Autox in Rain: Nitto Invo vs RE-71R vs PSS vs ?
Yes, sometimes we have to autocross in the rain.
C6 Z06. I have my A7s for dry, but for autocross in the rain, AND street driving, I want to stay at treadwear 200 or higher. So don't worry about classes. Opinions please... Nitto Invo Bridgestone Potenza RE-71R Michelin Pilot Super Sport Anything else better ???? |
I had no issues driving the RE-71R's in heavy rain on the street, but really don't think they'd be a great autocross tire in the rain at all.
Pilot Super Sport is your best bet if you're actually looking for a good all around tire and not just pure dry grip (go RE-71R in that case). I wouldn't recommend those silly Nitto Invos for anything but a showcar and getting your Starbucks coffee on Sundays. :ack: |
The new RS4 hankoook is coming out. Might be something to watch. The 200 treadwear tire class has blown up!
Pilot Super Sport or Conti DW (or the new versions of each). End story. If you want the best wet tire that's 200 TW and no concern about dry speed, it's the DW. If you want a touch more dry speed but less wet, then PSS. RE71's are not what I'd call a "rain tire". Maybe could be considered so if you were in a very dry area and rain is super rare. Pacific NW doesn't seem to fit that description to me.
Thanks Sam.
As always, your advice is sage. |
Originally Posted by Sam Strano
(Post 1593951737)
Originally Posted by chetly
(Post 1593959877)
How do you explain Chris winning STP on the RE71R's then? Granted they were narrow and full tread depth...
EDIT: Did STP get rained on at Nats? I didn't stay for all the runs on Friday but I didn't remember them getting rain Thursday. |
Yes, they got rain on the 2nd day. Chris was something like a couple of seconds faster than 2nd because he was on stock size s550 wheels with full tread 255 RE71R's.
It depends on how hard it is raining. R compound tires will do pretty well in a light drizzle and will still perform better than a treaded tire. Yes, the tires will slide around a little more but not as much as a treaded tire which has a much smaller contact area touching the ground. Once the water on the pavement gets deep enough the empty portions of the treaded tire become useful by providing a channel for water to evacuate from under the parts of the tire touching the ground the treaded tire will work better. One way to improve slick performance in the wet is to raise the tire pressure a few pounds which lessens the contact area a small amount and increases pressure on the parts of the tire that are still touching the pavement. The soft rubber compound of the R compound or slick tire is still better than the harder compounds found in treaded tires. You just have to adapt to keep it in touch with the pavement which means adjusting pressures higher, adjusting driving technique to avoid shocking the tire contact point with sudden changes in direction, braking or acceleration.
Bill |
(Post 1593959877)
1. He can drive 2. What was everyone else on? 3. STP wasn't exactly teaming with entries,and I don't recall any being the level driver Chris is 4. I be with as wet as it was, if he had another tire option, and it woudl not have cost him contingency (always a large factor in what we do) he might have run something else. Are those 4 good enough reasons? :) |
Look. It's a trade off. ALL Tires have some tradeoff.
How wet are we talking here? If there is no standing water to pump away, it's damp then the stickiest tire will be the best one. If you have water to pump, how much? A little? Ok then shallow depth, big tread block tires are ok for that too. But as it rains harder and harder the need moves from as much tire down on the ground as you can get to getting water out from under there to let the tire stay on the ground. Then narrower tires are better. Tires with more grooving are better. Both being the best to move a lot of water. Gary lives in the Pacific Northwest. It can get wet there. BTW, this debate is what is so frustrating about internet opinions. Without defining "wet" it's hard to pick the right tire. Hell it is anyway that's why folks will try different tires. |
I will be on a7's waiting for you in the dry!!!
(Post 1593963076)
Uh, well. Let's see.
