Curt trailer hitch on a C7 yet?
I am considering going from a C6 to C7 for open track HPDE events. I transport my slicks on a small trailer behind my sports car. The Curt trailer hitch has worked great in between the NPP exhaust tips on my present car. Has anyone moved their pipes around yet to attach a Curt hitch? If so pictures would be helpful.
I made mine from scratch.
Takes some time, but can be done. https://cimg5.ibsrv.net/gimg/www.cor...0eb94dc2c8.jpg https://cimg6.ibsrv.net/gimg/www.cor...c67467945d.jpg |
Originally Posted by Magister Ludi
(Post 1593461912)
Takes some time, but can be done. https://cimg5.ibsrv.net/gimg/www.cor...0eb94dc2c8.jpg https://cimg6.ibsrv.net/gimg/www.cor...c67467945d.jpg Bill |
I couldn't find a convenient way to fit the hitch receiver between the exhaust pipes, so I opted for a receiver plus an extension. With the extension, it comes out just under the rear facia. It clears hazards and speed bumps just fine with reasonable care.
https://cimg2.ibsrv.net/gimg/www.cor...5638d07266.jpg Without the extension, the receiver is recessed behind the facia and pretty much invisible. https://cimg7.ibsrv.net/gimg/www.cor...a514db2e04.jpg There are two attachment points. First is to the rear suspension cradle, which already has conveniently located holes for bolts. I put a rectangular plate at the top of the cradle for the bolts to feed through with nuts and lock washers. https://cimg5.ibsrv.net/gimg/www.cor...3142d4dde1.jpg The forward bracket is basically a "U" shape that attaches to the frame on either side of mufflers in the same fashion that Curt hitches do. https://cimg3.ibsrv.net/gimg/www.cor...0827d7fb95.jpg https://cimg4.ibsrv.net/gimg/www.cor...649579f89d.jpg The component parts look like this: https://cimg0.ibsrv.net/gimg/www.cor...9300f7ae72.jpg PS: I'm glad to share any details with my Forum brothers. Anyone contemplating commercial development should see me about a license agreement (patent pending) |
(Post 1593467859)
https://cimg2.ibsrv.net/gimg/www.cor...5638d07266.jpg Without the extension, the receiver is recessed behind the facia and pretty much invisible. https://cimg7.ibsrv.net/gimg/www.cor...a514db2e04.jpg There are two attachment points. First is to the rear suspension cradle, which already has conveniently located holes for bolts. I put a rectangular plate at the top of the cradle for the bolts to feed through with nuts and lock washers. https://cimg5.ibsrv.net/gimg/www.cor...3142d4dde1.jpg The forward bracket is basically a "U" shape that attaches to the frame on either side of mufflers in the same fashion that Curt hitches do. https://cimg3.ibsrv.net/gimg/www.cor...0827d7fb95.jpg https://cimg4.ibsrv.net/gimg/www.cor...649579f89d.jpg The component parts look like this: https://cimg0.ibsrv.net/gimg/www.cor...9300f7ae72.jpg PS: I'm glad to share any details with my Forum brothers. Anyone contemplating commercial development should see me about a license agreement (patent pending) A couple questions: 1) In the "Components" picture, it looks like there are *two* "u" brackets? 2) does the U-bracket require drilling? Appears as if two holes are required? |
looks amazing!!! great job sir!
Originally Posted by Kent1999
(Post 1593472774)
Great job!
A couple questions: 1) In the "Components" picture, it looks like there are *two* "u" brackets? 2) does the U-bracket require drilling? Appears as if two holes are required? If you want to build one, I would suggest doing a mock up like mine below so you can make sure everything lines up before bending steel. (Disregard the "V" shaped brackets; it was an early iteration that I abandoned.) https://cimg4.ibsrv.net/gimg/www.cor...62cf1328d1.jpg |
Is the square tube 1 1/4 or 2" ? How did you attach the u shaped
piece to the frame, I see there is a hole in the frame there, but only on the bottom of the frame, Did you use an L shaped bolt? Very nice job Thanks for the help. John |
Originally Posted by jwbert
(Post 1593487339)
piece to the frame, I see there is a hole in the frame there, but only on the bottom of the frame, Did you use an L shaped bolt? Very nice job Thanks for the help. John I'm tied up at work at present, but will respond with more details when able. Short story: the receiver is 1 1/4" square. Attachment to the frame rails is exactly like the Curt hitches, which involves drilling a hole large enough to insert the head of a carriage bolt and a rectangular retention piece into the frame. It's easier than it sounds. I think there's a Youtube video on it. I'll elaborate more later. |
(Post 1593488805)
John,
OK, so a little more on mounting to the frame.
I used the fishwire technique shown here: I used the "reverse fishwire" technique which requires only one hole. The bolts were 1/2" x 1 3/4" carriage bolts. I got almost all of my parts from etrailer.com. Lots of good info on the site and the reps are very helpful. |
Well done. I'd definitely buy one of those.
looks awesome! really good job!
This is exactly what I have been looking for, exactly.
Private Message Sent. Thank you. David Howard AllVettes4Me |
This is exactly what I have been looking for too, exactly! (towing hitch/bracket)
(Post 1593473417)
I made two different "U" brackets, but ultimately only used the one toward the back of the picture. Yes a total of four holes must be drilled in this bracket. One on each end (for attachment to the frame) and two in the middle, spaced to align with the holes in small plate on top of the hitch receiver.
If you want to build one, I would suggest doing a mock up like mine below so you can make sure everything lines up before bending steel. (Disregard the "V" shaped brackets; it was an early iteration that I abandoned.) https://cimg4.ibsrv.net/gimg/www.cor...62cf1328d1.jpg Are you and/or would you consider making this for other members that don't have any manufacturing skills (lol)? Please contact me because I would be extremely interested in purchasing this type of towing bracket...I intend to use it strictly for carting around a mountain bike; so the weight/towing capacity shouldn't be a huge issue. Please let me know how and/or if I could purchase one of these from you! Thank you. dizrok@aol.com |
Just what I'm looking for!
(Post 1593467859)
https://cimg2.ibsrv.net/gimg/www.cor...5638d07266.jpg Without the extension, the receiver is recessed behind the facia and pretty much invisible. https://cimg7.ibsrv.net/gimg/www.cor...a514db2e04.jpg There are two attachment points. First is to the rear suspension cradle, which already has conveniently located holes for bolts. I put a rectangular plate at the top of the cradle for the bolts to feed through with nuts and lock washers. https://cimg5.ibsrv.net/gimg/www.cor...3142d4dde1.jpg The forward bracket is basically a "U" shape that attaches to the frame on either side of mufflers in the same fashion that Curt hitches do. https://cimg3.ibsrv.net/gimg/www.cor...0827d7fb95.jpg https://cimg4.ibsrv.net/gimg/www.cor...649579f89d.jpg The component parts look like this: https://cimg0.ibsrv.net/gimg/www.cor...9300f7ae72.jpg PS: I'm glad to share any details with my Forum brothers. Anyone contemplating commercial development should see me about a license agreement (patent pending) Thanks!!!!! dizrok |
You have many tape measures!
This is exactly what I have been looking for too, exactly!!!
I've sent you Private Message, but your message box is full... Thank you. W. Sharp dizrok@aol.com |
Any chances we can get the C7 to tow ~ 1,500 lbs (1350lb racecar)?
I made a custom mounted trailer hitch on my 2015. I made a short video that shows how.
I hope this helps! |
