside door handle pulls will help bring back that new car look.If years of sun and use have ruined your inside door handle pulls our reproduction inside door handle pulls will help bring back that new car looks your Corvette deserves. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977 C3 Corvette. https://cimg4.ibsrv.net/gimg/www.cor...d37662d796.png https://www.rpidesigns.com/shop/item...-handles-pair/ 1978-1982 C3 Corvette Door Handle Bezel $27.55 With Code PHIL5 At Checkout Replace your damaged 1978-1982 C3 Corvette Door Handle Bezel with our high-quality reproduction. Our door handle bezel will help bring back that new car look.If years of sun and use have ruined your door handle bezels our reproduction door handle bezels will help bring back that new car look your Corvette deserves. Available in a variety of factory colors to match your interior. Fitment: 1978, 1979, 1980, 1981, 1982 C3 Corvette. https://cimg8.ibsrv.net/gimg/www.cor...d621d51f18.jpg https://www.rpidesigns.com/shop/item.aspx/1978-1982-c3-corvette-door-door-handle-bezel/ 1978-1982 C3 Corvette Door Armrest $122.55 With Code PHIL5 At Checkout Replace your broken or damaged 1978-1982 C3 Corvette Door Armrest with our high-quality reproduction. If years of sun and use have ruined your armrests our reproduction armrests will help bring back that new car looks your Corvette deserves. Available in a variety of factory colors to match your interior. Please contact us if you do not see the color you need for your car. Fitment: 1978, 1979, 1980, 1981, 1982 C3 Corvette. https://cimg3.ibsrv.net/gimg/www.cor...ef10b8178b.jpg https://www.rpidesigns.com/shop/item...-door-armrest/ 1969-1977 C3 Corvette Door Handle Pulls $19.00 With Code PHIL5 At Checkout Replace your damaged 1965 And 1969-1977 C3 Corvette Door Handle Pulls with our high-quality reproductions. Our C3 Corvette door handle pulls will help bring back that new car look.If years of sun and use have ruined your door handle pulls our reproduction door handle pulls will help bring back that new car looks your Corvette deserves. Available in a variety of factory colors to match your interior. Fitment: 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977 C3 Corvette. https://cimg2.ibsrv.net/gimg/www.cor...7739d61c98.jpg https://www.rpidesigns.com/shop/item...-handle-pulls/ 1968-1977 C3 Corvette Door Sill Plates $ 37.05 With Code PHIL5 At Checkout The first thing you notice when you open the doors of your car is the sill plates. If your sill plates are looking a little worn out our reproduction sill plates will have your car looking like new. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977 C3 Corvette https://cimg6.ibsrv.net/gimg/www.cor...82bc33b0dc.jpg https://www.rpidesigns.com/shop/item...r-sill-plates/ 1978-1982 C3 Corvette Door Sill Plates $28.50 With Code PHIL5 At Checkout The first thing you notice when you open the doors of your car is the sill plates. If your sill plates are looking a little worn out our reproduction sill plates will have your car looking like new. Fitment: 1978, 1979, 1980, 1981, 1982 C3 Corvette https://cimg3.ibsrv.net/gimg/www.cor...48b3a4baba.jpg https://www.rpidesigns.com/shop/item...r-sill-plates/ 1968-1976 C3 Corvette Inside Rear View Mirror $37.04 With Code PHIL5 At Checkout Over time the silver on your rear view mirror will start to delaminate leaving dark spots on your mirror. Our reproduction inside rear view mirror will take car of that problem and give you a beautiful reflection once again. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976 Corvette https://cimg6.ibsrv.net/gimg/www.cor...c131fad1fd.jpg https://www.rpidesigns.com/shop/item...r-view-mirror/ 1968-1977 C3 Corvette Rear Window Latch Bezel $18.05 With Code PHIL5 At Checkout This is a reproduction steel bezel for 1968-1970 Corvette "Pop-Out" rear window. This steel bezel can be painted to match your interior color. These can be used on 1971-1977 Corvettes if you would like to add this option to your later C3 Corvette. Fitment: 1968, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977 C3 Corvette https://cimg3.ibsrv.net/gimg/www.cor...104e5051ca.jpg https://www.rpidesigns.com/shop/item...w-latch-bezel/ |
1968-1982 C3 Corvette Interior Screw Kits $28.49 With Code PHIL5 At Checkout
When restoring your interior one of the most frustrating things is finding all of the missing screws to reassemble your interior. Our kits come complete with all of the needed screws in neatly marked bags so that you will know where everything goes. https://cimg9.ibsrv.net/gimg/www.cor...61634b99b3.jpg https://www.rpidesigns.com/shop/item...or-screw-kits/ 1968-1982 C3 Corvette Pedal Pads $6.65 With code PHIL5 At Checkout 1968-1982 C3 Corvette Brake or Clutch Pedal Pad https://www.rpidesigns.com/shop/item...tch-pedal-pad/ 1968-1982 C3 Corvette Brake Pedal Pad For Automatic Transmission https://www.rpidesigns.com/shop/item...-transmission/ 1968-2008 Corvette Gas Pedal https://www.rpidesigns.com/shop/item...tte-gas-pedal/ 1980-1981 C3 Corvette Clutch Pedal Pad For Manual Transmission https://www.rpidesigns.com/shop/item...-transmission/ 1980-1981 C3 Corvette Brake Pedal Pad For Manual Transmission https://www.rpidesigns.com/shop/item...-transmission/ https://cimg1.ibsrv.net/gimg/www.cor...2eab0ce98c.jpg 1980-1981 C3 Corvette Brake Pedal Pad For Manual Transmission https://cimg2.ibsrv.net/gimg/www.cor...5830a362f3.jpg 1968-2008 Corvette Gas Pedal https://cimg5.ibsrv.net/gimg/www.cor...a8076deb8c.jpg 1968-1982 C3 Corvette Brake or Clutch Pedal Pad |
1968-1975 C3 Corvette Heater Control Reface Kit $79.89 With Code PHIL5 At Checkout
https://cimg9.ibsrv.net/gimg/www.cor...f7d24e6dd0.png https://cimg1.ibsrv.net/gimg/www.cor...bd57b7f644.jpg https://www.rpidesigns.com/shop/cate...-parts/?page=2 1968 C3 Corvette Heater Control Unit Complete $197.45 With Code PHIL5 At Checkout https://cimg8.ibsrv.net/gimg/www.cor...55c17f0813.jpg Without AC https://www.rpidesigns.com/shop/item...te-without-ac/ https://cimg0.ibsrv.net/gimg/www.cor...3e33505991.jpg With AC https://www.rpidesigns.com/shop/item...plete-with-ac/ |
Thank you for the orders!
1970-1982 C3 Corvette Clock Conversion Kit Quartz Subassembly $79.15Do it yourself and save with this 1970-1982 C3 Corvette Clock Conversion Kit Quartz Subassembly from RPI Designs and your restoration project will shine. Or you can replace that non-working part with this quality made quartz clock.Fitment: 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980, 1981, 1982 C3 Corvettehttps://www.rpidesigns.com/shop/item...on-kit-quartz/ https://www.rpidesigns.com/images/19...Quartz%20s.jpg https://www.rpidesigns.com/images/19...Quartz%20p.jpg |
1968-1982 C3 Corvette Leather-Like Seat Covers $328.99A quick and easy way to dress up your interior is to replace the worn and scratched seat covers with our quality reproduction 1968-1982 C3 Corvette Leather-Like Seat Covers.Unfortunately, your C3 Corvette seat covers have probably seen better days. After decades and decades of continuous use, these are bound to wear out and in need of a replacement. We have very accurate reproductions available in nearly every color that General Motors offered from the factory. These Leather-Like Seat Covers look and feel just like real leather but at a fraction of the price! These seat covers are made of premium vinyl that will rival the appearance of real leather. Our C3 Corvette seat covers are made specifically to match exactly the originals with the correct grain and stitching patterns that vary from year to year. https://www.rpidesigns.com/shop/item...e-seat-covers/ Fitment: 1968, 1967, 1969, 1970, 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980, 1981, 1982 C3 Corvettehttps://www.rpidesigns.com/images/19...t-covers-4.jpg |
