JRZ C7 Double Adjustable Coilovers
5 Attachment(s)
JRZ Suspension Engineering offers the best high performance club sport damper available today. Combining the best aspects of our JRZ RS and 2-way racing damper, the JRZ RS Pro gives the owner ultimate suspension tuning ability while maintaining compliance for driving on public roads. A mono tube double adjustable damper with adjustable gas pressure, the JRZ RS Pro offers an increased adjustment range allowing the user to tune the car to their further needs. The JRZ RS Pro is available as a complete kit with springs and mounting hardware.
Taking club sport performance to the next level, the RS Pro has a remote canister with a digressive blow off system. Digressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. JRZ standard 22mm piston rods maximize flow to the blow off valve response to great chassis control without using a high spring rate. The design of the JRZ RS Pro takes you to the next level. Stiffer cars with higher levels of power demand the control JRZ can supply. With the control of gas pressure charge as well and compression and rebound adjustments, the JRZ RS Pro will get the most out of your high performance car. The JRZ RS Pro is shipped as a bolt on kit with installation instructions and always comes with our world renowned personal service of JRZ. Benefits • Better chassis control for higher rate springs/power/ratio • Street ride, racing performance • Easy to change configurations Recommended applications • Highly modified Street/DE • Experienced club racing • Entry level professional racing JRZ RS PRO SPORT Double Adjustable - External Reservoir Adjustable compression damping 14 clicks Adjustable rebound damping 24 clicks Every click noticeable change Ride height adjustable Gas pressure adjustable (nitrogen) Uses spherical bearings Valved for more chassis control and performance Remote reservoir Every click noticeable change Mag Ride Eliminators http://www.xplosiveperformance.com/C...rs_p_4119.html Attachment 48047647 Attachment 48047648 Attachment 48047649 Attachment 48047650 Attachment 48047651 |
When you demand the most from your car and push it to the limits you want the best
• Better chassis control for higher rate springs/power/ratio • Street ride, racing performance • Easy to change configurations Recommended applications • Highly modified Street/DE • Experienced club racing • Entry level professional racing JRZ RS PRO SPORT Double Adjustable - External Reservoir Adjustable compression damping 14 clicks Adjustable rebound damping 24 clicks Every click noticeable change Ride height adjustable Gas pressure adjustable (nitrogen) Uses spherical bearings Valved for more chassis control and performance Remote reservoir Every click noticeable change Mag Ride Eliminators http://www.xplosiveperformance.com/C...rs_p_4119.html |
1 Attachment(s)
JRZ C7 Double Adjustable Coilovers When you decide to become serious about how your car handles!!!! Recommended applications • Highly modified Street/DE • Experienced club racing • Entry level professional racing JRZ RS PRO SPORT Double Adjustable - External Reservoir Adjustable compression damping 14 clicks Adjustable rebound damping 24 clicks Every click noticeable change Ride height adjustable Gas pressure adjustable (nitrogen) Uses spherical bearings Valved for more chassis control and performance Remote reservoir Every click noticeable change Mag Ride Eliminators http://www.xplosiveperformance.com/C...rs_p_4119.html Attachment 48054427 |
When you decide to become serious about how your car handles!!!! Recommended applications • Highly modified Street/DE • Experienced club racing • Entry level professional racing JRZ RS PRO SPORT Double Adjustable - External Reservoir Adjustable compression damping 14 clicks Adjustable rebound damping 24 clicks Every click noticeable change Ride height adjustable Gas pressure adjustable (nitrogen) Uses spherical bearings Valved for more chassis control and performance Remote reservoir Every click noticeable change Mag Ride Eliminators http://www.xplosiveperformance.com/C...rs_p_4119.html |
1 Attachment(s)
Recommended applications • Highly modified Street/DE • Experienced club racing • Entry level professional racing Attachment 48057178 |
1 Attachment(s)
Benefits
Do C7 coil overs fit C6... and do C6 coil overs fit C7??
Thanks |
Originally Posted by HorsePower Junkie
(Post 1594096616)
Thanks |
1 Attachment(s)
These gunmetal Forgeline 18" GS1R wheels are looking phenomenal sitting on a JRZ RS Pro Susension, a Brembo GT big brake kit and Hoosier R7 tires! Attachment 48068913 |
1 Attachment(s)
Attachment 48074751 |
1 Attachment(s)
Taking club sport performance to the next level, the RS Pro has a remote canister with a digressive blow off system. Digressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. JRZ standard 22mm piston rods maximize flow to the blow off valve response to great chassis control without using a high spring rate. The design of the JRZ RS Pro takes you to the next level. Stiffer cars with higher levels of power demand the control JRZ can supply. With the control of gas pressure charge as well and compression and rebound adjustments, the JRZ RS Pro will get the most out of your high performance car. The JRZ RS Pro is shipped as a bolt on kit with installation instructions and always comes with our world renowned personal service of JRZ. Benefits |
