C7 recalls
sitting in my dealer waiting room while they reprogram the airbag and seat belt item and the service tech tells me there is a new campaign on the vented seats. Getting both done now.
What is the vented seat issue? I also see the cooler temps have now brought my cold tire pressure down about 3 lbs to 32. Having them add some air per base 2016 spec. |
The Service Tech is the person to ask, since you are right there and he is going to do the work.
If I remember correctly the vented seat issue had something to do with them not working when the car is started remotely. Software update fixes this.
You trust the tech to add the right amount of air. LOL
You trust the tech to add the right amount of air. LOL.
A friend of mine with a '16 C7 had a recall that had to do with the front brake rotor. I have not seen nor heard of this yet, but I'm waiting. Apparently they were not torqued correctly.
Folks are talking about two different things here. Recalls and Technical Service Bulletins (TSB), also known as "campaigns," are two different things.
Recalls are for safety reasons, and a car cannot be re-sold without being completed. TSBs are optional for customers reporting issues, and are often issued when widespread non-safety related issues are substantiated. There was a TSB for brake rotors, but it was for 14 Z51 models which came w/ 2-piece rotors. I haven't heard of any subsequent campaigns for brake rotors. |
The seat cooling/heating correction is for remote start.
The seats would not heat(if left on when car was shutdown) when the car was remote started. Some issues with this software fix are: You may have to reset your passive door lock settings (look in menu, vehicle, passive lock settings). The drive mod and dash display settings may be different then before the upgrade. Don't remember the path ex. set: display linked to driver mod. |
Originally Posted by fredmills
(Post 1593333358)
The seat TSB is this I believe....I had not read about it here: TSB Number: SB-37030 NHTSA Number: 10078776 TSB Date: April 21, 2016 Date Added to File: August 17, 2016 Failing Component: Seats:Front Assembly:Seat Heater/Cooler |
Originally Posted by Foosh
(Post 1593333526)
When I got it done (because of pulsing) they only replaced the front as the rears checked out fine. It resolved the issue. |
Info: Today received mail advice ("OWNER NOTICE" from GM Canada) called "Special Coverage Program 16009".
Basically making 'awareness' that some 2014 Corvettes may have a condition where a fuel odour is detected, fuel droplets appear below the left-hand fuel tank (driver side) with fuel gauge level above 1/2, or a malfunction indicator lamp illuminates due to a leak path in the driver side fuel tank at the Inlet Check Valve (ICV) to fuel tank shell interface". Goes on to state ...."Do not take your vehicle to your GM dealer as a result of this letter unless you believe your vehicle has the condition as described above". More details written....yada, yada. |
Originally Posted by springer-
(Post 1593333892)
Actually I believe the TSB is for all C7 Z51's with 2 piece rotor (2014-2016). It states to check them for runout. It's commonly reported as pulsing in the brake pedal. If there is pulsing and the runout is out of spec then to replace them with the newer 1 piece design. It is noted that it is typically on the front rotors however they are to check the rears as well.
When I got it done (because of pulsing) they only replaced the front as the rears checked out fine. It resolved the issue. My '14 still has the 2-piece rotors, and they are smooth as silk. |
(Post 1593333358)
