Factory full dual stripes
4 Attachment(s)
Hello Everyone, I am throwing out a question about the factory stripes. I have a 2016 Laguna Blue convertible with the silver factory silver stripes and I have had problem since day one. It has been repaired three times at the Chevrolet dealership and it is lifting in the corners of the hood vent area radius and the third brake light area in the center of the lightside of the light. Each time it is the same areas. I was wondering if there has been any other similar problems out there or is this a isolated problem. I took it back this morning for them to check it out again.
Thank you for nay help in this matter. |
I've had no problems with mine but I've always been a little disappointed the stripes weren't painted on like Vipers.
Mine aren't folded over cleanly behind the front clip and at the hood louver. I plan on taking it in in the Spring and having them fixed and/or replaced. Looks like they just stuffed the rest behind those spots. Hideous
Hard to see but are they folding the stripes under and around the ends. I had a Jake installed on the hood and they removed the hood vent so they could tuck it under and wrap it around both vent and top if hood.
Also, did they just slice/cut it at the ends? If that is the way they want to do it, maybe have them or you paint the ends with "Clear Coat".. I did that with a pin stripe that I installed to avoid lifting on the ends and it worked great!.. You can get Clear Coat in any auto parts store and it has a built in brush.. |
Why GM doesn't paint these stripes is beyond me. Pay $75k and get stick on stripes? Crazy. Hope you can get yours fixed to your satisfaction.
Are stripes factory or dealer installed? I'd pay for painted stripes.
Factory installed stickers. And at a cost just shy of $1,000.
I've had no problems with mine. Just wondering, are you taking it thru a car wash?
-Bob George |
Originally Posted by Bruiser2012
(Post 1593383270)
-Bob George |
Originally Posted by Stanimal
(Post 1593381291)
Originally Posted by 2K14C7
(Post 1593384089)
The 2016 Viper factory painted stripes are a $5000 option. :eek:
Originally Posted by KuzVette
(Post 1593381336)
That's pretty bad. Hope they can get it finally fixed for you.
(Post 1593384089)
So nicely done, it's almost worth it... |
