WTB: L/H dipstick 350 block
I'm looking for a L/H dipstick 350 engine block (also a 400 sb) and don't care if it's 2 bolt or 4 bolt main. The only other requirements are that it have a fuel pump boss on the passenger side, and it not be overbored, and of course be in rebuildable condition. Let me know what you have.
Originally Posted by LagunaBlue14
(Post 1593515749)
Motor is solid with around 16,000 miles on it..... I'm located in Brooklyn NY near the Verrazano bridge.....If I do this swap I will let you know..... |
Originally Posted by zrc3john
(Post 1593539346)
I may swap out my parts on my present 350 .40 over to a 383 short block....Its a blueprinted 75 block 4 bolt main with a Lunati cam 489/498 lift I believe...I have the specs home....
Where are you located please? I cannot see this on my mobile application.
(Post 1593545224)
That is a LH dipstick block?
Originally Posted by AllC34Me
(Post 1593546639)
(Post 1593546639)
(Post 1593547135)
its on the drivers side and the fuel pump is on the passenger side...
(Post 1593549499)
I am in central Jersey but travel a lot to friends in Flemington,NJ. That makes it within meeting distance
Back to you today. David Howard AllC34Me |
(Post 1593549559)
I have two engines in my storage area now. I will go and verify the one I am thinking of has a left hand drivers side dipstick. It is a two bolt main, but let me confirm and get back to you today. I am in Easton, PA and would be glad to meet up in Flemington.
7 Attachment(s)
I have two candidates depending upon what you are looking for sir. Both are driver side dip stick with passenger side fuel boss.
First is this 1975 engine complete. I removed the carb and headers, still has all other items on it including the dizzy. Was running two weeks ago when I removed it from the car. Has 57,000 miles on it. I think it has a mild loping cam but otherwise appears to be stock. $500 and it comes on Z-Legs. Attachment 48040681 Attachment 48040682 Second option is this short block. I have the heads as well if you want them. Came out of a 72 with 87,000 miles on it. Nothing modified from what I can see here. $125 for the short block, $150 with heads. Does not have an intake or valve covers. Also comes on Z-Legs. Attachment 48040683 Attachment 48040684 Attachment 48040685 Attachment 48040686 Attachment 48040687 Let me know if you have interest in either of these engines. Thank you and best regards, David Howard AllC34Me |
(Post 1593555787)
PM replied to.
Thank you Dennis. David Howard AllC34Me |
(Post 1593563095)
PM replied to.
