QuickJack BL-5000SLX Car Lift review
I've been reading the articles here for quite awhile and have been looking for some hints on what kind of car lift I should get for working on my vette. I settled on the QuickJack BL-5000SLX since I needed something low-profile that wouldn't permanently take up too much room. This setup works great and fits all of my needs. I included some photos for anyone that may be researching for something like I did and wanted to see what this product looks like.
Here's what the system looks like when fully connected: https://cimg2.ibsrv.net/gimg/www.cor...f0f64e5e46.jpg Here you can see a rear view of the lifts when stored under the car: https://cimg5.ibsrv.net/gimg/www.cor...73990c91af.jpg This is a photo of them in position and ready to lift: https://cimg8.ibsrv.net/gimg/www.cor...5018fff9d5.jpg Here is a view of them in the full height position: https://cimg7.ibsrv.net/gimg/www.cor...719c461a61.jpg You can easily disconnect the hydraulic hoses once the lifts are in position and the weight is on the locking bars. In this photo you can see the additional safety that I included by placing my 4 ton jack in the frame while lifted: https://cimg5.ibsrv.net/gimg/www.cor...224dd594ab.jpg After spending 10 years working on aircraft, I learned that you always needed more than two safety mechanisms on any lift!:cool: So this system is really great for the $$$ spent, and stows away nicely when not in use. While assembling I needed to pay close attention because some things were not as the manual had indicated (the air cylinder had the valves already connected). Here is a short list: Pros
I would definitely rate this lift system at a B+ and I did so when comparing it to the system by brother-in-law has in his garage that is permanently mounted and takes up a ton of space. Thanks all... great forum BTW! |
Thanks for the photos and review. :thumbs:
:cheers: |
I was kicking around the idea of grabbing one of these, are you using the pinch weld adapters or just the included blocks?
What do you use for blocks at the lift points of the car (can't see in pictures) - if that make sense - - also I assume there's the need to allow 18" (??) of distant front or back as the lift rises - only a concern in small garages - mine is only 19' deep.
What did your set up cost delivered?? |
Originally Posted by dclafleur
(Post 1593707225)
Originally Posted by jpipx
(Post 1593708789)
I am using the rubber blocks that were included. They seem to be a high density product and stabilize the car when it's in the air.
I have had mine for two years now and love it. I use it quite a bit and my Vette is on it now for winter storage in my garage. :thumbs:
How many $ for that?
Originally Posted by grandspt
(Post 1593712323)
I was thinking of getting one of these myself.....:rock:
I also have this lift and give it two thumbs up. Next to my race ramps, the two best items I've gotten for Vette maintenance. Now waiting for those who say you'll die if you use this lift. The four post or nothing crowd.
Originally Posted by Weck86
(Post 1593714439)
I'd sure like to have one in my garage. |
Originally Posted by Christi@n
(Post 1593712897)
I do own a two post lift but working on certain things is actually harder on a lift then using this item which is exactly why I bought and use it more often than my real lift.
Don't listen to the posts that say it's not sturdy or safe since it's such thin or lightweight steel because once lifted it's extremely sturdy and it locks into place just incase the hydraulicsame were to bleed off. Another two thumbs up review |
Have one....love it. Zero footprint, up in the air in literally five minutes, very safe design and real easy company to deal with if there is a problem. As stated, it locks in place mechanically so there is no safety issue. If by some freak miracle BOTH steel welds gave way there is still hydraulics in the system as a backup. Two big thumbs up.
