c6 Backup camera
Looking for some advice and recommendation on a backup camera for my C6. It is a 3LT with Navigation so I want something that is compatible with the factory radio.
Originally Posted by Stevied
(Post 1593799707)
Steve |
Originally Posted by bassman50
(Post 1593799985)
What year is your Vette? From what I understand, the earlier cars' radios equipped with Nav are not compatible with a back-up camera. I have a 2007 3LT with Nav and it would be a lot easier to replace the radio with a late model aftermarket unit with Nav and set-up for a back-up camera.
Steve |
Factory radios are not CAM capable.
Not the cheapest but definitely the easiest solution to adding a quick rearview camera for a Corvette where you want to keep the stock radio: https://pearlauto.com/ Keep in mind you will easily spend twice that amount to put an aftermarket radio, control adapters, rear camera, and labor to install for an aftermarket radio and lose HUD integration. If you are fine with OEM radio and navigation and only want to add backup camera capability swapping out the radio is not a cost effective option at all. |
Originally Posted by RC4G
(Post 1593801387)
Factory radios are not NAV capable.
Not the cheapest but definitely the easiest solution to adding a quick rearview camera for a Corvette where you want to keep the stock radio: https://pearlauto.com/ Keep in mind you will easily spend twice that amount to put an aftermarket radio, control adapters, rear camera, and labor to install for an aftermarket radio and lose HUD integration. If you are fine with OEM radio and navigation and only want to add backup camera capability swapping out the radio is not a cost effective option at all. GM missed the boat on this feature..:ack: |
Unfortunately, the GM Nav Radio does not have any video inputs for a BU camera. There was LockPic 360 that was once available as a harness to add a video feed, but it was not that popular, so it got canned. Every once in awhile you see one on the FS section of this forum.
I got a cheap camera, and added a monitor inside the sunvisor where the vanity mirror used to sit. It's out of sight, looks OEM, and is easily accessible when needed. The Homelink for the garage door opener still works on the sunvisor. https://cimg5.ibsrv.net/gimg/www.cor...e1cfcb575e.jpg |
Originally Posted by LV2TOUR
(Post 1593802669)
Originally Posted by teebee
(Post 1593803233)
I would be very interested in seeing a write-up on how you did this!
Thanks...looking into doing this upgrade!
I too would be interested in seeing a write-up on how you did this.
Wally |
Would you post a link to the write up if possible?
Originally Posted by wallyh
(Post 1593809358)
Wally Anyone that wants it can PM me their e-mail and I'll gladly send it to them. |
Originally Posted by CaliVetter
(Post 1593810352)
(Post 1593801387)
Not the cheapest but definitely the easiest solution to adding a quick rearview camera for a Corvette where you want to keep the stock radio: https://pearlauto.com/ Keep in mind you will easily spend twice that amount to put an aftermarket radio, control adapters, rear camera, and labor to install for an aftermarket radio and lose HUD integration. If you are fine with OEM radio and navigation and only want to add backup camera capability swapping out the radio is not a cost effective option at all. Yikes.. At $500 i'd throw another $200 and get a camera and a better radio.. |
(Post 1593810566)
The PDF file is large so I can't post it here.
I just understand why my 07 burb had backup camera and my 2013 GS doesn't when it's basically the same F-ing radio made by the same guys put in the same brand of car. Ok rant is over.
Originally Posted by Cruiser1964
(Post 1593814600)
(Post 1593803233)
If you could PM me also on how you did that sunvisor it would be greatly appreciated also. |
Pdf
(Post 1593810570)
Anyone that wants it can PM me their e-mail and I'll gladly send it to them. Thanks, jeremym422@yahoo.com |
Originally Posted by Jeremym422@yahoo.com
(Post 1594949157)
Very clever solution to use the visor, besides the covers on my vanity mirrors have broken off.
