Vibration at 55 mph+
I own a 1991 ZR1 which vibrates slightly at higher speeds - generally above 55 mph. Feels like it's coming through the seat/bottom. I now have at a driveline shop and they think it may be associated with bad ujoint(s). They are putting up on lift shortly and running it to see which ones are bad. My understanding there are 8 ujoints?
My question, rather than replacing all ujoints if only one is bad (troubleshooting) - are there any particular ujoint(s) that go bad first to replace? Thanks! |
Mine just needed the half shaft joints. But good time to do them all.
Half shaft joints go first, but if you are having heavy vibrations through the steering wheel, you may want to have a good look at the balljoints too.
Thanks to all that responded to my original post. Quick question again:
Well we may replace the half shaft u joints first BUT would bad half shaft ujoint(s) cause vibration at both the steering wheel and from underneath? Thanks |
Originally Posted by TealZR1
(Post 1593786785)
Road force balance fixed my 94 coupe after 4 wheel alignment.Computer tire balance would not stop vibration at 65+.Now all is well.
Its strange I have been trying to get rid of vibrations at 80 mph, I just got new tires ,alignment, and was replacing my shocks found left front was locked. Have not been out on highway yet but seems like it could be anything, I have replaced all ujoints.
Originally Posted by xrav22
(Post 1593796824)
Its strange I have been trying to get rid of vibrations at 80 mph, ..... was replacing my shocks found left front was locked.
Have you driven it yet? |
Originally Posted by vader86
(Post 1593754399)
(Post 1593786785)
Ball joints, tie rod ends, tie rod ends at the steering rack and tire balance will shake the steering wheel. Now that you're doing some maintenance, check those rear wheel bearings before everything goes back together. It'd be a shame to pull that rear end apart again for a wheel bearing. :smash: |
Originally Posted by JrRifleCoach
(Post 1593797208)
:yesnod::yesnod::yesnod:
Ujoints will shake your butt. Ball joints, tie rod ends, tie rod ends at the steering rack and tire balance will shake the steering wheel. Now that you're doing some maintenance, check those rear wheel bearings before everything goes back together. It'd be a shame to pull that rear end apart again for a wheel bearing. :smash: Don't forget the Teflon washers. :thumbs::cheers::thumbs: |
Originally Posted by A Peter C4
(Post 1593795673)
I agree on the u joints. I am getting a vibration at highway speeds too. This just started last year on mine. I also got a leak at the pinion seal as well even after a complete rebuild by the local speed shop. I am runing Yukon Gears (3.55) and they are noisey as hell. I am getting ready to change the rear to a D44 rebuilt with Dana gears and new u joints so we will see what is up.
Since I started this thread. Conclusion was the Tire Monitor Module broke loose from the wheel and was churning violently. Rides much better but will check into a speed balance and possible wheel balance this weekend here into Atlanta where it will be almost 70 degrees for Caffeine and Octane!
(Post 1593839165)
I sheet you not! Here is a pic. Funny, the warning light never came on either. Thanks for all's help!https://cimg8.ibsrv.net/gimg/www.cor...87f29b3ae2.jpg
(Post 1593843382)
(Post 1593797148)
Locked? Musta handled like a truck.
Wow, who knew?!?!
BTW and file in the back of your memory bank many (and I mean many) years ago I had a front end balance issue in another make that stumped lots of people for months. Turned out the gas station I was filling up the tires with never drained moisture from their tire pressure pump. You guessed it, the tires were filling up with water and causing a tire balance issue which understandably got crazy when the temp went below freezing....! |
